Have a Weil McLain gold gv gas boiler. The internal circulating pump needs to be tapped on to operate. It's 10 years old. Do I simply replace the pump?
  • Heating & Co... Master
  • 3,315 Answers
Yes its sticking best to replace it
Posted on Dec 05, 2016
Boiler working but no hot water
Pump circulating heated water to the tank? Set the temp adjustment on the tank?
Sep 02, 2014 | Weil-McLain Ultra Plus 40 Indirect Fired...
Light the pilot light on weil mclain gas boiler
Joanne If there is a standing pilot on the boiler. Put the gas valve to the pilot setting and push in on the valve while holding a long match or BBQ lighter @ the pilot assembly that is behind the small access port at the top of the gas train assembly. Dont hold the pilot knob doun without having a flane @ the gas outlet of the pilot assembly or gas will build up and could blow out of the port and hold the gas valve in for about a minute or two and let it go it should stay light when you let it go .If it does not sta lit and it IS a standing pilot there- is a thermo-coupling that may be bad If the pilot does not stay lit.
If there is an electronic ignition rather than a standing pilot then you do not need to light it will light itself if the electronic ignition is bad or if the flame sensor is dirty. If you remove the pilot assembly from the gas train and clean the flame sensor rod with a piece of .0000 steel wool it could help. If not you may want to call a licensed pipe-pitter ( OR plumber depending where you live and the local codes).
If you don't thing you could do it yourself then call a licensed pipi-fitter or plumber. (Gas only has to leak once for there to be a problem so please do call someone licensed if you don't think you could do it your self.), http://www.weil-mclain.com/en/weil-mclain/products-services/
Here is a link to the manufacturer you should be ale to fing your equipment and the install instructions, if you look around .You can download a PDF and print it
Good luck and stay warm
Feb 08, 2014 | Weil-McLain CGa-25-SPDN, NG, Gas Fired...
Operating worcester bosch 240 gas boiler
  1. If there is no water on the floor, your crack is probably OK so far. The water thing is a worry though. NEVER fire a boiler that is low on water. Adding water to a hot boiler will crack it. Tell me all you can on what components you have in the water and gas lines.
Nov 15, 2013 | Weil-McLain Heating & Cooling
Set up for heating and lighting pilot
When is the last time you had it serviced By a Tech?
Oct 24, 2013 | Weil-McLain CGa-25-SPDN, NG, Gas Fired...
Safety relief valves
Need to know what pressure steam you are running, and what your water feed pressure is & temperature. If you are using a deaerator with pumps to supply feed pressure, and if there is a stack economizer. @ your altitude, I would de-rate your gas output to 10% less than your rated BTU's. Also need to know the % of oxygen in your flue gas, and if the gas & air intake is staged or modulating.
Apr 17, 2013 | Weil-McLain 88 Series - 11.8 GPH -...
Heating & Cooling Logo
59 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
