Which HDMI port do I use to connect my Element eleft326 to laptop or pc? And other than switch source to match port, is there something else I should be doing?
    Top Expert:
  • Computers & ... Master
  • 8,303 Answers
Posted on Dec 05, 2016
Testimonial: "(chuckling) I deserved that. I personally do not respond to anonymous inquiries, and here I did the same.Link wasn't helpful, but as it turned out, I was asking the wrong question. Thanks for responding. You are appreciated."
  • NOEL
    NOEL Dec 06, 2016
    lol, you are welcome.
Why does screen say no media device when I have iPad connected to usb port of ELEFT326 TV
USB on that TV is for a USB flash.
Page 11 in the manual says:
Insert the USB flash drive into the USB port, select USB channel source via the SOURCE button.
It doesn't say what it will read off a flash drive though.
Sep 05, 2016 | Televison & Video
How to connect an apex led 24 FLAT PANEL to Dell Inspiron lap top TO FUNCTION AS MY COMPUTER SCREEN?
your laptop would have either a HDMI port or a VGA PORT on the Flat panel it might have a HDMI input or a vga input port. Search on the model numbers of these devices and find the user manuals. MY laptop uses Function (FN) with F4 key to switch the output to either extra screen only , Dual screens, ect. THen you would selectg the input source on the flat screen that matches with the type of output and input port you used.
Nov 02, 2014 | Apex Digital Apex Power Supply SL-8600EPS...
I want to connect my Hp i5 laptop to sanyo LCD via HDMI please help me
all you have to do is plug it into a HDMI port switch the TV source to that HDMI port and plug it into your laptop. It may not work until you hit the FN key and the F4 key (at the same time). the FN+F4 key switches between laptop screen and your other source (TV in this case) and you should be able to choose to use both at the same time
Dec 14, 2013 | Computers & Internet
Connect acer to smart Toshiba tv
If your laptop has a HDMI port, all you need is a HDMI cable. Plug one end into your laptop, plug the other end into a HDMI port on your TV, and then change the input setting on the TV to match which port you plugged your laptop into. Easy Peesy!
Dec 04, 2013 | Computers & Internet
Element tv wont see laptop
Connecting laptop VGA port to HDMI port on a TV
VGA to HDMI converter is required to connect a laptop to a TV with HDMI input. The VGA signal does not have an audio component. You need to connect an audio cable from the audio/headphone port on your laptop to the audio connector on your TV. There are HDMI converters with Audio input so you do not need to connect an audio cable to the TV. The audio is connected to the HDMI converter and then passes the audio with the video data to the HDMI cable to HDMI port on the TV. Check out these WEB site for these HDMI converters. http://www.aten.com/products/productItem.php?model_no=vc180 http://www.sybausa.com/productInfo.php?iid=1174 http://www.topbuy.com.au/tbcart/pc/Audio-VGA-to-HDMI-Video-Converter-Box-HD-HDTV1080P-p164633.htm
Mar 14, 2013 | HP Pavilion Computers & Internet
PS3 Connection problem with this particular tv model.
connect PS3 to Tv with RCA cables (white,red,yellow) go to display settings change to HDMI, Tv should go black remove RCA cables and connect with HDMI.
Jan 10, 2018 | Samsung LE22B450 22 in. HD-Ready LCD TV
Can i hookup theis computer to my tv using a hdmi cable?
Yes, your notebook comes with an HDMI port. You will need an HDMI cable to connect to the TV (usually LCD TVs come with an HDMI port). After the connection has been made, change the source in the TV by clicking the "Source" button on the remote. It usually changes in the following sequence - AV1, AV2, HDMI.
Jun 25, 2011 | HP Compaq Presario CQ50-103NR Notebook PC
I try to connect my pc with my tv with an hdmi cable 2m but my tv can't read it,so when i turn my tv channel to the hdmi port(tv) which i have connect the cable the screen of the tv is blank.in other words...
