Question about Lands Phones
The base wont press down - Lands Phones
The phone says no phone line, and i dont have a dial tone. cant call out and cant get calls coming in
Model LS6305: How to register a handset:
  1. Place the non-registered handset in the telephone base or charger. If 1.Press FIND HS on base 4sec and 2.Then press # on handset do not appear alternately on the handset screen after a few seconds, remove the handset and place it in the telephone base or charger again.
  2. On the telephone base, press and hold FIND HANDSET for about four seconds until the red IN USE light on the telephone base turns on.
  3. Remove the handset from the telephone base or charger and then press # (pound key). It displays Registering...Please wait. It takes about 60 seconds to complete the registration. The handset displays Handset X Registered and you hear a beep when the registration process completes.
  • If the registration fails, the handset displays Registration failed for a few seconds, then 1.Press FIND HS on base 4sec and 2.Then press # on handset alternately. To reset the handset, remove it from the telephone base or charger and place it back in. Try the registration process again.
Model ip8300: How to register a handset:
  1. Press and hold FIND HANDSET for at least 10 seconds on the telephone base. The VMWI and LINE IN USE lights will blink alternately indicating that the telephone base is in registration mode.
  2. To display the telephone feature menu, press the Menu softkey from the main idle screen.
  3. Press the up, down, left and/or right NavKeys to choose Registration Settings then press the Select softkey or center NavKey/SEL.
  4. Press the up or down NavKey to choose Handset Settings then press the Select softkey or center NavKey/SEL.
  5. Press the up or down NavKey to choose Register to Base then press the Select softkey or center NavKey/SEL. A list of locations for assigning telephone bases will be displayed.
  6. Press the up or down NavKey to choose an empty location and press the Register softkey or center NavKey/SEL.
  7. The handset will display Searching while it searches for the telephone base. If the search is successful, a code from the telephone base will be displayed. To register the handset to the telephone base, press the Register softkey.
  8. In the Enter PIN box, enter the system PIN. The default PIN is 0000. Press the Apply softkey.
  9. Handset registered will be displayed when the registration process is complete. The screen will return to the registration settings menu. Press OFF to return to the idle screen.
Model ip8301: How to register a handset:
  • Before registering the handset with the base station, press the FIND HANDSET button in the base till the VMWI and LINE IN USE lights blink alternatively. When the lights start blinking, register the handset. The default PIN for registering the handset with the base station is 0000.
  1. Press Softkey Menu from Home screen
  2. Choose the Settings icon from Menu screen and press center Navigation key/SEL to display the settings menu options.
  3. Press the up or down Navigation Key to choose the Registration Settings menu option and press the center Navigation key/SEL to select.
  4. Press the up or down Navigation Key to choose the Handset Settings and press the softkey Select to select.
  5. Press the up or down Navigation Key to choose the Register to Base and press the softkey Select to display a list of available base stations. Choose a base station from the list and press the softkey Select to select.
  6. The handset will search for the Base within its range. During this time, the searching screen will be displayed.
  7. If the search is successful, the Base station number of the base will be displayed.
  8. Press softkey Register. Enter the PIN and press softkey Apply to save and subscribe to the base station.
  9. To cancel the entire operation, press OFF key anytime.
Mar 07, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
How do i set ring volume on a binatone veva 1200
If the serial number under the base starts with "VT" under the base unit:
Press OK, press the arrow down to HS Settings, press OK, press the arrow down to Ring Setup, press OK, press the arrow down to RING Volume, press OK then use the arrow keys to set desired volume, then press OK. You may want to change the volume on the base too, in that case, the same instructions but instead of "HS Settings" go to "BS Settings".
If the serial starts with a "B":
Press Menu, press the arrow down twice to HS Ringer, press OK, press OK again, use the arrow keys up/down to select required volume then press OK.
Nov 24, 2010 | Cell Phones
My uniden DSS7855 with 1 base station and 3 handsets wont connect when i dial a number and hit the talk button it tries to connect and then comes up "'out of range" much appreciated for any help...
Clear the Handset's Base Data
  1. To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.
  2. It will now be de-registered from the base.
Note: This requires that the base and handset can communicate with each other.
