Picture and sound. freezes - Televison & Video
The picture freezes
It sounds that the main digital processor board has the fault. Normally this board has no repair other than replacement. After replacement, it will be necessary to update the firmware too. Contact any service technician, and make sure about the fault. If you're sound in electronics, check the link given here. It might help you. Pull up older posts there by its left sidebar.
Jun 14, 2013 | Panasonic TH-42PX75U 42 in. Plasma...
Picture freezing
change the t.con board of yu tv
Apr 17, 2013 | Coby LEDTV1926 19 in. TV
Hitachi 42" picture freezing
Digital processor board should be checked. It sounds to be a memory chip problem.
Apr 17, 2012 | Hitachi Televison & Video
Picture and sound problem
If your getting your signal via a satelite receiver or HD cable box, its likely that the sound dropouts and picture freeze are the result of marginal signal strength. Does the TV ever do this when using a DVD player? If not, its certainly the quality of the signal.
If the TV is at fault, the problem will be on the digital board.
Feb 07, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung HLR6167 - picture freezes
This is very common in Samsung DLPs. The DMD board is going bad. You will need to replace it.
Jan 07, 2008 | Samsung HL-R6167W 61" HDTV
I have the same problem... It turns B&W
I can still hear the sound... however I can still turn the tv off when that happens
Aug 28, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
