Question about Canon Office Equipment & Supplies
When scanning of my mp 237 printer a dark portion has come in the middle of the scanned image. I also want to know how to open the glass of the canon mp237 printer to clean the glass.
SOURCE: scanning document leaves streak down right hand side
Backu
Thanks for the tip...the problem is NOT a black line but a wide yellow line on the right side of the paper. It starts out about a quarter of the page in width and diminishes in size to about a half inch in width after many repeated scans.
The glass IS clean , and even when the glass had some smudges here and there, I never had a yellow stripe problem!
Scanner bulb is bright and even the entire length of bulb (no dark areas) so I don't think it is the bulb!
Rowboat
Posted on Dec 26, 2007
  • 5 Answers
SOURCE: i can't scan
hope this will help u about CANON MX310
http://canoncanada.custhelp.com/cgi-bin/canoncanada.cfg/php/enduser/std_alp.php?p_sid=Gk-ofu2j&p_accessibility=0&p_lva=&p_sp=&p_li=
Posted on Apr 29, 2008
bunnydawg
  • 5158 Answers
SOURCE: cleaning the scanning glass
Hard to get a smudge inside but basically you take it apart and clean the inside of the glass
Posted on Aug 31, 2008
SOURCE: how to scan on canon pixma mp 160
You need MP navigator to scan your photos or documents. under support and software and drivers all u have to do is select your OS and then download MP navigator its under SOFTWARE on that same paqe ... GOOD LUCK http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13368#DownloadDetailAct
Posted on Jun 16, 2009
kerguney
  • 577 Answers
SOURCE: CANON MX 320 SCANNER PROBLEM
You need to control the scanner thru your PC with canon software that came with your scanner otherwise you cant scan anything..first open the printer/scanner software ,select scanner,then place your document and command "scan" on your PC..thats it..
Posted on Jan 15, 2010
Canon ir 3300 printer has dark part in page not apper in print what is problem
dear
If the dark portion of the page is out side of the image scanned, then there may be chance of light passing to the scanner through platen glass.Pl. check the top cover and whiteness of the flap.
If the scanning through the PC has the same problem then the SHADING adjust to be done.
Thanks
Feb 21, 2015 | Canon Ir 3300 B/w Copier image Runner...
Scanner image is askew
Base on your explainination it seems like, this is because of your setting in MP Navigator, the image may not be scanned properly. In such a case, it is necessary to match the settings in MP Navigator to the document. please do the following. 1) Match the type of the document on the platen glass to the document type set in MP Navigator. For example, when scanning a color photo, select Color Photo in Document Type of MP Navigator. 2) Match the size of the document on the platen glass to the document size in MP Navigator. For example, when the document size is A4, select A4 in Document Size of MP Navigator. (Memo) Auto Detect is set in Document Size as the default.
Sep 09, 2007 | Canon Pixma MP500 All-In-One InkJet...
How to use the *2670 lexmark scanner
Please follow the steps below on how to scan using your Lexmark X2670 printer:
Using the printer control panel
1. Open the top cover, and then load an original document face down on the scanner glass.
2. Close the top cover to avoid dark edges on the scanned image.
3. Make sure that the printer is connected to a computer, and that both the printer and the computer are on.
4. From the printer control panel, press the scan button.
5. Follow the instructions on the computer screen.
Using Windows
3. Do one of the following:
• In Windows Vista, click > All Programs, and then select the printer program folder from the list.
• In Windows XP, click Start > Programs or All Programs, and then select the printer program folder from the list.
4. Click Lexmark Productivity Studio.
5. On the main screen, click Scan.
6. Follow the instructions on the screen.
Using Macintosh
3. From the Finder desktop, double-click the printer folder.
4. Double-click the 2600 Series Center.
5. From the "What is being scanned?" list, choose the type of document to be scanned.
6. Click Scan.
Source: Lexmark X2600 Series User's Guide
Oct 09, 2011 | Lexmark X2670 All-In-One Printer
How do you scan?
Open the Applications folder on the hard disk on which MP Navigator is installed, then open the Canon Utilities folder and double-click the navicon.gif MP Navigator 3.0 icon. MP Navigator opens.
