Not getting local channels - Televison & Video
Hi.how do i get local tv channels when we go into it it gooes to austar how do i get local channels . i have runned the wizard and the local channels came up just not sure how to access them?
get the on screen menu on the screen scroll around until you find auto tuning
click on that and sit back as it finds all channels that are available in your broadcast area
go ok and exit
Sep 13, 2015 | Televison & Video
How do I get my local channels back after pushing reset and auto channel scan?
and what was the point of factory resetting .check input setting it has to be air or antenna
Apr 27, 2015 | Televison & Video
Can this TV show local channels
Yes,Go to the tv menu,go to SETUP,go down to CH.press and select AIR.Will scan for over the AIR channels,u will get all the free air channels.After this u will get all the local channels,and other free air channels.
Apr 25, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Missing channel I used to get (using Broadcast)
You simply need a "Better" antenna system.
Feb 11, 2010 | Polaroid FLM-3232 Television
Unable to pick up local ''free'' channels following digital change over. Using RCA DTA800 converter and Phillips 2750/27 antenna. Can pick up only one local channel, but signal loss is more often the...
first of all, make sure all your connections are secure and threaded all the way in. Next, go to the main menu and press 5 (configuration) and press 1 (search for channels) if this doesn't work, press 4(signal strength meter) and see how strong your signal is. You may just need to re-position your antennae. If all else fails try system reset(number 5) and repeat search for channels. I've had similiar experiences with mine but I have a 62% signal strength and still get 20-something channels. Hope this helps.
Oct 11, 2009 | Televison & Video
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
