Question about LG Washing Machines
How many bearings are there in lg wd-1274fb washing maschine ? Is it diffucult to change ?
  • LG Master
  • 2,305 Answers
Most have 2 bearings an d a seal. Pretty difficult. But it can be done. Hardest part is getting bear out of housing and installing new. Taking unit apart is tedious but not particularly hard. Check out YouTube videos.
Posted on Dec 07, 2016
4 Suggested Answers
SOURCE: lg intello wash wd 8013f
The front panel is flasing when i press play
Posted on Sep 16, 2008
  • 901 Answers
SOURCE: LG Intellowasher 7kg, Model WD-8074FHB - noisy spin cycle
You are right!
Bearings have to be replaced. Replace with the same type and design. All the bearings connected to the washer center shaft has to be replaced at the same time with new set.
Replace the water seals also connected to this. Check the shaft where the bearing sits, for any abrasions or metal damage.
Check the bearing housing also. While carrying out these repairs check the drive belt also. If needed replace it.
If you are happy with the machine outer body and other aspects repair it and re-use it.
Posted on Apr 07, 2010
Testimonial: "Thanks for the quick reply Ambari, that's exactly what I wanted to know. Atleast I'll some idea if the repair bloke is pulling a swifty. Cheers"
  • 6277 Answers
SOURCE: My LG washing machine (Inverter 7KG WD-1274FB) has
Have you been able to test/see if the pump actually is free? Before considering a new one I would strongly advise doing so.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 04, 2011
Lg intellowasher wd-8013f is very noisy
it will definitely be the bearings and possibly the spider as well. the spider is attached to the bowl. the spider is made of aluminum and they corrode all the time. open the door to the machine and grab hold of the steel bowl, has it got movement on it. if it has then the spider and bearings are faulty, also the main shaft seal will need replacing.nearly every time i went to an LG 8013f that was noisy it was the bearings and or spider. hope this helps. please reply 4 more help. good luck.
May 09, 2010 | Washing Machines
You suspect right.
It is a complete strip down job. I have just finished mine.
taking apart and reassembling is not too dificult.but you need to make up a tool to remove and replace the bearings which are two different sizes. It consists of a lenghth of studding, bolts and washers.
Download the manual from LG.
Good Luck
Mar 17, 2010 | Washing Machines
My lg wm 14225fd is making a banging popping
this sonde like the drum needs to be rebalenced this needs to be done once a yr. you well need to call a repair person its covered under your warrenty.
Dec 22, 2009 | Washing Machines
Makes helluva noise when going into final spindry cycle
I would check the large pulley on the back for wooblyness(is that a if so replace pulley.:)
Jun 13, 2009 | LG WD-16115FD Front Load Washer
LG WD-1049C Front Load Washing Machine Pump impeller sloppy
probably better change the pump if you feel any up and down slack in the impellor. you may have an ingress of water through the seal.
Mar 13, 2009 | LG WD-1045FH Front Load Washer
The problem is with the door rubber of my beeb washing machine model wm1510w. my dog managed to pull the door rubber and the wire that holds the rubber in place off the machine and i havent been able to...
how to insert the new part of the door it s rubber of the LG WASCHING MASCHINE TYPE MODEL WD-8016( 0-9) T( U ) P
Oct 16, 2008 | Washing Machines
7 kg intellowasher noise when in wash cycle
if its a direct drive remove the rotor and see if theres a loose magnet etc,hope this helps
Feb 21, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
41 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
