Question about Garden
Elect problem kohler courage 25 engine - Garden
SOURCE: DGS 6500 w/26hp Kohler Courage surging
i HAD SIMILAR ISSUES WITH MY 2500 SERIES CUB CADET....IT WAS THE CARB.....REPLACED, AND ALL HAS BEEN WELL...THINK IT WAS APROX 200.00
Posted on Jul 26, 2009
bulldogchief
  • 388 Answers
SOURCE: Kohler Courage carbeurator leaks when engine off.
You need to rebuild the carburetor. You can most likely find a rebuild kit through the manufacturer.
Posted on Sep 13, 2009
jdlipscomb41
  • 157 Answers
SOURCE: What is the oil capacity of a Kohler Courage 19
all models are diffrent start by pouring 1 quart of oil in and check the level on dipstick if it is at the full level start the machine let it run 30 seconds and shut it off and let it set for 1 minute then check the oil. add as needed. as far as i know there is no way to reset the hour meter. thanks jd
Posted on Sep 19, 2009
  • 17 Answers
SOURCE: kohler 20 hp engine cranks way too fast and will
Sounds internal something broke
Posted on Jun 24, 2010
philwalker78
  • 605 Answers
SOURCE: How do you reset the change oil light on a kohler
Hi, the light will cancel automatically after another two hours use. Regards Phil.
Posted on May 11, 2011
I have a Gravely ZT2548XL mower with Kohler Courage Pro 25 hp engine. The mower will not start unless jumped off and the immediately dies when jumpers are removed.
That motor has a stator built in and uses a rectifier. The rectifier is probably burned out. They are not cheap.
Jun 10, 2017 | HP Garden
Tip
TROY-BILT PROBLEM WITH KOHLER COURAGE SV730 ENGINE
It seems kohler engine is well aware of the problem they have in the field with their engines. They told me since it didn't discharge the battery in one night to do as the manual states, disconnect the battery if longer.
on Jul 23, 2012 | Troy Garden
I HAVE ELECT PROBLEM WITH MY KOHLER COURAGE 25 ENGINE
you may want to describe the electrical problem your having. there are a lot. give more information on what it is doing or not doing.
Dec 05, 2016 | Garden
What is the vaulve clearence on a Husqvarna 25 HP, kohler courage 25 engine?
For SV480 through SV620: In: 0.127 mm (0.005 in.)
Ex: 0.178 mm (0.007 in.)
For SV710 through SV840: IN:0.101 (0.004in) /EX:0.152 mm (0.006 in.)
May 22, 2015 | Husqvarna Garden
Do you not know how to reset governor
go to youtube they have videos on how to adjust governor
Apr 14, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
MY NEIGHBOR KOHLER COURAGE 20 LTX1045 WILL TURN
check and see if it's getting spark by removing the plug from the engine and keeping it plugged into the wire,lay the plug on the head and turn the engine over and look to see if the spark is jumping accross the gap. if it's blue your ok if it yellow you'll have to replace ignition modual..good luck
Apr 10, 2010 | Garden
Belt replacement on kohler courage sv 590
Kohler Courage is an engine model. What is the make of the riding mower?
The mower belt arrangement is usually shown in the owner's manual. If you don't have this, you might check out www.mytractorforum.com. You can join for no charge. Put an item on there stating you problem, and somebody will likely answer your question.
Oct 15, 2009 | Garden
Sep 13, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
