Question about Zanussi Washing Machines
Our new Zanussi Lindo300 washing machine moves around quite dramatically when on spin due to vibrations even on 800rpm spin. I have to push machine back into position after washl. Can some one advise.
  • Zanussi Master
  • 10,028 Answers
The load is unbalanced. Try moving heavier or bunched up clothes to a different place in the tub and watch it spin. You may have to rearrange the load slightly to keep the vibrations to a minimum.
Posted on Dec 06, 2016
My machine has stopped before spin
It might be off balance, can you move some of the items around to be sure it's even all around. Mine does that sometimes when I do towels or bathrugs.
Mar 04, 2015 | Zanussi FS1155W Front Load Washer
Washing machine
is the machine new or newly installed, check on the back to ensure the travel pins or bars are removed. when the machine is new or when moved the packers may have replaced the movement pins this stops the drum swinging around and damaging the outer casing. if used with them still in the drum can not swing freely and the whole machine will vibrate. if this is not the case, the washing maybe uneven in the drum casuing it to vibrate. if either of these is not the case the drum maybe unbaleanced or the weights may have dislodged. then will have to go in for repair.
I hope this was useful.
Feb 15, 2013 | Zanussi Washing Machines
My washer model fjs1397w wont move through a wash cycle or spin drum wont go around on any cycle , tried moving it around by hand will not do anything
if you are unable to turn the drum by hand it may have ceased due to a sock or item of clothing jammed in it behind the drum this in turn may have snapped the belt
regards
Ian
Apr 20, 2011 | Zanussi FJS1225W Front Load Washer
Bosch classixx 1400 express spin vibration problems - when my machine spins is vibrate violently and moves across the floor - how do i fix it?
Is the clothing distributer evenly around the drum or is the washed bunching it up and spinning it around as a ball.
Jan 16, 2011 | Washing Machines
Machine vibrating badly
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 13, 2010 | Zanussi ZWF1430W Front Load Washer
Washing machine has a seizure during the spin cycle.
Try leveling the washer so that it is about half a bubble biased towards the rear. This usually helps front loading washers balance properly even if the installation instructions say that it should be perfectly level. This can also aid draining problems.
Also, some newer front loading washing machines are simply prone to dramatic vibration even when they is "anti-vibration" or "vibration reduction" systems. You can never go wrong installing an anti-vibration pad under the washer. Good Vibrations Inc, Kellett Enterprises and The Vibration Solution all have good products. The Vibration Solution seems to have figured out the best solution and offers excellent support and return policies.
Washer anti-vibration pads
If all else fails call the retailer and ask for an exchange.
Jun 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Coin trapped between rotating drum and casing
Get underneath the machine and remove the big black house coming directly out of the drum,this is held in place with either a screw tie or pinch type tie.
Put the machine back level and see if the coins drop out (they should) or have a feel around inside the drum.
Please make sure machine is unplugged and empty before carrying out this procedure.
Some water will come out of hose.
Nov 19, 2008 | Zanussi ZWF1430W Front Load Washer
LG Intellowasher 7kg 800rpm WD-8074FHB washing machine now makes a very loud noise when spinning whereas before it was completely silent. machine still washes & spins OK but the noise is very loud and...
It could be that the springs have become lazy (stretched) and not supporting the spinning weight as good as they once did or as happened to me one of the shock absorbers at the base of the unit has come adrift from its securing point. Replacement parts are easily available but you will need someone strong to fit them with all that new tension.
Aug 08, 2008 | Washing Machines
Not spinning
First clean out your outlet filter. If this does not work, open up behind and tighten all points where wires are joined; due to vibrations these might have come loose. Plug off the wall first!!
Rate me if it works.....
Dec 28, 2007 | Zanussi FJS1225W Front Load Washer
At bottom left of machine there is a small metal flap where you can drain off water. Next to that is a grey pipe you can keep pulling and pushing i have done this quite a few time and it has let out sludgey stuff put washing machine is now spinning and draining. Good Luck.
Aug 29, 2007 | Zanussi ZWF1420W Front Load Washer
Washing Machines Logo
113 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
