Question about Air Tools & Compressors
Cooey model 60 manual for service or repairas i need to replace or constuct new trigger assembly
5 Suggested Answers
  • 44 Answers
SOURCE: I need a service manual Electrolux 6500
I don't have a service manual but maybe I can give you some instructions that will make some sense. Open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl covered strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl separates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come of relatively easily, and everything will be exposed. The control valve rests under the bag housing, since the machine is now upside down. I hope this helps. Good Luck!!
Posted on Jan 03, 2009
  • 2176 Answers
SOURCE: bostitch n80s nail gun leaks
under my name click on it and in the tip section on the left hand side of the page you will find detailed instructions on how to remove this valve. If you have trouble finding it let me know and if I have helped you with your problem would you please vote accordingly, Thank you
Posted on Mar 25, 2011
  • 40473 Answers
SOURCE: i need a service manual for Broksonic TV model number lcd 3276 60 hz 100 watt
Request the manual directly from Broksonic.
Posted on Sep 14, 2014
  • 95 Answers
SOURCE: how do I replace a old style slide safety trigger guard assembly with a new style cross bolt style on a Remington model 11 shotgun???
Take it to a gun shop and ask them to do it.
Posted on Jan 09, 2015
What year is a cooey model 84 .410 shotgun serial number 18017
Cooey model 84 Gunsopedia
I can try and delve deeper but slim hopes on your serial #Cheers Pete
Apr 29, 2017 | Firearms
How to replace a trigger on the arm of a homelite 250 gas pack leaf blower
look up the service manual online. if you can get the trigger assembly it should be a straight forward replacement. only issue will be the getting the correct torx screws.
Aug 30, 2015 | Homelite Garden
How to use the upholstery attachment for hoover max extra 60 carpet cleaner?
Hey there! The nozzle/valve that releases the solution from the hose may be clogged and not closing off to stop the solution flow. You can try soaking the trigger end in warm water for a few hours to unclog it. Also make sure you are inserting the hose back into the hose slot in the back of the cleaner. If the cleaner is still dispensing from both the hose and the cleaner, your nozzle/valve assembly may need to be replaced. To order a replacement nozzle/valve assembly follow the link below.
Search Results
Hope this helps!
Aug 30, 2014 | Hoover Max Extract 60 Pressure Pro Carpet...
Why won't my Hoover SteamVac 7000 LS spray?
Hi there! Be sure you are only using the recommended detergent for your cleaner. Sometimes it is necessary to prime the trigger to get the solution to flow. Give these quick steps a try.
1. Recline the handle
2. Pump the trigger 30 times
3. Power the unit on.
4. Squeeze trigger for 60 seconds
If the cleaner still wont dispense you may have an issue with your pump assembly. We recommend taking your unit in to an authorized service center for repair. I have included a link where you may go to locate a service center near you. Service Center Locator
Aug 03, 2014 | Hoover SteamVac F5914-900 SpinScrub...
No water getting to brushs
Hi! Sometimes it is necessary to prime the trigger under the handle to get the solution flowing. To prime the trigger, recline the handle and pump trigger about 60 times. Then, power the cleaner on and squeeze the trigger for about 60 seconds. The solution should start to dispense. If it is still not dispensing there may be an issue with the pump assembly on the cleaner. We would recommend taking the cleaner in to a Hoover authorized service center for repair. Follow the link to locate one nearest you. Service Center Locator
Hope this helps!
Jun 12, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
How do i install trigger kit in qtimax
Unfortunately IR does not have a maintenance manual for this model, but you can use the manual for a model 2131.
The air inlet assembly is slightly different on both models but the parts kit will fit both models, assembly and disassembly are the same.
Follow this link for a maintenance manual:
Apr 03, 2013 | Ingersoll Rand Ingersollrand 2135timax 12"...
I have a Stanley Bostitch N80SB with the sequential trip kit. I have installed a new trigger valve assembly, and the unit now holds air pressure, but the trigger will not activate the plunger. I can...
The safety foot assembly pushes up on inner trigger lever which in turn pushes on the trigger valve. If the trigger valve firing pin is slightly shorter than the old trigger valve, or the inner lever is worn from use, the inner lever will not push the trigger pin all the way in. Examine the trigger and the roll pin that holds the trigger for wear and check that the safety is pushing up on the inner lever. If the trigger is worn replace or repair with metal type epoxy filling in worn spots and use a new roll pin.
Aug 18, 2011 | Stanley Air Tools & Compressors
I need help replacing a bostitch framing air nailer trigger model 28ww it's leaking air and won't work.
follow closely, do you have a new trigger assembly because the problem is with one o ring commonly referred as the purple o ring in the kits? either way the procedure to remove the trigger is first knock out the roll pin for the trigger latch and then the 2 roll pins for the trigger assembly. next get a shop rag or equivelant and place under the now exposed trigger assembly and then while holding the collar on the air chuck plug into tool and hold rag tight and trigger will "pop" out pull the chuck away and remove the 2 pins to disassemble the assembly or install in reverse order lubricating the o rings first. Let me know if you have any questions or problems.
Nov 22, 2009 | Stanley Bostitch F28WWMCN 28° Industrial...
Bostitch framing gun
HI, if it happens when you press the trigger the top valve is sticking & your gun needs servicing.
If it is just leaking by itself the trigger assembly needs serving or you can replace the trigger unit. They are not expensive & come as a complete unit (depending on the model).
Moselikely the orings are worn out or dirty
Oct 08, 2008 | Tools & Hardware - Others
Air Tools & Compressors Logo
109 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
