Question about Health & Beauty
What causes a (relatively new) power wheelchair motor to make a "Chirping" sound? What can be done?
2 Suggested Answers
  • 119 Answers
SOURCE: chirping sound coming from fan motor under dash.
remove blower motor and look for obstructions hitting cage(leaves etc.)possibly motor is worn internally
Posted on Feb 16, 2010
Why does joystick light drop to red as soon as u move motor were done new cable and joy stick
The batteries are to weak to drive the chair. It takes a lot of battery power to start moving but not when you just turn it on. Using a volt meter in the charge port before and when you push the joystick will confirm this. Very typical of wheelchair batteries to do this when weak.
Sep 09, 2014 | Health & Beauty
My mvp5 going right how do you check the bad connection to the motor
You will need to remove the seat and the shroud to get inside your chair. Once that is done, you will see the cable coming from the motor and then plugging into the control box. Unplug the cabe and do a visual examination of the connectors. Rarely, but occasionally these will overheat and cause a bad connection.
Apr 09, 2014 | NRS Hoveround MPV 5 - Used Power...
Jazzy select is swaying side to side when going forward like it has too much play in the joystick
Check your tire inflation and treads to make sure they can grip the floor/ground without slipping. Make sure that any keystock/keylock needed is installed on the axle, sometimes they slip out. Are your batteries fully charged and in good condition? Are you over the weight limit for the power chair?
Is there any noise or vibration coming from the power chair as you operate it? A grinding sound may indicate bad bearings in the caster wheels and cause problems in steering. A chirping sound may indicate a bad motor, they may be losing power and are not able to move the power chair evenly.
If your insurance purchased the power chair for you, they may also cover the repairs; contact them for information.
Oct 28, 2010 | Pride Jazzy Select 6 Indoor Power...
Motors not sincorised right motor runs faster and crooked
Check to make sure nothing has wrapped around the drive tires or axles that may be causing the motors to run improperly. Make sure your drive tires are fully inflated to 45-50 PSI. If you are still having problems with the chair pulling to one side, listen as you operate your power chair for any noise or vibration. A chirping sound can indicate a bad motor, grinding or rubbing can indicate bad bearings in the casters. Motor replacement can be costly, unless your insurance can pay for it. If you got your power chair from a second party, you will most likely have to pay for any repairs COD. Contact Hoveround sooner rather than later as Tech Service calls can take some time to schedule.
Oct 19, 2010 | NRS Hoveround MPV 5 - Used Power...
My friend has a rascal electric wheelchair he rode it here andveven tho we put the charger on--and he recently spent $200 on new batteries--it wont move the horn honks and it appears charged but it wont...
Hi. This type of fault can be caused by a few different problems. Is the machine flashing any fault codes?
Faults could be a stuck brush in the motor, Free-wheel lever in the wrong position, faulty motor or battery connectors, loose battery terminals, jambed brake solenoid.
Hope this helps. Neil.
Jun 09, 2010 | Pride New Jazzy 600 Power Wheelchair by...
Chirps when powered up
i have a 42 in magnavox lcd tv and it wont turn on at all and is also making a chirping sound coming from the back left of the tv. Picture just went out and gave a bad smell.
Oct 05, 2009 | Philips Televison & Video
Power light flashes 3 times and makes and alarm or chirping sound then nothing. its a 52 inch RCA hd52w59 itc222 chassis. I replaced cp150 and cp120/114 and also flyback transformer and still same thing? I...
Chirping sound is coming from coil on right side behind FBT, resolder then use Glue gun to glue on top of coil LL037,Make sure high voltage wire from FBT to Trippler is in Good this is what maybe causeing lines and fuzzy picture.Also make sure solder on all pinns of FBT are good.
Sep 22, 2009 | RCA HD52W59 HDTV Projection Television
When running the wheelchair at top speed there is a slight grinding noise in the drive train. is there a way to grease or oil the drive?
No,the motor-gearbox mechanism is sealed. You`ll probably need new motor brushes which you can get from a dealer or a new motor and/or gearbox.
Apr 13, 2009 | Invacare Pronto M51 Power Wheelchair
Philips 55PP9352 Rear Projection, no picture or sound, chirping.
This is a common problem with this model. The convergence circuits have shorted out causing the HVG to chirp.
Goto the site www.TvRepairKits.com and get their "chirping" tv repair kit. It will fix the no audio+no video + chirping problem.
Nov 16, 2008 | Philips 43PP9202 43" Rear Projection...
Health & Beauty Logo
62 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
