Vizio 60" E601I-A3 Full HD LED-LCD TV Logo
A
Antonio Belton Posted on Dec 05, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What are the symptoms of a Vizio e601i-A3 main board that has gone bad?
I have a Vizio e601i-A3 that is malfunctioning. My symptoms include unexpected shutdowns, no wifi sources found and non responsive remote and side buttons. I assume the main board has gone bad. Is this the case?
Ostia Mosley
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 16, 2019
Ostia Mosley
Contributor
Level 1:
Answers
Questions
0
Helped
984
Points
I have a 2016 vizio D50-D1 smart tv. I had just powered the tv on when I hear a pop and then the standby light faded then the tv went dead. No power on or off. Only power is in the back ethernet plug. I replaced power supply do u know what it can be?
Lawrence Oravetz
Level 3:
  • Vizio Master 10,558 Answers
  • Posted on Dec 06, 2016
Lawrence Oravetz
Vizio Master
Level 3:
Answers
10558
Questions
Helped
2700220
Points
29284
You are correct. You can get replacement parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy
The backlight on my Vizio E601i-A3 is not coming on. How can I tell whether it is the power board or the LEDs themselves?
Vizio had a recall on this model TV resulting from the issue your having, below is a link to the recall. What they said was recently Vizio put up a special bulletin on its website stating a number of its 60-inch E601i-A3 and 70-inch E701i-A3 HDTVs may lose the picture (but maintain audio) due to a bad "chip assembly". The "chip assembly" is actually in the main board, Ive fixed a number of this model TV's by replacing the main however Ive also seen the lamps fail as well so its kind of a guessing game as far as where the issue is at unless you have some high end test gear to troubleshoot the set.
Vizio Issues Recall On Large Screen LED LCD HDTVs
I have a Vizio E601i-A3 tv that has video problems.
You have a bad tcon board or the panel is bad but this set has some issues with the tcon board...you could try baking it if you wanted, its not going to hurt anything
I have a Vizio E601i-A3. The "Vizio" emblem does not light up and the screen does not light up. Is it most likely power board that needs to be replaced?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Vizio E601i-A3 Does not power on
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
1helpful
I have a Vizio E601i-A3 model # LFTRNWAN4909536. The screen comes up and reads "no signal" none of the controls on the side of the tv function and the remote control isn't working either
http://electro-medical.blogspot.com/
VIZIO E601i-A3 has a blinking screen or i could say a pulsing screen when i turn on the black-light in the settings. When Black light is off no pulsing. Is it the T-Con card.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
