Question about Craftsman Garden
What grade of oil is required for craftsman tractor model # C459-60411
  • Craftsman Master
  • 2,540 Answers
I use 10 W 30
Posted on Dec 06, 2016
Why is my craftsman 15 hp tractor smoking and stalling
Make certain the oil level is where it should be, overfilling can cause this or driving it down a steep grade will cause the oil to hit the underside (skirts) of the pistons and will pump oil. A damaged engine will also do this such as a piston that is broken or has a hole in the crown.
Jul 27, 2014 | Craftsman Garden
WHAT TYPE OF OIL DO I USE ON MY TRANSAXLE MOD 917.273080
Hydrogear transaxels take a multi grade oil 20-50 the filler is a brass plug on the top, there should be a 1/4" air gap at the top to allow for expasion, Tuff Torq units also take a multi grade oil 10-30, these units normally have a resevoir on the top with upper and lower fill marks.
Dec 10, 2012 | Garden
Where is the oil filter on a 17 HP Craftsman briggs & Straten engine and what grade of oil do I need
It may not have a filter, but if it does it would be a small spin on type on the left side of the engine about 4 inches in diameter. Use SAE 30 in that engine. It takes about 48 ounces of oil. Sears sells 48 oz bottles or you can use oil from your favorite auto parts store. Just don't over fill or it will smoke. Verify level with dip stick screwed in.
Oct 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have Craftsman 42" lawn tractor with the automatic transmission. It runs fine but it is not pulling a grade now. The belt seems tight, what could be the problem?
As you attempt the incline grab the clutch pedal with your heel and pull it towards you if it starts pulling correctly you have a belt problem . If it makes no difference you are having hydro pump problems
Jul 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Oil Grade
Either one will work fine. They both give the same protection. However, if you use the mower in the winter (for snow moving) you will prefer the 10W30 for easier starting. Here's an explanation of what multi-viscosity (like 10W30) oil is all about. Any weight (thickness) of petroleum oil has a characteristic temperature vs. viscosity curve. They all get thicker when cold and runnier when hot. Multi-Vis oil uses additives to modify that curve. 10W30 has the viscosity of a 10W oil when it's cold, but when it's hot it doesn't get as thin as a 10W oil. Instead it only gets as thin as a hot 30W oil. (this is much easier to see as two superimposed curves). The only downside of the multi-vis oil is that when it's been run in a hot engine long enough the additive tends to break down and it starts to behave more like a straight 10W oil. Besides it getting dirty, that's why you need to change it once in a while.
Apr 14, 2010 | Craftsman 16" High Garden Tractor Snow and...
I have a 20 hp craftsman lawn( hydro gear transaxle ) tractor in terrific shape that losses drive on a grade. I replaced the worn drive belt and it was good for the first few mows, Now Im right back to...
It sounds like the oil in transaxle is degraded.The transaxle is supposed to be a sealed unit requiring no service but over time the oil will get dirty enough to cause problems like you are describing.Remove the back hitch plate and look at the transaxle it will have a rubber vent hose or a 1/4 alllen wrench fitting on top. You will need to purchase a battery suction bulb from sears automotive and use it to remove as much oil from transaxle as possible. Warm the transaxle up first by running it around,then suction the oil out.Refill with a good synthetic motor oil 15w-50 or 20w-50 like Amsoil or Mobil 1.Do not use transmission fluid or hydraulic fluid. When adding the new oil back fill it to within 1.5 in from the top,be sure to allow this amount of air space in top of transaxle for expansion.
Jul 15, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Is craftman 10.5 hp good for commercial work
You don't specify what model, however most craftsman products are "homeowner" grade manufactured by american yard products. If your going to do a lot of commercial work spend the extra dough and get a good one with a commercial grade engine and a good warranty
Jul 01, 2009 | Craftsman 10.5 Hp 33" Commercial Cutting...
Changed transmission filter but don't know how to get oil back in to Craftsman Garden Tractor.
Hello:
I can Assist you, but I Require the Model Numbers Off the Unit and the Hydro Transaxle Tag.
With these I can Locate the Correct Manuals and Better Assist you.
I have Just Joined this Site as an Expert.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
May 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
60 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
