Question about Kitchen Ranges
We have a Wolf C56D Commercial Range. We need a propane to Natural gas conversion kit.
    Top Expert:
  • Kitchen Ranges Master
  • 75,005 Answers
Contact the local supplier of the gas, they can get you set up with the needed parts.
Posted on Dec 05, 2016
    Top Expert:
  • 4,740 Answers
Ge j2s968 convert to propane
On the back of the range there should be a conversion kit with intructions on how to convert from natural gas to l.p. good luck..
Nov 05, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
How can you tell if a 1985 wolf range burnes gas or propane? it says propane, but we bought it saying it was for gas? And how much would it cost to change out? Thanks, Mary Kaye
Most ranges are easy to convert from propane to gas or vice versa. If there is a gas regulator installed on the back gas inlet, you could see if it is running 3-6" WC or 10-12" WC, The latter is for propane. If no regulator is present the orifice sizes will need to be checked. Propane has a higher caloric value than natural gas so the orifices are smaller. One way to see would be to install the oven. If the orifices are for propane and you are using natural gas there will be too little flame. I would estimate a conversion would cost no more than $250.00 to $300.00 depending on where you are. I would hire a professional to verify. I know it is expensive but the technician will be able to check your older oven (1985) for potentially dangerous gas leaks etc while he is there.
Jun 06, 2011 | Wolf Range CHR-0-29-FT34 Gas Kitchen Range
I have a small counter top fryer set up for lp gas how do i change to nat
check the supplier for the conversion kit.the kit contains burner orifice, pilot orifice and gas valve spring which are commonly needed for conversion from propane to natural gas or from natural gas to propane.
****natural gas orifice has larger bore than propane, gas valve spring for propane is thicker than for natural gas.
Mar 29, 2011 | Cecilware FMS-40 Deep Fryer
Where do i find propane to natural gas conversion kit for weber spirit e310 gril
Apparently, Weber does not make a conversion kit to convert the grill from propane or from natural gas to propane. According to the Owners Manual - "Liquid propane gas is not natural gas. The conversion or attempted use of natural gas in a liquid propane unit or liquid propane
gas in a natural gas unit is dangerous and will void your warranty." (From Page # 3 of the Owners Manual)
See below link.
http://www.weber.com/help/manuals/pdf_files/2008_updated/89525_030308_2008.pdf
Feb 23, 2011 | Weber Spirit? E-310 Propane Grill
How to convert a 61" residential rangefrom butane to natural gas?
Ranges come set from the factory for natural gas. To convert it to propane, you should call your propane co and have a qualified serviceman do the work. You can void the warranty if you try to do it yourself and break something or don't convert it correctly. On an expensive range like this, you'll be better off having a professional do it right and keep that warranty intact. It could take 1 1/2 to 2 hours to complete the job. You may need to purchase an LP conversion kit if some of the orifices have to be exchanged, like on a unit with sealed stovetop burners. Write down the make, model # and serial # for reference when you make an appt to have it done. Hope that helps.
May 22, 2010 | Imperial Commercial Cooking Equipment...
SWITCH FROM NATURAL GAS TO PROPANE GAS MAYTAG MGR 5755 ADQ LOKING FOR GUIDE AND DESCRIBE ALL PARTS, NEEDED TO SWITCH FROM NATURAL GAS TO PROPANE GAS . PLEASE THANK YOU
Hello. Contact your propane provider and they will get you the conversion kit for your maytag model. In fact, they will send a technician to your home for free to make the conversion for you.
If you want to do it yourself go to any appliance store that handles maytag and get the conversion kit. Then remove the orifices that are currently in the stove and replace them. Regards, Joe
PS please rate my answer.
Dec 17, 2009 | Maytag MGR5755QD CleanDesign Gas Kitchen...
My pots and pans are covered with soot. We us propane for our 6 burner heavy duty gas range
u stove is designed for natural gas you need to retro fit or change the gas valve over to propane or locate a propane adapter kit for ur stove check with appliance part stores or product company
Oct 29, 2009 | Imperial Commercial Cooking Equipment...
Converting a Propane Thermador 36" range to Natural Gas
I have the same range but need to convert it from natural gas to propane....we should trade...9j antiques
Aug 31, 2009 | Thermador PGR366 Gas Kitchen Range
JDS8130 Cooktop Conversion Kit : Propane to Natural Gas Conversio
here is a site that has gas conversion kits
http://en.allexperts.com/q/Major-Appliances-3603/Jenn-Air-gas-range.htm
Jan 31, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Tappan Range Model TGF351ESJ Nat. Gas to Propane
Yes you can convert the range
2. Provide an adequate gas supply.
This unit is pre-set to operate on 4" natural gas manifold
pressure. Aconvertible pressure regulator is connected to the
manifold and MUST be connected inseries with the gas supply
line. If the LP/Propane conversion kit has been used, follow
instructions provided with the kit for converting the pressure
regulator to LP/Propane use. The LP kit can be found on the
back side of the range (some models).
I yours does not have the kit on back go to sears to get one.
Good Luck
Please rate FixYa!
Dec 19, 2008 | Jenn-Air JGR8855BDS Gas Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
