Furnace 435fxr pilot wont stay lit. As soon as I release the button pilot goes out doesn't matter how long I push the button.
  • Heating & Co... Master
  • 2,900 Answers
Clean pilot and change thermocouple .
Posted on Dec 05, 2016
SOURCE: Unable To Keep Pilot Light Lit!
I have a Williams top vent gravity wall furnace (model 5009622) and I had the same problem. I had to take the cover off the furnace -- screw on top and two at the bottom (open the access door and there is one screw on each side) to get to the reset button for the vent safety shutoff system. On my furnace it's on the left side toward the top of the unit. I pressed the little red reset button and it's been working ever since. If your furnace is properly installed and doesn't have bird's nest in the chimney, it should work fine. Good luck!
Posted on Dec 06, 2007
  • 108 Answers
SOURCE: pilot light wont stay lit
You need to replace the pilot safety switch which is usually a Thermocouple. It is connected by a thin tube from the gas valve to a bulb near the pilot burner. It should be available at Home Depot or online.
Ray
Posted on Dec 17, 2008
johnsonr1
  • 91 Answers
SOURCE: The pilot light will not stay lit to light the heater.
The power pile (pilot generator) is defective. It produces a milivolt signal to ensure to keep the gas valve open. If it goes bad, the valve thinks the pilot is out, even when you are holding the button down, so when you release the button, it shuts the gas off to prevent excess gas buildup and a possible explosion.
Posted on Sep 12, 2009
james3751
  • 614 Answers
SOURCE: pilot wont stay lit on my furnace
Bad thermocouple. you can get these at a hardware store. easy to replace rus
Posted on Oct 04, 2009
  • 8404 Answers
SOURCE: i have a older Miller furnace(1989)the pilot will stay lit
Replace the thermocouple.
Try this, do you have a butaine stick lighter? Try to heat the thermocouple with it ... see if you can get the main burner to come on. If not - definitely, replace the thermocouple.
Thanks for your question.
Posted on Jan 04, 2010
Oven lights but then flame goes out as soon as I release the knob
The flame sensor seems to be bad.
When I light my pilot light, it stays on till I release the button ...
askville.amazon.com > Home > Home Improvement
Mar 18, 2008 - Similar Questions: light pilot stays till release button suggestions ... If you have held it for a long time and it still won't stay lit, then your thermocouple is bad.... the gas valve doesn't think a flame is burning the gas coming out of the pilot ... less likely but somewhat common is the gasvalve... if the knob you are ...
Troubleshooting Gas Range and Oven Problems ' Back ...
blog.etundra.com > Tundra's Tech Talk
Dec 15, 2015 | Fisher Paykel Fisher & Paykel 24-in...
My pilot light will not stay lit. It lights and stays lit as long as I have the knob pushed in. As soon as I release the knob, the pilot goes out. The heater hasn't been used for at least 2 years.
The thermocoupler is shot. Its the little probe the flame keeps warm. It supplies .3V to the gas valve to keep the gas flowing. when you get one it would be a good idea to get two and leave one in the furnace compartment as a spare. remove the old one and measure the length of it as they come in different lengths. its ok if it is longer. I sometimes prefer a longer one because it makes it easier to install
Jan 06, 2015 | Heating & Cooling
My heat won't come on.
Newer furnaces do not have a pilot light. If yours does, you will have to relight it. Find the gas valve inside the furnace and follow the lighting directions. Generally, you turn the valve to the pilot position, press a button and hold it while you light the pilot. Hold it for about a minute and then release. If the pilot stays lit, then you can go ahead and set the thermostat to call for heat. If it does not stay lit, or the furnace still will not light, I think you need to call a repairmen or someone with knowledge of how to troubleshoot the problem.
Mar 21, 2014 | Heating & Cooling
Pilot wont stay lit when i release push down button on gas valve
Are you certain you are connecting the generator to the correct terminals? Is the pilot head partially blocked not allowing the flame to reach the generator even though the pilot is lit? Can you read the millivolts on the generator leads? Is the reading 400mV or higher? I assume it will be with a new generator but if it is not then the flame is not across the generator as it should be. If it is, be certain you are connecting the two leads properly and in the correct order. The generator has polarity so it needs to be connected to the valve properly. The tag up inside the heater should give you the correct locations for the white and red wires on the valve.
May 29, 2010 | Hayward 150000 BTU Millivolt Natural Gas...
Pilot wont light
If the pilot light goes out when you release the primer,then the thermocouple is bad.You can try to adjust the thermocouple,if it can be.It needs to be in the pilot flame.If the thermocouple is not in the flame,it will not stay lit.If you can not get the pilot to light at all,with the primer pushed down,then replace the regulator.To light the pilot light,you need to turn the dial to pilot.Then press the primer button down and hold it.The primer is either built into the turn knob,or it is a res button.Hold the primer down,and light the pilot,continue holding the primer down for at least 40 seconds.Then release the primer slowly,and if the pilot light starts to get weak,and try to go out,then push back down,and hold 30 seconds more.After the pilot stays lit,turn the knob to furnace or low,or whatever the directions say.
Oct 19, 2009 | Heating & Cooling
Pilot wont stay lit on my furnace
Oct 04, 2009 | Heating & Cooling
Sep 10, 2009 | Coleman (5040B750) Patio Heater
Pilot will not stay lit after button release
most likely you have a thermopile that has low output. it takes about 100mv to maintain pilot light
Jun 24, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Mar 04, 2007 | Williams 2509612 Ceramic Mid-Size Heater
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