2. Point to Scan/Import and click 'Photos/Documents (Platen)'.
3. Place the document face-down on the platen glass, and select 'Document Type'.
How to place the document and Document Type depends on the document to be scanned.
Allow 3/8 inches (1 cm) or more space between the edges of the platen glass and the document.
Align a corner of the document with the corner at the arrow of the platen.
  • When you select Color Photo or Black and White Photo, the position or size of the image may not be scanned correctly if you do not leave 3/8 inches (1 cm) or more space between the edges of the platen glass and the document.
  • When you select Color Photo or Black and White Photo, the position or size of the image may not be scanned correctly depending on the document. In such a case, select Document Size such as A4 or Letter according to the document to be scanned.
  • When you select Magazine(Color), the Descreen function will be enabled and scanning takes longer than usual. To reset the Descreen function, disable Descreen in the Scan Settings dialog box.
4. Click 'Specify'... and set the preferences as required.
The Scan Settings Dialog Box opens. Specify the Document Size and Scanning Resolution.
  • When Document Size is Auto Detect or Auto Detect(Multiple Documents), the position or size of the image may not be scanned correctly depending on the document. In such a case, select Document Size, such as A4 or Letter according to the document to be scanned.
5. Click 'Scan'.
Scanning will begin.
When the document has been scanned, the scanned image is displayed in the Thumbnail List area.
Oct 26, 2010 | Canon MP610 Photo All-In-One Printer
How do you get the Canon Pixma mp500 to scan?
Scanning images,
About Scanning images
You can scan images from the machine to a computer without printing them and save them in popular formats. Scanned data saved on your computer can be processed using image processing software. Furthermore, you can use the OCR (Optical Character Recognition) software to convert scanned paper documents to text data.
* Before scanning
Before scanning images, confirm the following :
- Are the necessary software (MP Drivers and MP Navigator) installed ?
If the software is not installed, install it.
- Does the document to be scanned meet the requirements for an original to be set on the Platen Glass ?
- Is the machine connected to a computer correclty.
Confirm that the connection between the machine and the computer is physically secure.
Scanning Methods.
A) Scanning Using the MP Navigator
MP Navigator enables you to scan in documents loaded on the Platen Glass and view images saved on your computer or on a memory card. Scanned documents can be previewed and easily printed and edited according to your needs.
You can use the supplied application softwares to edit or print the document you have scanned.
Windows : Double-click the [MP Navigator 2.0] icon on your desktop to launch MP Navigator.
Mac : Select [Applications] from the [Go] menu, then double-click the [MP Navigator 2.0] icon to launch MP Navigator.
You can launch the following application software from the MP Navigator.
* Easy-PhotoPrint (Photo Printing)
* ArcSoft PhotoStudio (Photo image editing)
* ScanSoft OmniPage SE ( Converting scanned document to text)
- This application software may not be supplied with teis machine in some country.
Note : If you did a [Custom Install] and only installed the MP Driver and MP Navigator, these application software were not installed and thus cannot be launched. To launch any of the above application softwares from MP Navigator, do a [Custom Install] once again to install them.
For detailed operations of the MP Navigator, refer to the Scan Guide.
B) Scanning Using the Operation Panel of the Machine
You can scan documents to your computer by using the Operation Panel.
Important : Do not insert or remove USB cables when scanning images with the machine connected to a computer, or when the computer is at sleep or standby mode.
*If you are using Windows XP
The program selection screen is displyed the first time you press [Color] or [Black] on the machine.. Specify the [MP Navigator 2.0] as the application software to use, check [Always use this program for this action], then click [OK]. From the next time, MP Navigator is automatically started.
*When using Mac OS X
For the machine to start scanning when [Color] or [Black] is pressed, you need to set MP Navigator as the starting application software in Image Capture under [Applications] of Mac OS X.
1) Press [ON/OFF] to turn on the machine.
2) Load the documents on the Platen Glass.
3) Select the scan option.
a) Press [Scan].
The scan operation selection screen is displayed.
b) Use Up or Down arrows to select the scan operation, then press [OK].
Scan standby screen is displayed.
Save to PC : The document is scanned and saved.