Clear the Base Handset Data
  1. To de-register all handsets from the base, remove power to the base, and remove the handset from the base.
  2. Press and hold the 'flash/find hs' button while applying power.
  3. Wait for the beep and release the button.
  4. The charge light will now flash.
  5. Sit any handset in the cradle.
  6. When the flashing stops, re-register the handsets to the base.
Re-Register a Handset to the Base
1. Remove Handset Battery.
2. Reconnect battery while holding down "*" and "#" key.
3. Then press the right upper key under the LCD.
4. Press the "End" key.
5. Wait a few seconds and then the phone will be ready to register to the base.
Nov 12, 2010 | Uniden Lands Phones
Wont pick up any frequencies
Hi, my name is John. Try to program some frequency,s in it. Get them here. <a href="http://www.RadioFreq.com">www.RadioFreq.com</a> or <a href="http://www.RadioReference.com">www.RadioReference.com</a> ...instructions are #1. Press the E/PGM button. #2. Enter the frequency you want. Press the E/PGM button. #3. To program frequency, press the up- down arrow. #4. To exit, press the HOLD or SCAN button...... hope this was helpful....
Aug 27, 2010 | Uniden BC340CRS Base Scanner
How to reboot soundstation 2w polycom if you forgot the password
egistering Base Station on Polycom SoundStation 2W
Hold down 1,4 and 9 until green & red lights flash. Then hold down the page on the base station.
OR
You can register the base station to the console by:
1. press menu key
2. Select Admin Setup
3. Select Registration
4. You will see "Register with Base Station" in display. Press the Register softkey.
5. You will see "Power cycle base station then press ok". Unplug base and plug back in and press OK softkey.
6. You will see "Press and hold the paging button on the base for 10 seconds"
7. You will see Registering in the display on the console and then it should go to ready mode.
Mar 05, 2010 | Polycom SoundStation 2W (2200-07800-001)...
Best way to attach drill press base to cement floor ? 3/4hp. ITS.
The slots are there so you can use them to clamp work down to the base such as long objects that you need to drill into the end of. There should be holes around the outside, usually in the 4 corners that are there for bolting the base to the floor using expandable anchors in concrete. hope this helps you, Jeepfxr
Oct 08, 2009 | Makita TW0350 1/2" Drive Impact Wrench
I need the base id for a vtech house phone model number 6772
It sounds like you are trying to register the handset(s) to the base. Once the handset is charged, if you see 'Searching for Base' on the display,(The bold is for your question specifically but I thought you may like all of the information for getting a phone hooked up) ON the Base unit press MENU, scroll down to Display Base ID, press OK, and the Base ID code will display. If NEW appears in your handset display, press the soft key under it and enter the base ID code you found in the base display. If 'New' does not appear on your handset, press MENU and then scroll down to REGISTER. Press OK and then enter the base ID code. If the handset is already registered, please deregister all then register again. To deregister a handset which is registered to the base model 20-2431, Using the soft keys on the base, press the 'MENU', then press the down arrow once until 'SETUP BASE' is highlighted. Press 'OK'. Press the down arrow 6 times, until 'DEREGISTER ALL' is highlighted. Press 'SET' . If your handset is registered to the base model 20-2481, Using the soft keys on the base, press the 'MENU', then press the down arrow twice until 'SETUP BASE' is highlighted. Press 'OK'. Press the down arrow 7 times, until 'DEREGISTER ALL' is highlighted. Press 'SET'.
Benjamin
Jul 11, 2009 | Lands Phones
Telstra 7100. we had a power cut and now the phone just flashes with base 1 ....no dialing tone ect help
Disconnect the phone line leaving the power supply still plugged in. Next page the handset from the base unit hold and press button until it bleeps (remove the handset from the base unit first). press menu and scroll down to register.... press menu .....scroll down to select base... press menu then press 1. This should reset the phone. Failing that you can ring customer services the number will be on the bottom of the base unit.
Regards Sheena.
Nov 04, 2008 | Lands Phones
Olympia cdp24201
1. go to menu, then HS setting, then registration, register
2. follow the steps and register the set to the base.
3.press and hold the base mute button for 10 seconds, press next to continued
4.select the cbs and connect it.
5.enter 0000 as a password
Jun 28, 2008 | Olympia CDP 24201 Cordless Phone
Turn the ringer off
To turn off the ringer on my Vtech cordless phones, I have had to turn off the base ringer & all handsets.
Base Ringer:
Press Menu and listen carefully, continue to press menu until you hear "Base Ringer, to change base ringer press change", hit change and it will say "Off", then you must hit the PLAY/STOP button to save your change.
Handset:
Press the program button and use your "up/down" key to cycle until you see the Ringer selection. Press SELECT and then use your "up/down" key(s) to cycle until the OFF selection is see on the handset screen. Press select.
Jan 17, 2008 | Lands Phones
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
