Question about Watches
How do I match up day to date when end of month.
    Top Expert:
  • 4,807 Answers
How many days from 01/11/1944 to 01/07/2016
Date difference from Jan 11, 1944 to Jan 7, 2016 The total number of days between Tuesday, January 11th, 1944 and Thursday, January 7th, 2016 is 26,294 days.
This is equal to 71 years, 11 months, and 27 days.
This does not include the end date, so it's accurate if you're measuring your age in days, or the total days between the start and end date. But if you want the duration of an event that includes both the starting date and the ending date, then it would actually be 26,295 days.
If you're counting workdays or weekends, there are 18,782 weekdays and 7,512 weekend days.
If you include the end date of Jan 7, 2016 which is a Thursday, then there would be 18,783 weekdays and 7,512 weekend days including both the starting Tuesday and the ending Thursday.
26,294 days is equal to 3,756 weeks and 2 days.
The total time span from 1944-01-11 to 2016-01-07 is 631,056 hours.
This is equivalent to 37,863,360 minutes.
You can also convert 26,294 days to 2,271,801,600 seconds.
Number of days between January 11th 1944 and January 7th 2016
Jan 10, 2017 | Watches
Tip
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
on Jul 20, 2010 | Watches
Tip
on Jul 09, 2010 | Watches
How do I know what month my Michael Kors watch is showing?
At the end of a month that is less than 31 days you must manually advance the date.
Aug 30, 2014 | Michael Kors MK5629 - Sport Bradshaw...
How do I change the month on an MK 5629?
At the end of a month with less than 31 days you must manually advance the date.
Aug 30, 2014 | Watches
How do you set this watch....4 buttons
SETTING THE TIME AND DATE ON AN OLD 4 BUTTON DIGITAL WATCH
[L1] [R1]
[L2] [R2]
SETTING THE TIME.
Press [L2] to move through the modes. When the time display flashes, you are in the correct mode to set the time. The hours first, then the minutes and seconds.
Press [R1] to advance the numbers, [R2] to go to the next.
Press [L2] to save your settings. [L1] is not used; it's the light.
SETTING THE DATE AND DAY. After setting the time (seconds flashing) push [R2] to move though time, backwards, to date, [R1] to set day, [R2] to move to month [R1] to set the month. Push [R2] to get to the day of the week, then [R1] to change. [L2] to end.
Jul 26, 2010 | Fossil JR9455 Watch
Date on watch?
mcdevito75 here, YES! that"s normal, all Date watches go up to 31, as some months have 31 days, watch makers haven"t come out with a mechanism that will automatically jump the 31 to the 1, well not that I know of, you simply turn the hands another 24 hours from 31 to 1 if the specific month ends with only 30 days.
Jul 03, 2010 | Watches
How do i adjust the date on my classic watch?? pull the pin and rotate cw or ccw no changes.i have an indigo classic watch. does date need to be adjusted every 30 day months? thanks
You have to adjust the date every February (28 or 29 days), April, June, September and November (each 30 days). Self adjusting calendars are called Perpetual Calendars and this feature is quite expensive, especially in mechanical watches. Your watch has calendar ring with 31 days printed on and the simple calendar mechanism which is changing dates from 1 to 31 inclusive,day after day, so, when the 30-day month is ending and there is no 31st date to follow, your calendar is showing 31st anyway,instead of 1st of the next month. This is when you have to adjust date. Now about the date adjusting. If you pull out crown gently, you will notice there are two clicks (positions), not just one. So the first click, when crown is not pulled out fully, is exactly for day/date adjustment. If you pull the crown further out, watch is in hand adjustment mode. Try it carefully and you will find out the right position.
Rate me, please.
Jan 12, 2010 | Timex 5B841 Wristwatch
Day and date not synchronized with actual day and date
The watch does not have a "perpetual" clock so it does not know what month it is in. It will treat every month as a 31 day month, so you will have to re-set the date anytime a month is not 31 days.
If you appreciate me answering this for you then please rank this solution as "fixya" or at least "helpful" as what I have said will solve your problem. :-)
Jan 09, 2009 | Citizen 8700 BL8000-54L Wrist Watch
How to change day and date of fossil me1045
I bought my bf this watch for christmas... i set it before i gave it to him... it is the me1045
It took me forever to figure out how to set it, and even longer to actually set it.
The instructions fossil gives are useless, and the two side buttons do absolutely nothing.
So.. to set the day of the month, you have to spin the knob clockwise for 24 hrs for each day.
So, if it says 2nd, and the date is actually the 4th in the am, you have to spin it 4 times around the face, ie 48 hrs. If you go over, you're screwed and have to go all the way around again which, trust me, takes a really, really long time. Going counter-clockwise will not change the date, only the day.
The day of the week will change with the day of the month. Don't worry; they might not match up at the end. It may be the 4th and say it's monday. That's okay, because, unlike the day of the month, the week days can be turned backwards by turning the dial counter-clockwise.
Remember to take into account whether you are in the AM or PM. PM will require an extra turn beyond when it first switched to the date.
Goodluck; hope this helps.
Jan 04, 2009 | Watches
Watches Logo
19 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
