Question about Comstock-Castle 2616HG Deep Fryer
What do I need to do to switch over from natural to LP gas?
    Scholar:
  • 81 Answers
You will need the following Castle part #s
17003A- Pilot head assy LP gas @ $49.
17006L-Convertible Press Regulator LP gas @$29.
Give Castle Stove a call @ 800-637-9188 to make sure that is all that you will need. They were the only two parts I found on there website (www.castlestove.con) under your model # for LP gas conversion. There might be a need for a conversion kit for the gas valve.
captrick
Posted on Jul 29, 2009
Tip
Changing your gas appliance from natural gas to LP or vice versa.
You have an LP gas stove which you really like and would like to take to a new home but the new home has a natural gas hookup. Since natural gas is already available it would be convenient to be able to use it. Can you convert your unit over to work on natural gas?
Yes it is possible to convert any LP gas appliance to natural gas or from natural gas to LP. The only difference is the size of the orifice used in the burner.
LP gas is composed of a much larger molecule than natural gas and requires a larger orifice to output the same amount of gas as a natural gas unit at the same setting. Therefore if you used an LP stove on natural gas it would produce too much heat and burn rather intensely. If you used a natural gas stove on LP it would not have much flame at all. You can see the problem. The solution is also obvious. You need the correct orifice.
Changing the orifice is easy. It is located in the middle of the burner and unscrews out of the unit. Install the new one the opposite way. Do not overtighten it.Usually the burners are made of soft metal and can strip easily.
The parts you would need are available at most good appliance stores but I would recommend the following site http://www.repairclinic.com . The parts will be cheaper at repairclinic. They have parts for almost any brand and a great search engine. They also have excellent videos showing how to make the repair.
Thanks for using FixYa and for the great rating.
hardrocko
on Dec 10, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
How do I change from LP gas to Natural gas? Does this unit have a switch for that?
There is usually an orifice change that needs to be made to switch from LP to LNG. For safety's sake, you MUST contact the manufacturer for the procedure for your specific device.
Oct 22, 2014 | Pool & Spa
How do I convert from liquid propane to natural gas
You need parts from the manufacturer. The gas orifices are different sizes between natural gas and LP gas. If you try natural gas with an LP gas orifice, you will not get much flame. If you use LP gas with a natural gas orifice, you will burn off your eyebrows and possibly other things.
Dec 19, 2013 | Capital Cooking Titanium X CCE26XRBI (NG)...
Can i switch a model RN30 from natural gas to propane?
Only the portable heaters that are manufactured to be used on dual fuel (nat gas/propane) can switch from one to another. If they are made for 1 type of gas only, they are not field serviceable and cannot be converted. Douglas
Sep 30, 2010 | Reddy Heater-30-55,000 BTU Variable
Gas stove need to switch to propane
Hotpoint supplies the orifices and instructions with each range for converting. It is just that it is hidden, they attach it to the gas regulator. The regulator is near the bottom back typically. Here is a cut out from your use and care manual.
CONVERTING TO LP GAS (or converting
back to natural gas from LP)
This range leaves the factory set for use with natural
gas. If you want to convert to LP gas, the conversion
must be performed by a qualified LP gas installer.
The conversion instructions and LP orifices can be found
attached to the range next to the pressure regulator.
Keep these instructions and the orifices in case you want
to convert back to natural gas.
May 13, 2010 | Hotpoint RGB745 Gas Kitchen Range
Switching from natural gas to lp gas
Get in contact with the appliance manfacter, ask them for a conversion kit and if it can be done they will send you out all you need. Obviously there will be a charge.
Jun 02, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Change Natural Gas Model of rinnai Heater to LP model
You can change the dip switches, but you may also need to work on the gas valve
Nov 12, 2008 | Hotpoint RGB528 Gas Kitchen Range
Switching from natural to lp gas
Hi, The gas jet is too large and the gas valve needs adapted for lp gas. Lp gas has more pressure so the jets are smaller. Any appliance parts store should have the kit needed to adapt the gas valve along with the jet. The valve pressure will also need to be adjusted using a cheap water column gage also available at the appliance parts store. Check with them on what the pressure needs to be in your area. If the regulator is part of the lp it should be set right. If it is part of the fryer, set up for natural gas, and there is no lp regulator, it will need to be adjusted and or replaced with an lp regulator. Gas companies are usually very helpful with such things because they are concerned about gas safety. Good luck.
Sep 23, 2006 | Cecilware GF-28 Deep Fryer
Comstock-Castle 2616HG Deep Fryer Logo
217 people viewed this question
Top Comstock-Castle Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Comstock-Castle Kitchen Appliances - Other Expert? Answer questions, earn points and help others