Save as PDF file : The document is scanned and stored as a PDF file.
Attach to E-Mail : The document is scanned, and the image is attached to an e-mai using the e-mail application software.
OPen with application : The document is scanned and displayed on the registered application software.
4) Press [Color] or [Black].
The document is scanned. The settings configured from MP Navigator apply when scanning.
Important : If with some types of original the position and size of the image is not scanned in correctly, please refer to the "Selecting the Behaviour of the Operation Panel with Mp Navigator " in the Scan Guide (on-screen manual). and change the MP Navigator [Document Type] and [Document Size]] to match those of the original being scanned.
Note : The operation to be performed after scanning the document depends on the scan operation setting you have selected in step 3. For details on how to modify the operation settings, refer tp the Scan Guide on-screen menual.
C) Scanning from an Application Software
You can scan an image from TWAIN-or- WIA (Windows XP only) complaint application software and handle the scanned image in the application software. For detailed operations, refer to the Scan Guide (on-screen manual).
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 07, 2009 | Canon Pixma MP500 All-In-One InkJet...
I CAN'T FIGURE OUT HOW TO SCAN ON A 210
Scanning images : You can scan images from the machine to a computer without printing them and save them in popular image types such as JPEG, TIFF, bitmaps or PDF. If you are scanning printed text, you can use the OCR (Optical Character Recognition) software to convert it to text data.
Scanning Methods : You can select from various scanning methods.
* If you want ot Edit or Print the Scanned images
MP Navigator EX enables you to edit the scanned images, such as optimizing or trimming. You can also start appilication sotfware from MP Navigator EX to edit ot print the scanned images.
For detailed operations of MP Navigator EX, refer to the Scanning Guide on-screen manual.
You can also use the Operation Panel to open MP Navigator EX as well as open it using the computer.
-- Opening MP Navigator EX using the Operation Panel
1) (MAC only) Prepare your computer before scanning.
This operation is not necessary for MAC OS X v.10.4 x.
For details, refer to "Scanning Methods" in the User's Guide on-screen manual.
2) Turn on the machine.
3) Load the original Document on the Platen Glass.
4( Press the SCAN button, then press the Color or Black button.
* If you want to Scan Originals with Advanced Settings.
Scan Gear enables you to scan originals with advanced settings such as the resolution. For detailed operations of ScanGear , refer to the Scanning Guide on-screen-manual.
Besides the above mentioned methods, you can use a TWAIN or WIA-( Windows Vista and Windows XP only) complaint application software and the Control Panel (Windows Vista and Windows XP only) to scan originals with this machine. For detailed operations, refer to the Scanning Guide on-screen manual.
Hope this helps.
Have a good day.
Dec 05, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
HOW DO I SCAN A DOC.
Hope this helps.
Have a good day.
Dec 03, 2009 | Canon PIXMA MX300 All-in-One Printer
6150 scans leave a line down the scanned image
There is probably a speck of dust on the scanning unit. You can unlatch the glass scanner table and, with the unit powered down and the cord unconnected, gently pull the scanning unit out (or you can start a scan and power down the unit when the scanning unit is in the middle of the table). Opening the scanner table will void your warranty!
Examine carefully the glass "window" of the scanner in the area corresponding to the dark line using an angled light and see if you can spot the dust. You can clean the window glass with a lint-free cloth dampened with alcohol. Do not press hard on the scanning unit since the mechanism is quite delicate. Afterwards, carefully replace and latch back the glass table.
If the dark line does not go away, you might have a faulty scanner, but that's unlikely.
Oct 27, 2009 | Lexmark X6150 All-In-One InkJet Printer
I want to scan documents with my Pixma MP 150
Scanning using the Operation Panel 1. Place the document face-down on the platen glass.
2. Press the [Scan] button on the machine.
MP Navigator starts on the connected computer. You can scan in documents placed on the platen glass using MP Navigator.
Oct 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
HP 4345 Dark Line in Middle of Scanned Image
The correct answer is to clean or replace the mylar sheet on the bottom of the adf
Mar 13, 2009 | HP LaserJet 4345mfp Printer
29 people viewed this question
old marine
old marine