Once you made all the proper connection, meaning the hdmi cable from your laptop to your tv, and tunning your laptop to the right hdmi port (like hdmi side, rear1 or 2 however many hdmi input your tv has). Then I believe on acer model, you need to press the FN button and the F5 button at the same time that switches your external video source, Leave the Fn button press and then slowly press the f5 button key until your screen is display on the monitor HDMI. Like said earlier, you need to make sure the tv is tuned to the correct HDMI port.
Jan 30, 2011 | Computers & Internet
I cant find a port in which i can connect the tv cable into my acer laptop 5920
The Acer 5920 comes with two options to connect and display the desktop onto a TV.
The First Option is the HDMI port which you can identify by looking here http://en.wikipedia.org/wiki/HDMI
The HDMI cables cost around $14 - $20 at Target or Walmart
You must ensure that yourTV has an HDMI port or you will not be able to connect to it.
Also, the regular 5920 does not have an HDMI port, but the 5920G does, so check your model on the bottom of your laptop to be sure.
The second option is S-video, you can see that here http://en.wikipedia.org/wiki/S-Video
Cables are retaltively cheap, but be sure to check the connections to ensure the pins match the port.
Apr 21, 2010 | Acer Aspire 5920-6727 Notebook
What cable do I need to connect latitude D600 to a hdtv ?
The first step is to inspect both your laptop and TV and identify the connections, easily located on the back of either component. There are five basic types of jacks, or ports involved:
*Composite/phono plug (RCA)
*S-Video
*Video graphics array (VGA)
*Digital video interface (DVI)
*High-definition multimedia interface (HDMI)
*An RCA connector, sometimes called a phono connector, is used for analog audio and video components. Three round, colored sockets are standard — left audio is white, right audio is red, and composite video is yellow. These are standard jacks on older TV’s and laptops. A three-prong cable, readily available at any computer or electronics, is the easiest way to make an RCA laptop to TV connection.
*S-Video, or Super-Video, a more advanced analog video connector, uses a four-prong round plug, like those used in TV cable installations. Separate audio cables are the same as for the RCA connector, left audio/white, and right audio/red. S-Video is commonly found on older TV sets and some laptops.
With S-Video on both TV and laptop, connecting a laptop to a TV is a simple matter of a single S-Video cable. If your laptop has a great sound system, you won’t need audio cables, but for better quality you’ll also want audio cables.
RCA to S-Video cable, a special laptop to TV cable, is available when you have RCA jacks on one device and an S-Video port on the other.
*A VGA connector and cable are used to carry analog video signals plus display and graphics data. The VGA is a 15-pin connector commonly found on laptops and other devices. With this port you need a PC-to-TV Convertor to connect laptop to TV. You simply plug the VGA cable from the source into the convertor, and use an S-Video or RCA cable out to the TV. The converter is USB powered, so there’s no external power adapter to carry around, making this laptop to TV connection entirely portable.
*A DVI port is rectangular with 24 pins arranged in three horizontal rows of eight pins for digital video; separate RCA analog audio cables fit into white and red plugs. DVI ports are found on Macintosh laptops; sometimes they are smaller than normal DVI ports and require an adapter, which usually comes with the laptop.
*The HDMI port, one-half the size of the DVI port, is also rectangular with 19 pins. It provides digital audio in addition to digital video, despite it’s smaller size, for a complete TV to laptop connection. These ports are found on new HDTVs, and sometimes there are two or more. TVs with HDMI ports are the only ones that do not require additional audio cables.
TV’s with a single digital port labeled HDMI/DVI require only one cable when the source is another HDMI component. But when source is a DVI laptop, you need a DVI-to-HDMI cable for the video and a separate pair of RCA analog stereo cables.
NOTE: Whenever ports do not match, you can by adaptors and/or cables to make any connection.
Nov 22, 2009 | Dell Latitude D600 Notebook
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
