Question about Whirlpool Washing Machines
I have a Whirlpool estate washer...it fills, agitates..but the spin cycle does not work. The timer has been sounding kind of odd the last couple of weeks. Could this be my problem?
I have the same problem with my whirlpool washer. It is five years old! I was told it was the basket drive and transmission that is going. It will cost $275 to fix. Paid $379 for it. What a piece of ****! Will never buy whirlpool again. It was my 1st one. I had always bought GE prior.
Posted on Aug 03, 2009
Estate washer will fill up but want drain spin, or agitate
sounds like pump is working but not transmission... check under washer for plastic shavings, lovejoy coupling might have disentergrated, VERY cheap fix if done yourself.
Apr 16, 2012 | Whirlpool Kitchen Appliances - Others
Our older top loading Whirlpool washer skips FILL
It sounds like you have a timer going bad.
Mar 06, 2010 | Washing Machines
My Estate Whirlpool Washer, model #TAWS850PQ0 fills the tub but does nothing else. It does not agitate or spin, just hums.
if it cuts off the water ok and motor running
it could be a coupling .
possible transmission.
if no motor noise
could be motor .
wiring,
timer.
Jun 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Will not agitate
Replace the direct drive coupling. Directions are in the attached video.
Apr 03, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Roper RAL6245AW0 Washer Won't Drain or Spin
We have a Kelvinator Washing Machine that just won't drain , but fills , agitates , & spins just fine. What shall we do?
Oct 13, 2008 | Washing Machines
Estate by Whirlpool washing machine will not drain or go into spin mode in any cycle.
I would try and check voltage at the overload on the motor
when in spin cycle and see if you have power there..
 that should tell ya if your at least getting power from the timmer or not in the spin cycle to the motor
Sep 04, 2007 | Admiral AW22 Top Load Washer
Washer clothes
Does the washer fill normally and just stop? Or, does the washer fill, go through a complete cycle, and just won't drain? There could be a couple of problems that cause a no drain issue. 1. FILL NORMALLY & STOPS, WILL NOT SPIN - This is usually a bad lid switch. If you open and close the lid, you should hear a "click", indicating the switch is working. 2. FILL NORMALLY, AGITATES, WILL NOT DRAIN - This could be a clogged drain pump, pinched hose, clogged rain line. Also, you need to make sure timer is advancing properly. If the timer never advances, the washer will fill, but won't go into agitate or spin. Let me know if this is helpful.
Aug 09, 2007 | Whirlpool LSR5132J Top Load Washer
Washing Machines Logo
91 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
