i recently purchased cricket broadband and have the a600 usb modem. i was told i can use it to play online with my playstation 3. what is the best way to do this? Playstation support doesnt wanna help me
1, wireless, make sure that you have an internet connection first with a computer and that you know your network name and password (if you have one set up). Go into the PS3 menu and scroll to the network config section, and set up a new network, where it says SSID this is the name of your network, for example SKY1234. Then it will ask you for a encryption type, for example WPA or WEP and then your password, input your password and let the PS3 do the rest, if there is anything wrong it will tell you.
2, wired through an ethernet cable, again go to the network config section in the PS3's menu and set a wired connection, it will not ask you for your SSID or password as its a wired connection.
If you need anymore help or advice please feel free to post back.
How do I allow inbound and outbound UDP to ports 5198 and 5199, and outbound TCP to port 5200 on my...
(More)
How do I allow inbound and outbound UDP to ports 5198 and 5199, and outbound TCP to port 5200 on my Westell 6100?
I have a westell 6100 router on a verizon isp. i set it to bridge mode and have a linksys router...
(More)
I have a westell 6100 router on a verizon isp. i set it to bridge mode and have a linksys router hooked to it. now, i get a key exhange timeout error on my ps3, and my laptop disconnects at the same time. renew ip address', and everything is good to go. any ideas?? it only started doing this when set in bridge mode.
I have a westell router to,but i don't have a manual for it and i can't sign into xbox live unless i...
(More)
I have a westell router to,but i don't have a manual for it and i can't sign into xbox live unless i have 1346 MTU or more and i need to no how 2 change this setting
