Question about GE Refrigerators
GE PSS26MGPA ClimateKeeper refrigerator side too cold - gets below 32 degrees with control set at 1 (warmest)
  • GE Master
  • 10,137 Answers
The thermostat isn't shutting off the compressor at the correct temperature. Changing that thermostat is a big job.
Posted on Dec 06, 2016
Ge refrigerator won't hold set temp-gets too cold
Probably the motherboard - the weakest link in the system. They're made in China using the cheapest components the chinese can find. Expect it to fail early and often.
Same is true of every other so-called "smart" appliance on the market.
Apr 17, 2014 | GE Profile PFS22 33" Artica French Door...
GE GSL25JFXLB (250 cu ft) Side by Side Refrigerator
your thermistors are way out of range even at that temperature you say,put each thermistor in a glass of ice water for 5 minutes,then remove the J1 connector from the main board and check with an ohm meter set on 20k ohm between the thermistors common terminal #5 and the other pin terminals all thermistors tested this way should be about 16k ohms when tested this way,if not replace them
Feb 11, 2013 | GE GSL25JFXLB (250 cu ft) Side by Side...
Refrigerator is too cold even when adjust the temperature
Too much freon? Or maybe you got the controls mixed up. My refrigerator used to freeze a gallon of milk over-night.
Nov 18, 2012 | GE Adora DSS25KSTSS Stainless Steel Side...
Wide variation in temperature in refrigerator section (40 degrees in top, 20 degrees in bottom, also, freezer set at WARMEST setting is ten degrees below zero.
Amana refrigerators older than 5 years have both a cold control and freezer control. this may be your problem. But check both the gaskets on the doors and check for heavy dirt on condser coil. Both can cause wild temp problems. Hope this helps
Aug 17, 2011 | Amana Refrigerators
GE Profile GSS25LGMB
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 05, 2009 | GE GSS25LGM Side by Side Refrigerator
My GE side by side has started freezing everything in the refrigerator on the warmest setting and the freezer will not maintain less than 10 degrees on the coldest setting. Any ideas?
on the left side of the crisper drawer there may be a air return hole that you can adjust, if not try some duct tape where the air comes into the fridge, cover it by 1/4 then 1/2 till it is the right temperature
Aug 04, 2009 | GE Refrigerators
Refrigerator does not get cold - GE side by side
In my GE side-by-side refrigerator (model number GSS20IEMDWW), there is a motor-controlled flapper door between the freezer and fresh food side. Cold air from the freezer side cools the fresh food side when that flapper door is open.
It is located at the top of the fresh food side on the dividing wall between the fresh food side and the freezer. If this is blocked with something (large left-over container, soft drink bottles, etc), it _may_ be enough to prevent sufficient cooling of the fresh food side.
Of course, there may be a more serious problem with the flapper door mechanism or the control unit that signals the flapper door to open/close.
The vegetable and deli drawers may have a small opening (manually controlled with a wheel or a slider of some sort) that connects those drawers to the freezer side, thus explaining how those areas are still functioning as expected.
Jul 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge fridge GSS25LFGww, fridge part freezing food
Hi, Change the controls back to normal settings. Make sure the freezer is getting 0 to 5 above. If the freezer is getting cold enough, try and turn the cold control to 1 and see if the refrigerator shuts off. It sounds like the cold control in not working properly and will need to be replaced. NOTE: The freezer temp has to be right temp or the fresh food side will not work proper.
I hope this helps. Please let me know if I can assist you further.
Vic
May 30, 2009 | GE GSS25JFM Side by Side Refrigerator
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
