Question about Pool & Spa
On backwash/filter pump does not suck up any water. Pump is running, but skimmer box no suction. If one fills up the pump, it does pump water out. Blockage in pipe between skimmer box and pump?
  • 77 Answers
SOURCE: suction with my pump
First thing to check is the removal of any winterizing plugs in the return lines. Sometimes plugs are fitted inside the lines in the pool making them not obvious. Secondly, check that any valves in return line are open. Many never lube type valve handles are oppositely positioned as compared to ball valves. If the multiport valve hasn't been tampered with, then there really is no other place to look. The flows everywhere but back to pool.
Posted on Apr 24, 2009
XPoolGuy
  • 34 Answers
SOURCE: No water coming out when I backwash. I cleaned
water level must be about the discharge (eyeball) in the pool to back wash. Check the hose connections to make sure that hoses off the the filer head are going to the right place Look for the words "Pump" , "pool" and "waste" molded into the valve. I've seen it a number of times where "Pump" and "pool" were connected the wrong way.
Posted on Jul 04, 2009
  • 634 Answers
SOURCE: my pool sand filter pump isnt filtering the water
sounds like the sand has clumped together inside filter. you can open filter and replace sand charge or dump into wheel barrow loosen sand and flush clean with hose and put back in
Posted on Jul 17, 2009
john224
  • 1378 Answers
SOURCE: water running through the backwash valve when in filter position
Open the valve and replace the "wagon wheel" looking gasket that sits below the diverter.
Posted on Aug 18, 2009
aquaman987
  • 927 Answers
SOURCE: I have a 1hp sta-rite
It sounds like there was a lack of water to the reservoir, which is, I assume the inlet reservoir with the basket strainer in it.
1. Is your water level in the pool high enough to keep the reservoir full?
2. There is an o-ring or gasket on the reservoir cover, is it there and lubricated so there is no air leakage?
3. Put a garden hose into the open reservoir to see if the pump moves this water out.
Do all of this with the filter set to just go back to the pool so you can see the results.
Try this and comment back.
Good Luck,
Gary
Posted on Dec 11, 2010
I have an Easy Set and using a skimmer. Should I remove the extra intake hose?
Huh?
i am confused... What does a hose have to do with the ability of the pump to move water?
Suction of a pump has nothing to do with an extra hose.
Suction ability has everything to do with whether a filter element is clean or dirty!
These toy pumps have an exceptionally SMALL filter, and need cleaning or replacement OFTEN!
The suction action of a pump should not change, with the attachment of a skimmer: unless... The skimmer is higher than it should be and sucks air, therefore the pump will lose prime!
If you comment back with a little more detail, somebody will be glad to assist.
May 28, 2015 | Intex Pool & Spa
Why does the filter basket never seem to catch anything and it never reads to need to be backwashed...but the water is still not clear....what are we doing wrong?
Because of the size of the filter - 18", I would presume this is an above ground pool?
  • Do you have a skimmer?
    • If so, put some leaves, larger organic debris, etc. into the skimmer. They should end up in the basket of the Hair & Lint Pot!
    • That would prove your question to be either working or not.
  • If you don't have a skimmer, then you have a suction port in your pool.
    • Let that suction port suck some larger debris that would stay in the basket. Again, you will prove or disprove, whether debris is getting to your pump basket (Hair & Lint Pot Basket).
How long has your pump & filter been operating?
How long do you let your pump & filter run per day?
  • It should run at least 8 hrs per day.
  • If cloudy, you should run continuously until clear.
How long has your water been turbid/cloudy?
  • Use a clarifier, Natural preferred, like SeaKlear, daily at recommended dosage, until clear
What is the pressure?
Are you saying that it is the same pressure as Day 1, has not climbed at all?
What do you mean: Does not read that backwash is needed?
What in your understanding is: "Time to backwash the filter"?
You should know the "Starting Pressure" of your Sand Filter!
  • When sand is absolutely clean & free of any grime and sticky residue.
