Question about Royal 10X Shredder
Runs in reverse, but no on auto.
It suddenly stopped working on auto to shred paper. The reverse will work, but not the actual shredding. Is the sensor light broken?
    New Friend:
I to am having this issue. So far this is what I have done: Took out the screws that hold the incasement together, on the left side there is a small switch (it is the auto shut off when it is sitting on the paper bin) I checked the gears to ensure all the teeth are in place and not broken or worn out, that was ok. Remember that you can control the shredder because you can and will be holding the switch. OK this you really have to take care because you need to plug the shredder in, turn switch to auto, try a piece of paper, I know not going in.... Now switch to reverse, I know the paper does go through.... Now VERY carefully turn on to the side, put a piece of paper in where the shredding comes out, Wow that works. I have realized that the motor ONLY operates in REVERSE!!!! 1. How do I fix it???? 2. WHY & HOW did this happen?
Posted on May 19, 2013
    Master:
    Sergeant:
  • 226 Answers
Check and see if there is a jam of paper inside the unit or around the sensors
Posted on Jul 20, 2009
My shredder won't shred
If the motor will not run, then probably there's paper clogged in the shredder. Turn over the shredder, after unplugging the power cord, and remove the papers.
If the motor will run but not shredding any paper, then the drive gear has broken teeth. This is not usually worth fixing.
Hope this helps.
Mar 27, 2015 | Shredder Office Equipment & Supplies
My shredder runs non stop, when I insert paper to shred , it stops... I push reverse, it works , pull paper out and runs non stop.......
Sounds like a bad or stuck sensor, acting as if it is always seeing a peice of paper in it. Check if you can find it and maybe it is just stuck to the on position..
Nov 07, 2013 | Omnitech 10-Sheet Micro-Cut Shredder
Spl-txc122a
The motor runs reverse even when in Auto mode, how do I fix it, and why did it happen
Mar 27, 2013 | Staples SPL1506X (CrossCut) Shredder
Hello my nane is Tom. The shredder doesn't work. It will run in reverse but when I turn it to forward it run for a second or two than stops. I looked and I can't see anything jamed in it.
I got mine to work by running it on reverse for a moment then sliding it to auto. It stopped. Then I did it again. This time auto ran just for a second then stopped. I did it a third time but I had a sheet of paper ready in the feeder. Ran on reverse. Slid it to auto and it took the paper and shred it. I did it a fourth time. Reverse slide auto and feed shred the paper. Fifth time Auto shred the paper without reverse. :)
Aug 30, 2011 | Aurora Electronics AS662C Shredder
Jammed in Auto, but works fine in reverse. How to unjam?
Continue to alternate between auto and reverse a number of times. Try to shred narrower pieces of paper at opposite ends to see if it can trigger the auto trigger wire. All else fails, carefully take the shredding part apart and you may find a hugh paper jam underneath.
Sep 02, 2010 | Aurora Electronics AS662C Shredder
Shreds in reverse only
I think there is a shredded buildup on the bottom. Unlpug the device ... turn it over and clear out the residue you will find there.
Sometimes I find the addition of shredder oil during the shredding process helps to eliminate this problem. Get the oil where shredders are sold.
May 31, 2010 | Tech Solution TS-4500 Shredder
It will not shred - the reverse works fine
UNPLUG THE MACHINE AND TRY CLEANING THE "EYES" WITH A SOFT CLOTH. IF THAT DOSN'T DO IT YOU MAY HAVE DEFECTIVE EYES OR PCB...YOU CAN CALL ROYAL FOR PARTS AT 1-800-524-0799.
May 21, 2010 | Royal 85X Shredder
My shredder stop shredding. has paper caught in it
Shredder drive gear is probably shredded - hard part to find or replace usually. Could mean a new shredder;-(
Aug 29, 2007 | Quartet gbc 6120S Shredder
Royal 10X Shredder Logo
1,020 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
