Question about Solo Garden
Will the ignition coil from a solo 423 blower work on a 414 blower?
2 Suggested Answers
  • 211 Answers
You can use any superior quality oil for 2 stroke engines.
best regards savumihai71
Posted on Feb 12, 2009
How do I replace the ignition coil on a strikemaster solo 142 ice auger. I can't see how to remove the plastic case to get to the ignition coil.
To replace the ignition coil on a strikemaster solo ice fishing auger you will need to go about it from the bottom side. remove the auger drill itself and turn the unit upside down. remove the 4 screws and the snap ring remove the screw that connects the throttle arm. remove the remaining bolts that hold the upper part of the gear case and remove the entire gear case unit. now you will be able to access the screws that hold the plastic cover and have access to the coil.
Feb 10, 2016 | Refrigerators
Why will my solo leaf blower not start ?
Possible reasons for not starting..
No Fuel
Spark plug dirty or worn out
Ignition cable weak
Ignition starter faulty
Starter cable stuck part way
Carburetor dirty or fuel mix setting in adequate
Choke not set correctly
Aug 07, 2014 | Solo Garden
Solo 445 weak spark
I had the same problem.. First I was only getting 89 psi so I took it apart just to find out that the piston ring was half way stuck in the piston groove making it loose compression put it back together and it started. But it was starting sometimes and I almost gave up on it till I noticed that the cruise throttle needed to be at least half way up to start and now it starts all the time just have to make sure is half way up before starting... If you try starting it with the throttle down it will give you a little bit of a hard time starting it when you put it half way up.. You have to start it half way up right off the back
Sep 08, 2012 | Solo 445 Backpack Gas Leaf Blower, Made In...
Poulan BVM200 LE leal blower it about 4 years old and has no spark. It work well last fall. Must the ignition module be replaced. Thanks, Rick
hi rick
if the plug is ok and kill switch and wire have been isolated from the ignition unit
and the earth is good for the armature legs on the coil - then yes the ignition module must be replaced and the air gap set to 0.010 "
a fair bit of work involved in replacing coil in one of these units !!!
ps make sure compression and muffler are ok and have a look up the ex port and check rings / piston and bore for any damage before parting with any cash for new coil
and dont be tempted to use stale fuel mix in your blower it can cause a lubrication fault
resulting i damage to piston / rings etc
cheers pauly46
Mar 30, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Dec 06, 2008 | Solo Backpack Blower 53 Cc, 235 Mph, 705...
Garden Logo
63 people viewed this question
Top Solo Garden Experts
Colin Stickland
Colin Stickland
Andrew Taylor
Andrew Taylor
Are you a Solo Garden Expert? Answer questions, earn points and help others
