I get sound, but the movie doesn't show up on the tv The three connector wire, has a yellow one that isn't connected. Should it be?
  • Televison & ... Master
  • 6,694 Answers
Firs of all check wit another cable. Also check is the input you have selected is composite video.
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Posted on Dec 06, 2016
3 Suggested Answers
  • 121 Answers
SOURCE: Model DX-LCD19-09 HDMI connection doesn't
The back where The plugs go in is proble over used
Posted on Sep 25, 2011
Where can I find a connector cable for my Sanyo TV model DP32242 to my Sanyo DVD player model DWM380?
Gonna need three wire connector (is red/white and yellow, yellow for video, red for right sound channel, white for left sound channel). Standard, and sold at either Walmart or Radio Shack.
Dec 31, 2014 | Sanyo Televison & Video
Set up to play dvd movie on TV
You just need an RCA cable. Find the output from your dvd and connect to the input of your tv. The cable has three connectors in three colors...red/white/yellow. Res and white is audio and yellow is the video.
Dec 22, 2007 | Televison & Video
Dvd movies won't play in color, are my connections wrong?
in most cases its the tv not the player make sure the tv is set to nstc not pal
Dec 28, 2010 | Samsung HT-X50 System
How do you connect the dvd player to the lcd
On the dvd player and the tv you will see three (or more) colored connectors. These are color coded yellow, red amd white. One is for audioleft, another for audio right, and the third is video. You can get the cable with the colors so all you need to do is plug the ends into the same color connectors.
thats about as complicated as it gets. Then you need to look at your tv and select source or antenna. That tells the tv where the signal is coming from. you watch your movie and flip the source back to cable or where it finds your normal tv stuff.
You can get the cabes almost anywhere these days. the dollar store around the corner here sells them cheaper than the tv or electronics stores. I think the larger grocery stores even have some. So you don;t need to worry about spending a lot to get good ones. Very little difference in reality. Only thing is to make sure you get it long enough so you can put the dvd where you want or need to and try to get the 3 cable wih color coded ends.
Dec 02, 2010 | Sharp AQUOS LC-40C32U 32 in. LCD TV
How do i hook up my dvd player
Get the appropriate cord for connecting the DVD player to the TV.
The chord should be three joined together. Its called an AV wire. It has yellow, white and red color at the mouth of the pin.
The yellow is for Video (Visual) while the red and white are for audio (sound).
Since the DVD is to show on the TV, the wire has to be connected as follows:
  1. Insert the yellow wire in to the yellow part of the video out of the DVD.
  2. Insert the white and red wire in to the white and red part respectively to the audio out of the DVD.
  3. Connect the other part of the yellow wire to the input of the TV
  4. Connect the white and red wire to input like wise.
  5. Put on the TV and select to AV from the TV remote and you will see a display of your DVD at the background of the TV.
At this stage you can start watching.
Take care.
Jan 01, 2010 | GE 27GT271 TV
How do we connect a DVD reader and make it function normally ?
You have to connect the DVD player using the RCA video and audio cables that came with the player, they are three wires with yello, red and black connectors on either end. Connect the yello( video) cable to the yellow connctor on the DVD player and the other end to the yellow connector on the back ro the front of the TV, do the same for the others fro sound. Then turn the DVD palyer and TV on and select the correct input on the TV using the remote, they will be Line 1 or Line 2 depending on your connection. you can get to these either through the channels button or TV/Video buttons.
Dec 26, 2009 | Sylvania 6427TE 27" TV
How do i hook my dvd player to my tv? i have no manual to show me where to plug the wires into the back of my tv.i have a proscan 32LB30Q LCD
Hello pebbles12137,
This depends on what you want to do SD or HD
First if you just want to connect for SD only
Here are Three ways:
1) connect the coaxial cable to the DVD player F-connector (sliver screw connector) and the to the TV's Antenna in F-connector.
2) connect the yellow, red and white RCA connector end wires to the yellow, red, and white RCA Jacks of the TV Yellow (video in), Red (Right Audio in), White (Left Audio in) do the same for the other end into the DVD player (Best SD Method)
3) connect the svideo cable into the s-video socket of the TV and the other end to the s-video socket of the DVD player
For HD, Here are the connection methods:
1) Connect the HDMI cable to the HDMI in of the TV (HDMI1)and the other end of the HDMI cable into the DVD player. (best HD method)
2) connect the Component video cable (RGB) into the RGB sockets of the TV (should be marked as Component 1) and connect the other end to the DVD player (using this method you will have to connect the Red and White audio cables to the audio input jacks of the TV from the audio out of the DVD player)
These are the SD and HD methods.
I would suggest using the HDMI cables only, its the best choice and the simplest.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jun 21, 2009 | Proscan 32LB30QD 32 in. LCD TV
Cannot get sound from desktop to flatscreen.
You have problem with wiring. You need two separate wires, 1 - pc-> TV (video), other pc->TV (audio). Audio cable - minijack to rc
Apr 14, 2009 | Computers & Internet
Hook up portable dvd to tv
Connect the phone jack sized end of the wire to the portable DVD player and then connect the 3 RCA's to your tv in the color coded spots. Yellow for Video, Red and White for Sound.
Dec 18, 2008 | Sharp Aquos LC-15B4U-s 15 in. EDTV-Ready...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
