Question about Plumbing
The sprayer hose will not pull out or retract in certain positions, especially to the side. (Moen 87017 Chrome Pullout Spray Kitchen Faucet)
    Top Expert:
  • 41,738 Answers
It may be getting tangled underneath
Posted on Dec 05, 2016
Testimonial: "Tom, i've checked that and it has clearance under sink, doesn't catch on any other plumbing. it seems to be stuck in the space between where the hose enters the cabinet (under the sink) and where it exits into the pull out faucet. I'm not sure how to get in there if something needs to be tightened."
Replacing Sprayer on Kitchen Sink?
Should be able to purchase sprayer head only at any store that sells taps and hardware to go with them. I got a replacement at a plumbing store in Chatham Ontario.
Feb 09, 2015 | Moen 7310 Legend Single-Handle Kitchen...
How can you remove a 7560w spray head?
  • Take out the plug button on the front side of the faucet handle and loosen the set screw with your Allen wrench, then pull off the handle. Remove the domed cap underneath the handle by unscrewing it.
  • Take off the entire spout by removing the mounting hardware under the base and lifting the spout up and off the faucet. The hose will be attached underneath the counter. Once you unscrew the connector, the spray head can be removed.
Sep 09, 2014 | Moen 7560W Extensa Glacier Lever Handle...
I have a ca87629csl two handle kitchen faucet with a side spray and I have extremely low water pressure coming out the faucet even with the screen taken out. I think or know that debris in the line has...
If the faucet is plugged AND the sprayer also seems to be plugged, the problem is probably in the diverter valve that controls the water going to the faucet and sprayer, see URL link below. Need to find a way to clear the valve, most likely by removing the faucet neck and cleaning and the reassembling. Prior to doing that I would remove the hose connection and try blowing back through the faucet to see if you can get something out of it.
http://www.moen.com/shared/pdf/ca87621pt.pdf
Please contact me if this does not work. More things you can do, but they are pretty drastic.
Paul
Sep 18, 2010 | Moen 7905 Castleby Two-Handle Kitchen...
Moen kitchen sink faucet side sprayer is stuck on
We had this same problem. We twisted off the sprayer cap to access the diverter valve under the trigger. The nylon diverter was stuck down into the cavity and was not popping out when the trigger was released. We pushed it down several times with needle nosed pliers to release it then applied a drop of household oil lubricant with the valve pushed all the way in. Then pushed and released several times to work the lubricant around the sides of the valve. After re-assembly, the sprayer seems to work perfectly again.
May 29, 2010 | Moen 7840 Camerist Single-Handle Kitchen...
I have a Moen kitchen faucet with a leak.
By "leak in the stem" I assume you mean you're getting water in the cabinet below the faucet. High likelihood is it's the hose - either loose where it connects to the faucet or the sprayer. You can pull it out and check to be sure it's tight at the sprayer. To check the faucet end, you'll need to be under the cabinet with a light. If you don't find one of those connections loose, it's likely one or the other is leaking, due to a hose defect or washer (or missing washer).
The only way to see that is to turn the faucet on full (cold) with the sprayer pulled out and look for a leak in the hose behind the sprayer. If not there, leave the water running (may need another person to hold the sprayer) and inspect under the cabinet with your light for a leak either in the hose or at the connection to the faucet. If the problem is the hose or one of the nuts, it's an easy deal to buy a replacement hose - Home Depot stocks Moen.
Feb 02, 2018 | Moen Plumbing
The waterline came loose from my the pullout sprayer and fell into faucet housing and i can t push it pack through the housing so I can reconnect it.
most of these sprayers have a compression fitting
for attaching if it gets bent or twisted you must
replace with new fittings or new sprayer
Oct 31, 2009 | Moen 7437 Chateau Single Hole Kitchen...
Kitchen faucet leaking pull down sprayer spout type
try tightening the nut that attaches the flex line to the pull out spout
May 04, 2009 | Price Pfister J103-BC 100 Series Kitchen...
Plumbing Logo
240 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
