I can't find info about model # WA37T26G to install control and display boards confused
  • Washing Mach... Master
  • 10,028 Answers
How do you replace the fuse on the control board
The fuse on the CCU control board cannot be replaced.
Unless you would have a fuse that blew from age, replacing would not solve the reason why the fuse blew. A new one could equally blow when you start the machine.
May 17, 2014 | Fisher and Paykel Washing Machines
My machine wont power on. I checked the outlet and it is fine.
you have blown the fuse on the main board. you will need to check short circuits in your pump and motor, and for leaks onto any electrics, and then replace the motor control board (or try to replace fuse on board if other components look fine ie no burn marks)
Oct 06, 2013 | Fisher and Paykel WA37T26G Top Load Washer
Is there a fuse in the WL80T
Yes a 4amp fuse in the brown motor controller board.
Dec 29, 2012 | Fisher and Paykel WA37T26G Top Load Washer
Hi, I have a fisher and paykel washing machine model #WA37T26G and I noticed yesterday and today that the lights lit on the electronic board was 1,6,7,8...not sure if it was the same yesterday and not sure...
to work out the fault code go from right to left far right light is 1 the next is 2 next is 4 then 8, then 16,32,64,128. add up which lights correspond to your machine and then you can google that code and find what your problem is
Aug 19, 2017 | Fisher and Paykel WA37T26G Top Load Washer
Washing machines got an error 49
is there any issues with the water filling? does it overfill, does the water not turn off and it begins to wash even while water is still pouring in? or fill very slowly like the water just trickles in? because im pretty sure not 100% with your model ive got no info on it but most F+P stuff has the same fault codes, but an error 49 is an issue with either the cold or hot water valve or both you may be lucky and its a dodgy wire come loose but if not and if you know how get a multimeter and measure the resistance of both valves if they check out all good you will need to replace the motor control module
Jan 20, 2011 | Fisher and Paykel WA37T26G Top Load Washer
My oven display panel is 'dinging' me with this message: F2 The previous owners of my house didn't leave the manual. Model # is KEDT105VBL0 Serial # is F93105(7 or 1)44
Hello- The code described- F2 - indicates a fault in one of the switches on the control. This model has the switches on the board with the computer, and must be replaced as a unit. The control is pretty easy to install, but costs over 250$. Wish I had some good news for you. -Bet the previous owners didn't.  Let me know if this info explains situation. Only solution is to replace the control.  Thanks- Ed
Mar 19, 2010 | KitchenAid Kitchen Ranges
Washing Machines Logo
Top Washing Machines Experts
