Question about Lakewood Heating & Cooling
Lakewood heater model 2727 not heating - Lakewood Heating & Cooling
SOURCE: Lakewood 792/JR heater running w/o heat
Hi Spybotics. I have the same problem and I traced mine down to a burned out over-heat fuse link. Check out my recent post. My guess is that you are having the same problem as me. It's not hard to tell - just take off the rear panel and test the link (looks like a small resistor in line with the element) with an ohm meter. Open circuit means burned out fuse link. DO NOT bypass the link, as an extreme fire hazard will exist without it.
Posted on Apr 22, 2007
SOURCE: lakewood 7096 heater
Some of the newer models have a thermal fuse which may be blown. It doesn't look like a normal fuse at all. It is similar to a transistor in looks and should have continuity from one end to the other. It will be tied in to the incoming power cord inside the heater, and may be covered with rubber coating within the wire. It will look different when you notice it. Sometimes its too far down inside where the heat causes it to blow prematurely. The purpose is to cut the power to the unit in case it overheats. You can get one at radio shack for less than a couple of bucks. The older models don't normally have one, but I would suggest you put one in it if that's the case.
Posted on Jan 01, 2008
SOURCE: Lakewood oil filled heater model 5500
Follow up to my post of 13 January. Out of desperation, I took the heater apart and determined that an electrical fuse-like thermal overload device had opened on the neutral side of the feed to the heating element thus rendering the unit non-working. This device is wrapped in a sheath around the underside of the heating element's electrical connections where the element enters the radiator's core. If the element exceeds the rated temperature it apparently "blows" or electrically opens much like a fuse. The lights still come on but no electricity is getting to the element. When I removed this from the circuit, the the unit began making heat. Apparently, when the heater is on full (both switches on for the full 1,500 watts) the core temperature gets too high. So, I now use my heater on only the 900 watt setting and it's putting out plenty of heat. Today's high is 2F and the room is comfortable. I've no doubt the manufacturer would not condone this modification and I have no intention of turning my modified heater back on "HIGH." Therefore I do not recommend doing this yourself unless you are competent in electrical and soldering work and are sure you won't overheat the unit. Having said that Lakewood clearly has either a design flaw or a bad batch of heater elements or overload protectors out there. When I have time, I'm planning to send my defective protector back to them with a letter. But given that they never responded to my e-mail to their customer service don't expect much in the way of a reply. As they say on TV, don't try this at home.
Posted on Jan 31, 2008
SOURCE: Recall
I had the 5101 I just sent it back last week to manufacturer,most of oil filled heaters make a noise as the oil heats up. The 5101 had a black control panel &black wheels & foot rest. Hope i was of some help. If u have more ? let me know.
Posted on Oct 10, 2008
  • 986 Answers
SOURCE: Lakewood Model 7101 - Need to drain the oil to dispose of it
I just drill a hole and I put old oil in my used motor oil
Posted on Jan 13, 2010
I need a thermostat switch for lakewood heater model 798/240
Fixya does not sell thermostat switches for Lakewood heaters.
Nov 23, 2017 | Lakewood Heating & Cooling
Replacement wheel for Lakewood Heater Model 7101
I did the drill think once. but today when trying to repair an old Lakewood 7101, I removed the two screws holding the front cover in place (top and bottom). the cover slides down and out. and underneath I see a large plug that can be unscrewed to drain or fill the heater!
Sep 02, 2012 | Lakewood Heating & Cooling
No heat coming from it
Let's try trouble shooting the situation, and see what clues we have:
Are there any lights lit?-- How do we know for sure, we have power into the unit?
Are there any resets?- or maybe turning the Thermostat all the way to one end of it's travel, or the other, might re-set it?
There must be some clues-- Unplug it, and start from the beginning, and listen, and observe everything for ANY CLUES!
Let us know what you find, and tell us any clues you see or hear.
Mack B.
Jan 17, 2011 | Lakewood 2727 Heater
How do I add oil to help heater warm better??
they are a sealed heater you can't add oil to get more heat, if you can must be a new type i haven't seen, but if not hot enough throw away and buy a heater that works they work on the principal that an element heats the oil and runds on an internal thermostat to control temperature of oil, your element may be starting to deteriate the same as hot water you only notice with hot water as it starts to not heat the water as much and you feel this in a shower or bath but you won't notice the same in oil heater it won't heat as it has and it may also be the thermostat, inside heater i wouldn't even bother trying to repair waste of time and money i would buy a proper working heater prefrably one that could be fixed to go better after its starts to deteriate a lttle
Nov 29, 2010 | Lakewood 2727 Heater
Help! Dog Bit Through Electrical cord on Lakewood 2727. How to replace cord???
another option for you would be to use crimp on terminal connectors(**** connectors) you may purchase these from most hardware stores. Even using these I would still tape around the outside to ensure a good insulating surface.
Apr 28, 2008 | Lakewood 2727 Heater
Jan 26, 2008 | Lakewood 2727 Heater
Model 7096 heater
Concerning Lakewood Model #7096
May cause electric shock!
Nov 20, 2007 | Lakewood Oil-Filled Electric Radiator...
Heating & Cooling Logo
76 people viewed this question
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
