Question about Cell Phones
My touch screen feature does not work on my xdvdn9131 and it will not calibrate either.
  • 5 Answers
SOURCE: Avic-N1 touch screen calibration...
1. Take disc out. 2. Press and hold eject and push the reset button. (don't release the eject button 'till screen closes and opens again. 3. Sceen will ask you to push reset.(don't) 4. With right knob... up,up,down,down,push 5. Perform steeps 1,2,3,and 4 only: The first outlines the screen The second has you push hash marks The third verifys The fourth Saves 6. Use "Band" buton for "back" 7. Press reset Be carefull......
Posted on Sep 10, 2007
  • 4 Answers
SOURCE: Iphone touch-screen
Solution i tried on Unlocked 1.1.3 and 1.1.4 versions. Just follow the steps they have been explained really easy way. Dont think this is too hard. Just follow them it will work:
1) download WinSCP on your PC (google it) and run the application
2) download new general.plist file on laptop
3) download OpenSSH on your iphone (its not show on iphone but its there so dont worry)
4) connect the laptop and iphone through the same wireless network and both will have separate ipaddress.
5) write the ipaddress from the iphone (Settings>Wifi>network details to which you are connected to shows you the ipaddress)
6) Goto laptop on WinSCP type the ipaddress of the iphone in host name field and username:root and password: alpine and then hit Login.
7) it will open like an explorer view of your iphone files on laptop then click on root left side. Click Applications> preferences> replace the general.plist file with the one you downloaded. Done the major part.
8) unplug iphone click Settings> General>Touch and reduce the senstivity to 0. 0 gives you the highest touch sensitivity.
9) Now be happy it works....
Posted on Aug 13, 2008
SOURCE: Screen Calibration problem with SteetPilot c330
Turn off the unit. Then hold down the power button for about 1 minute and the calibration screen will eventually come up.
Posted on Oct 13, 2008
  • 7 Answers
SOURCE: Sony DCR-HC18e Touch screen stopped
The problem you have on your Handycam is the flex cable FP-835.
You have to open the camera and change the cable.
It´s very easy to change.
Posted on Nov 19, 2009
SOURCE: touch calibration not working
i got the lg xenon for christmas.. and everytime you turn it off and power it back on you have to do the touch calibration and you do it once exaclty in the center of the cross and then any other time it asks just put dots randomly anywere and when it says save press no .. so you will have the first good calibration saved (:
Posted on Jan 01, 2010
My arcos no working teh touch screen so bad because for example u press a dive k d q etc
I believe you are trying to say that your touch screen isn't working. Your touch screen is probably locked. Its similar to a button hold lock, when this is activated, you can't press any buttons do anything unless you unlock it. To unlock the touch screen, press the ON/OFF button (don't hold the button for a long period of time. A message will appear on your screen asking for your conformation (approval) to perform the task. If that doesn't work, tap the TOOLS option, then select SETTINGS, and choose SCREEN. Once you've done that, choose the "Touch Screen Calibration" button and follow on-screen instructions given. If the second solution doesn't work, the "Touch Screen Calibration" option can be forced by using a feature called 'System Recovery'. To do a system recovery, Press and hold the Power button, then the Volume + button as soon as possible until you see a white screen, as system recovery is beginning. While this is happening, you will not be able to use the touchscreen to navigate between items. In order to navigate between items, you will have to use the Volume + & Volume - buttons and use the Power button to validate your selected task. The system recovery feature gives you a lot of options. Select the "Touch Screen Calibration" option and follow on-screen instructions given. I hope this activates your touch screen again.
Mar 22, 2011 | Archos 7 Digital Media Player
Touch screen not working
Try to remove the battery and insert it back into your gps device and turn it on. If the screen does not still work, then you need to reset the nuvi, by holding down the power button for about 15 seconds, then the unit will restart, that way the touch screen should respond. If it still does not work, then you need to calibrate the screen to get it to work. To calibrate the screen, follow the sreps below:
  1. Turn off your nuvi,
  2. Press your finger on the upper left corner of the touch screen,
  3. While holding your finger on the touch screen, turn on the nuvi,
  4. Continue to hold your finger on the screen for about 30 seconds until the calibration screen appears (white screen with touch dot),
  5. Then follow the on screen instructions.
It might not work trying it once, so you have to try it over time till it works. Calibration is the last resort of all solutions, so if calibrating it does not do the work, then it means it a an internal problem.
Dec 25, 2010 | Garmin nuvi 650 GPS Receiver
I have an eclipse tch428/828 and tried to use the features on this media player and frozen and the camera mold plse relpy asap denver158@gmail.com
i just got an eclipse tch 428/828 on 7/14/2011 and it want even come on whats the problem here...... not so happyn
Dec 03, 2010 | Audio Players & Recorders
My VUs screen is non responsive or enters a different key when one is pushed. how can i callibrate the phone
Touch Screen Settings
1. Tap Menu , Settings , then Touch Settings to
adjust the touch screen’s sound and vibration.
2. If the touch screen is not responding as you expect,
calibrate the screen for touch accuracy.
If this does not work the phone has a restore feature, but you would have to back up everything you put on the phone so you don't lose it.
In the menu there is a master reset.
If this does not work contact the company and see how to send in for repair.
There is no software update for this phone at the moment.
Feb 10, 2010 | LG Vu CU920 Cellular Phone
MP3 Touch screen is stuck . Can't configure
if the touch screen feature is not working, and you cant navigate to the calibrate screen, push the off switch but release right away, so it dont turn off, it will bring up the calibrate operation, its a default to access the calibrate when you cant navigate the screens.
Dec 29, 2009 | Sylvania SMPK8854 Digital Media Player
Touchscreen wont work
touch screen wont work,
what is it doing ?
Aug 14, 2009 | Sylvania SMPK8854 Digital Media Player
Touch screen
try to calibrate the touchscreen. if it still does not work you need a new touchscreen.
www.fixphonenow.com can replace the touchscreen for $55.
thanks,
Oct 15, 2008 | Cingular Wireless 8125 Smartphone
Nov 30, 2007 | Garmin StreetPilot C330 GPS Receiver
Aug 07, 2007 | Pioneer AVIC-N1 Car DVD Player
Cell Phones Logo
47 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
