Question about Panasonic RR-830 Desktop Cassette Transcriber / Recorder
Panasonic RR-830. When play is engaged and I press on foot pedal, unit only rewinds. No play. Have unplugged/plugged pedal, adjusted back space control, etc...nothing resolved the problem.
4 Suggested Answers
  • 67 Answers
SOURCE: My Panasonic RR-830 turns on, but the cassette
Most likely the internal belt has broken.
Posted on Jun 30, 2009
  • 18 Answers
SOURCE: have a panasonic RR930 microcassette
If neither rewind nor backspace work, the common problem would be that the solenoid grease has dried up and the solenoid is not retracting all the way. However, the track that the mechanism moves in also wears out, as well as the plastic rocker that depresses the rewind button where it engages the metal slide.
If backspace works but not rewind from the pedal then the problem is the pedal.
Posted on Jul 28, 2011
  • 145 Answers
SOURCE: Panasonic Model RR-930. The machine will not
Check that the pause switch is off. Otherwise, either the belt is broken or the motor is bab.
Posted on Aug 02, 2011
Testimonial: "Thanx so much. I was in a rush to get a job done and didn't realize that I pushed the PAUSE button..."
Panasonic RR-930 does not backspace with or without pedal. It engages the mechanism but appears stuck when tape is inserted. Runs fine without tape in deck.
The ancient tape is junk. Buy a new one. You might also try slamming the old tape against a wall or desk to loosen up the tape layers. Then FF and RW all the way.
Apr 20, 2015 | Panasonic RR-930 Desktop Cassette...
During transcription, when you release the foot pedal, the tape automatically rewinds a little so you can resume easily. This no longer happens with my machine. I have tried several foot pedals, but the...
It could be the rewind solenoid is jamed up or there is a switch that comes loose under the tape deck. Either way, it will need to be serviced.
dictationmall
Nov 01, 2011 | Panasonic RR-830 Desktop Cassette...
When I take my foot off the pedal it rewinds farther than it should
Hello on a BM-147 there is only one adjustment responsible for auto back space when you used foot pedal and that adjustment is next to the Display is call Reverse Time that controls the reverse function when you take foot control off from play but if the problem is when you take the foot off on REW and unit keeps going you have a bad foot pedal you can get a replacement at http://www.tvps.com/Products/ECS-Sony-IN-75-Heavy-Duty-Foot-Pedal---Pre-Owned__ECS-PIN-75.aspx
May 17, 2011 | Sony BM-147 Desktop Cassette Transcriber /...
Have a panasonic RR930 microcassette transcriber. Right now the foot pedal will not allow rewind though when I press the pedal I can hear it engage. I can, however, rewind right on the unit itself. ...
Mar 23, 2011 | Panasonic RR-930 Desktop Cassette...
Tape completely rewinds when I let off the foot pedal
Make sure the button for back space is not at max is the second button from the right side if problem don’t get fix unplug the pedal from unit and try to play and stop if unit work Ok the problem is your pedal. Needs to be replaced.
Apr 02, 2009 | Panasonic RR-930 Desktop Cassette...
Foot pedal FF or Rewinds when pressing Play
It's possible that there's a broken wire in the cable that connects the foot control to the machine. This usually happens near the plug that plugs into the machine, or by the end that goes into the foot control.
You can usually duplicate it if you put the auto-backspace up a bit and then hold down the play pedal on the foot control. While holding down the play pedal, try moving the cable near the machine or near the foot control in a circular motion. If the machine stops, rewinds or fast forwards, then odds are that the problem is with the cable.
Mar 13, 2009 | Dictaphone 3750 Desktop Cassette...
Panasonic RR-830 only rewinds and fast-forwards, will not play
If the foot pedal is pluged in, press the play button and then you should be able to activate it with the pedal.
Jul 30, 2008 | Panasonic RR-830 Desktop Cassette...
Panasonic RR-830 Desktop Cassette Transcriber / Recorder Logo
99 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
