A tv with multiple thin lines passing through it is a crt tube tv the video has a shade next to picture
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result will display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Posted on Dec 06, 2016
techman
  • 3130 Answers
SOURCE: Thin horizontal line across picture
I really dont understand the problem Could we see a picture of this please?
Posted on Jun 14, 2006
  • 579 Answers
SOURCE: Tube TV - one thin horizontal line of bright light
Vertical defection failure. Common failure. Pretty easy to repair ($50-75?). However, my general rule of thumb is not to waste any more money on TVs over 10 years old. Too much other stuff in there ready to fail as well.
Posted on Jan 24, 2008
  • 4234 Answers
SOURCE: 32" sylvania TV thin line
There are bad solder connections on the vertical IC. This is a small flat IC attached to a heat sink. It should have about 9-11 pins and may be marked LA7837 or something similar. Resolder the pins on this IC and that should resolve the problem.
Dan
Posted on May 07, 2008
bobjrdns
  • 84 Answers
SOURCE: 27" sharp has audio/no picture/ horizontal white line across screen?
bad vertical chip ic
Posted on Oct 19, 2008
bobjrdns
  • 84 Answers
SOURCE: picture tube
no you have no vertical bad chip ic
Posted on Oct 21, 2008
I have a CRT tv and the picture is just a thin band in the centre of the picture tube. The sound is ok
That is called "Frame Collapse" because the picture "Frame" has collapsed into the single horizontal line.
It may be caused by dry joints or output failure of the frame output stage.
A fairly inexpensive repair.
Mar 03, 2011 | Panasonic TC-21PM10RQ 21" TV
Tip
White Raster with thin lines; Sound Ok.
White raster with retrace lines: No picture, Sound OK
(picture tube based telivisions.)
It is a common fault to occur in most of the CRT based telvisions, regardless of which brand it is. There will be sound OK, and a bright screen with thin white horizontal lines across; at about an inch space, all over the screen area. This fault may occur along with colur shades also, like blue screen with white retrace line, red screen with white retrace lines, green screen with white retrace lines. Let us take the first case. A white raster with white thin retrace line acorss the screen. These are call vertcial retrace lines technically. To make it mor understand, we have to go to some picture tube electrode details. There are three colour cathodes for a colour picture tube, Red, Blue and Green. Two girds are there called Focus and Screen. Focus grid is supplied with focus voltage which in turn determine the cocus of picture, and screen grid is supplied with screen volrage which determine the emission of the picture tube; in short. There is a final anode to all the picture tubes, which supplied with Extra High Tension voltage, can be located at the top side of the picture tube, to which the EHT voltage from LOT is connected with the help of rubber ****** and clip. Without these three voltages, EHT, Screen and Fcous, no raster will be produced. Therefore in our case, there is a raster, so, horizontal output section including Line Output Transformer [LOT] is functioning well, and as far as sound is there, tuner and video IF section are working well. In fact, all other section except, video output section is working properly.
There are three cathode points on the base card, marked as Bk, Rk and Gk. Check the voltages of these three cathodes. In our case, it will be very low or approximately equal to zero. When cathode voltages goes low, emission of the CRT increases, is the reason. There must be a voltage between 120 and 135VDC at these points. Find out the reason for this voltage drop is the next step. The video drive voltages in most TVs comes from LOT windings, after rectification and filtering. There will be one reisitor of low value, say one Ohms or so, will be connected series with this winding, in between diode and winding. Check the voltage at the cathode of this rectifier diode first. If found low replace the diode and the smoothin capcitor. The smoothing capacitor will be between 33 and 47MFD 250VDC rating. Replace both of them. If there is volatge, say 200VDC or so, check whether this voltage comes to the CRT base board or not, If not, check the conducting wire, serial resistors; if used for open. There is no chance of transistor shortage at this time as the raster we see is white. If raser we see have a specific colour predominent, that is green, blue or red, check the revalent video out transistors and replace it. It is best to replace all the three video output transisors at the same time with same batch and number.
on Apr 18, 2011 | Televison & Video
Philips 60PP9363 colors not right. TV is 5 years old, the convergence appears to be fine in that all of the colors line up fine, but they are not the right shade. The green and blue are both teal, with...
