Question about Samsung RF220NCTASR 21.6 Cu. Ft. French-Door Refrigerator With
Brand new Samsung RF220NCTASR - plugged it in - lit up, cooled etc Unplugged it next day (working) for a few mins - replugged - no sign of power - checked wall socket and it is working - any ideas?
    Master:
  • 552 Answers
If power interruption is short duration (<5 min) compressor will have a delayed start to protect itself.
Posted on Dec 09, 2016
5 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: No power light.
First make sure it does have at least red indicator on the front panel, if not, the standby +5vdc is not working, common problem with this monitor is dead power supply due to bad caps, shorted transistor and Zener Diode in the standby power supply.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
Power supply; http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=hdgBTL6MJaKMNZLC1Ts&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCQQrQQwAA
Posted on May 30, 2010
ripleymojica
  • 643 Answers
SOURCE: Hi, My name is Anali and
Hi Anali. That sounds like the powersupply is bad. The tv has a one year manufactuers warranty. Take it back to Target and exchange for another one. Hope this helps.
Posted on May 27, 2011
  • 8457 Answers
SOURCE: approx. 1999 32" Sony Trinitraon
Yes,this tv it is repairable.This tv it is a Analogue tv have a big back cover (CRT- tube) tv wright?Yes?The tv have a FBT-(Flyback transformer) it is a big black plastic block with a red wire with a black cap hook to the CRT-(tv tube).That FBT-(Flyback tansformer) give the tv High voltages to the tv and causes most of the tv power shutdown problems.Also the outer side of the protection wall of the FBT-(Flyback transformer) there is a big or a small flat "H"-horizontal transistor with a screw onto it top screw tight and solders to the FBT-(Flyback transformer) outer side protection wall.If u have a soldering Iron a roll of solders and know how to do basic soldering works.Just take the tv aparts.Just resolders the FBT-(Flyback transformer) also it the outer side protection wall the "H"-horizontal transistor with a screw onto it top.90-95% will solved tv mishap have power work one day no power and don't work the next day.5% the "H"-horizonal transistor it is dying slowly.Or take the tv to any tvs shops and tell them that.If they're not trying to cheat u and trying to ripping u off.They'll take the tv aparts wright there and resolders the FBT and "H"-transistor for u like $35 or $40 dollars max.The whole jobs don't take more than 20-25 mins max.
Posted on Aug 29, 2011
SD Tech
  • 14553 Answers
SOURCE: no power
This sounds like a very common issue.
If set is hard to turn on (takes several tries)but will eventually turn on hereis what my guess would be.
Every set has a standby power supplythat is running 7/24 if the set is plugged in and it supplies voltage to theremote circuit that turn on the main power supply for the tv and hence turn theset on.
This is an area where companies cut corners by using lower rated voltage caps.By this I mean Standby usually provides under 10 volts to trigger the seton----what they do is use filter caps rated at say 10 volts max in a circuitwith 9 volts (example)=with the standby on all the time the filter caps(electrolytic caps) dry out and fail.
The problem usually begins where you have to turn set on or or two times andgradually gets worse--takes longer and more tries to get it to come up.
Once on it will stay on until turned off for a period of time.
The caps will begin to work better (regain some of thecapacitance) as they get hot--hence one it is on it will seem ok.
The beauty of this problem is most of themhappen when set is a year or two old (no warranty) and all you have to do islook at the top to locate bad ones.
They are generally black or blue and round and vary in --they have twoconnections each--a + for positive and a - for negative--not unlike a batterywhich in a way they are. The + and - are marked on top and bottom of most boards.
They are easy to replace and not expensive parts.
The tops are silverand metal looking with creases on top and if bad they will be puffed up ontop---tops must be perfectly flat with no brown material leaking top or bottom.
If this is your problem once you id them (make a drawing) you can begin.
Here is the critical part---on each cap is also marked the value like 220uf 10vdc---220 micro farad at 10 volts maximum.
If you find for example 6 puffed up and all are 10 vdc replace them with thesame value capacitance (like the 220 uf) but go up to at least in this case(from 10 volts) to a 16 or higher rated voltage cap.
The only issue is when you go up in voltage rated value the cap is larger sosometimes there is an issue of physical space for the replacement on the boardto fit them in.
The reason they cheapen these sets in this way is if 10 caps and you make25,000 sets there is a considerable savings in parts cost.
They do not care as long as it lasts past the usual one year parts warranty.
I have taken the time to be long winded because this really sounds like it maybe the problem you have.
See attached photo of a typical cap and if you have questions or need advicelet me know.4_28_2012_1_42_42_pm.jpg
Posted on Apr 28, 2012
Why doesn't it stay on?
The power supply may be failing
Feb 11, 2016 | Sanyo DP26746 26 in. LCD Television
My freeer stopped working after the temps dropped
freezers have a range of ambient temperature uses
most are plus 10c to 35c if using some units in garages etc. they just dont work...too cold for the poor things...
Feb 04, 2010 | Frigidaire 11.6 cu. ft. / 328 liter...
GE Profile refrigerator cooling system failure
Replace the mother board. Part will run aprox. $185. Get a new one, in a factory sealed box. Easy to replace, just take the rectangular cover off the back and transfer the multi plugs. Takes about 10 minutes.
Jun 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Wii won't power up
Leave the wii power brick unplugged from the wall socket for 15 min then try to plug it back in. This worked for me.
Jun 11, 2009 | Nintendo Wii Console
Refrig shut off and will not restart - light bulbs still working
this refrigerator sounds like a 'frost free' type, and as such can, usually, only be repaired by the manufacturer. local refrigeration engineers cannot get the parts. your fault sounds like a PCB (printed circuit board) has gone, which only the manufacturers have in stock.
Jan 25, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Wii / No Power
or you can remove all of the plugs from the console: AC, remote sensor, AV. This is important: You must also unplug the AC from the electrical outlet. Then wait 45 seconds, then plug the AC adapter back into the wall and your console. Power On.
Dec 25, 2007 | Nintendo Wii Console
Refrigerator won't get cold
hi!, if you did not turn on the thermostat by turning it clockwise and set on highier setting, it will not getting cold. 1hr is enough to test if the unit is in good condition.
Nov 19, 2007 | Samsung RF265AA Bottom Freezer French Door...
Printer shows offline
your next plan of action should be to let the printer reset its self. Unplug the printer for a few minutes then plug it back in. Turn printer on and try to print something. If this does not work then what i would do is use add remove programs and remove the software and drivers for the printer and re install them again. Read and use the manufactures recomended way of installing your new printer. Start off with printer unplugged and usb unplugged then begin as if you bought it brand new. I cant stress enough how important following the manufactures instructions are.
Feb 19, 2007 | Lexmark X1150 All-In-One InkJet Printer
Once Standby mode shut down Monitor will not operate for a few days
Problem is maybe caused by electrolytic capacitors in PSU you can inspect them visualy if their top is blown then they are defective you can easily replace them.
Good luck.
Nov 14, 2006 | Samsung SyncMaster 173P 17" LCD Monitor
Samsung RF220NCTASR 21.6 Cu. Ft. French-Door Refrigerator With Logo
43 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
