Question about Frigidaire Affinity ATF6000F Front Load Washer
How to manualy drain the water? - Frigidaire Affinity ATF6000F Front Load Washer
  • 76 Answers
Hi
In the front of the machine there should be access to the pump filter . open the small door unscrew the filter and the water will come out . make sure you have a bowel and rags to catch the water that comes out.
good luck
Posted on Jul 20, 2009
How do you manualy defrost?
Defrost the refrigerator when the frost accumulated on the evaporator is about 1/4" thick. To defrost, simply push the defrost button. Be sure to keep the drain pan in place. Defrosting usually takes a few hours. The refrigerator will restart automatically when defrosting ends. Empty water from the drain pan after defrosting.
Jun 18, 2011 | Magic Chef MCBR445W1 Compact Refrigerator
How do i drain a mastercool of water manualy?
Remove drain pipe from water pan. You can usually turn it counter clockwise. When drained, clean with fresh water and replace pipe buy placing pipe dope or teflon tape to avoid leaking.
May 05, 2010 | Mastercool 67471 Evaporative Cooler Air...
My Bosch Exxcel 1100 will not drain, after manualy emptying it i have opened the front filter cap checked the filter and i can see the impellar spinning but when it is full of water it will not drain
Could be the impellor is slipping under load, or there is a blockage between the pump outlet and the point it drains into the waste pipe.
Try blowing down drain hose to see if it is blocked.
Feb 22, 2010 | Bosch Exxcel WFO 2264 Front Load Washer
On all cycles the "f-20" code comes up & will not go thru rinse cycle. I have to manualy do the rinse cycle.
you need to check your drain pump for anything that maybe blocking or restricting the water flow when it does go into the drain cycle
Feb 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have hotpoint aqurieus WML560 will not drain how do i do this manualy
To get rid of any water still in washer, lay drain outlet hose to floor level, and the water should run out through gravity into a bucket or similar.
Once empty, remove the lower rear pamel of washer.
Remove large black hose on to pump.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 26, 2010 | Washing Machines
Washer won't drain.
hi, to empty water manualy, lift the hose from the stand pipe, keep it above the water level, place a bowl on the floor and lower the hose into it, the water should drain out, to stop the water flow lift the hose above the drum and empty bowl, continue until empty, hope this help, thanks for using fixya
Feb 14, 2009 | GE WBSR3140DW Top Load Washer
Frigidaire Affinity ATF6000F Front Load Washer Logo
79 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