Ur tv look dull in pictures?Ur tv might need it CRT tube coolant replacement.Tries websites like Tvrepairworld.com,Tvrepairkit.com to buy a coolant kit to replaced CRT tube coolant replacement.
Aug 04, 2010 | Philips 60PP9363 60" Rear Projection...
Picture go into a thin line.
You have a thin horizontal line in the center of the TV. You, in this case have vertical IC that has bad grounds. Resolder the vertical IC pins and check the capacitors in the immediate area and replace these caps as necessary. If you still have a horizontal line, you will have to replace the vertical IC. Find a TV tech or someone with electronic experience to do this for you. Should be reasonable to fix. Thanks for asking and Good Luck!
May 30, 2010 | Sanyo AVM-3659S 36" TV
IM A TV TECH. I HAVE A SONY LCD KP-60XBR800 I HAVE NO RASTER. POWER OK, MENU OK BUT NO RASTER ON TUNER, TUNER VOLTS OK,CAN YOU HELP ME PLEASE. THANKS my email sergioaguirre0182@hotmail.com
check the high voltage with the screen control turned up high where there is no raster. suspect problem within the video circuit where there is no high voltage or defective picture tube.some time when the screen is black and the screen control advanced,you can see if the tv has video or vertical or horizontal problems on the screen.service the high voltage circuit if there is no raster or high voltage is seen.no raster can be caused by the no heater or filament in the CRT.---- a defective picture tube can cause many problems, such as, poor brightness ,missing colors,intermittent picture,poor focus,a single-colored raster,arching in the gun assembly,retrace lines in the picture,negative picture,chassis shutdown,noheater or filament lit and no raster to name a few.an open filament or heater can cause no picture or no raster symptom.a defective CRT can have an extremely bright screen.loose particles of the cathode element can lodge between the grids and cause an intermittent black and white picture. simply tap the ends of the CRT gun assembly and notice if the picture begins to flash off and on.---- with a leaky picture tube after turn on the raster dims and get extremely bright.a dim picture with no green in the raster can result from a bad green assembly. a heater-to-cathode short can cause a raster to change colour or a result in no raster at all.replace the picture tube if there is severe arching in the neck of CRT. excessive brightness with retrace lines and a vertical collapse to a thin line can be caused by a bad coil on the neck board of the picture tube.rejuvenate the picture tube when there is very bright green screen. check for the resistance change on the resistors of the CRT neck board for an excessively bright picture with retrace lines.excessive dust inside the CRT spark gaps within the picture tube socket can cause the very bright raster and the chassis shutdown.a defective video amp,luminance buffer,or reference transistor can cause a bright picture with retrace lines. -------- for getting any required parts to replace you can get it from www.radioshack.com or from www.partstore.com or from www.shopjimmy.com --------- thanks.please do rate the solution.thank you for using fixya.keep updated.
Sep 06, 2009 | Televison & Video
2002 27" SONY Trinitron. Half-screen picture with bright line.
Ur video board have burn capacitor,check the board connect to the CRT board connected to the tv tube.
Aug 02, 2009 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Turn on pic turns red with thin bright red horizontal lines
Sorry to say, but that's usually the sign of a bad picture tube. One of the elements inside the tube shorts and you see the picture you describe, and the set shuts down due to high voltages getting to places it shouldn't. There's no solution except picture tube replacement, and that is uneconomical. You're better off replacing the TV when the tube goes bad.
Mar 31, 2009 | Toshiba Televison & Video
A bright thin white line, side to side.
You need to replace the vertical IC and all the dry capacitors near to him.Good luck
Jul 06, 2008 | Sylvania 202SL8 TV
Black screen with green smiley face
If your tv has a picture tube,your problem is in it. If you have only one line now,the vertical circuit is not working. You could have jarred something loose around the picture tube.Maybe a yoke lead ???
Jan 13, 2007 | Mitsubishi VS-60607 TV
Some part of TV has been fused causing no picture on screen , only bright green horizontal lines , not even video channel could be set ,cannot see menu on screen please help by specifying possible...
if the screen is real bright green with thin small white lines in it its probably a shorted picture tube. Or a shorted Green driver Transistor. Good Luck
Apr 12, 2006 | Thomson 14MG135 14" TV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