    • Just added media, when just installed is the best time to make a note of the starting pressure on a working pressure gauge.
  • When the pressure rises 8-10 lbs. over starting, time to backwash!
Jul 13, 2014 | Hayward Pro Series 18" Above Ground Pool...
Hayward s200 losing suction in filter mode
Based on your question, it appears you have a Hayward S200 sand filter with 6-position side mounted valve and a standard pump with a first stage basket with a Lexan sight cover. You indicate that 5 of the six valve positions appear to work properly, drawing water out of the skimmer line, through the valve, and into the appropriate output (such as waste, recycle, backwash, etc.), but that in the normal filter mode your pump runs but no water is drawn from the skimmer through the pump basket.
What you describe is a classic blockage downstream of the pump. First, check to verify any/all downstream valves are in open position. If the filter will operate in backwash mode, it is likely not a blockage within the filter. I suggest you disassemble the 6 position valve and check for any obstruction within the valve itself. Based on your description, it's possible the obstruction might be in the bottom line going to the filter. This line narrows as it approaches the valve, and in normal filter mode an obstruction in this line could log and clog the water path, but in backwash mode water flows away from the valve toward the filter in this line, away from narrow to larger diameter. It's a long shot.
Apr 04, 2013 | Hayward Industrial Products Hayward S200...
What is an impeller
the impeller is the most important part of the pump when motor kicks on impeller spins pulling and pushing water through it check to see if it has something glogged in it also try backwashing filter...
May 30, 2012 | Intex 2100 Gph 95 Hp Sand Filter Pump With...
I returned from vacation and the water level was adequate b/c it had just rained a lot. I think the water may have gotten low when we were gone. Now there is not enough pressure in the pump and the...
Any air getting into the suction line of the system can cause a low flow. If too much trans is in the skimmer basket or pump basket you cna get a low flow. If junk is in the pump impeller or the filter the flow can be low. Check each of these possible problem and you will likely resolve it. I hope this helps.
Aug 12, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP 2 HP...
When I backwash or rinse my pump reservoir fills to the top when I filter I have air bubbles at pool discharge and reservoir about 3/4 full and air is evident. Do I need to start digging up my skimmer line...
When backwashing or rinsing the same water is used as in filtering.(skimmer and main drain) so I don't think skimmer damage is the issue. Check if the pool water is low at the skimmer after the backwash cycle, Also check to see if the skimmer weir gate (flapper) is stuck in the upright position. I would suggest 2 main checks. Fill the pool higher than usual, back wash, ensure the pool water level is 1/2 way up the skimmer level and try again. Also, if your lines are valved right, shut off the skimmer during the filter cycle and see what happens. Lastly, the gasket on your multi-port valve may be bad.
Jul 16, 2010 | Hayward 3/4hp Super Pump Inground Pool...
Pressure up past 15 or 20 shortly after
The sand is clogged and needs a backwash or change.
May 25, 2010 | Hayward Pro Series 18" Above Ground Pool...
Cannot get pool pump to prime
turn the valve to main intake line (not the skimmer) and flood the pump with as much water as possible.
make sure there are no areas around the seals where air could get sucked in. when you get a full flow switch it to skimmer and main.
May 10, 2010 | Garden
My pool pump won't prime
If the pump is above the pool water level the it is unlikly that the tank will fill completely with valves open (which is ok).Most pumps are self priming and will pick up a prime with water level below suction inlet on strainer. Try starting on main drain again and slowly open skimmer line. Did you remove water from skimmer line and winterize(if in cold weather climate)during closing?.I know this sounds stupid, but make sure water level in pool is well into skimmer. If air situation remains after scspriggs' and these thoughts then prepare for a pressure test on skimmer line to determine location of leakage.
Apr 21, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Sand filter not catching little debris
Filter is being bypassed at backwash valve, due to poor spider gasket in valve, or there is a broken lateral in bottom of sand filter, causing debris to return to pool..
Feb 18, 2009 | Hayward Pro Series 18" Above Ground Pool...
Pool & Spa Logo
79 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
