Question about Dishwashers
Water spray quit spraying - Dishwashers
    Top Expert:
  • Dishwashers Master
  • 8,211 Answers
Not spraying water
I have sk460 spray mop and the 6 volt spray motor rusted up.
Looking for motor now.
Dec 09, 2015 | Vacuums
Engine runs fine. But it quits when I pull the trigger on the wand to start washing
Does this behavior change if the engine is warm and on minimum choke? Do you get any water spray before the engine quits? Carburetor could be dirty or float stuck. Try putting dose of carburetor cleaner through engine and cycle choke lever and engine speed lever back and forth while engine is running after it has warmed up without running water spray. See owners manual.
Apr 03, 2015 | Craftsman 2700 PSI,2.3 GPM Briggs &...
My vax rapide w89 will not spray water from the bottom
Hi s_hall9800,
We bought a Vax Rapide Carpet Cleaner and were disappointed with it's performance as we couldn't see it spraying the cleaning soltion onto the carpet. I found there was no pump and gravity was all that put the solution on via a sparge pipe, controlled by a trigger-operated valve. So, all that happened was an intermittent sort-of dribbling. The cleaner picked -up quite well, though and we sprayed the carpet using a separate hand-held sprayer.
Nov 21, 2014 | W87-Rh-P Rapide Ultimate Clean Upright...
Machine turns over, but keeps stalling when I begin to spray
By stalling you mean quit or bogs down until you release spray?
The engine has to be on high speed and be in good tune with good gas to produced the horse power for the pump. A too small water supply hose can add to to the engine load trying to suck water that is not there.
Sep 12, 2013 | Dewalt Garden
After pressure washing my engine last week I have been having problems starting my Volvo truck. The truck is turning over but not starting.
hi.
you have probably got water in part of the electrics somewhere.
simplest thing to try is a water repellent lubricating spray. spray any electrical plugs you can see in the area you pressure washed it. also spray any ignition units that you can see. if it is a petrol, spray the HT leads going to the spark plugs and the inside of the distributor . then leave it for 30 minutes and try starting up.
repeat if necessary.
if this does not work, you will probably need to open each plug and spray inside both parts and reconnect. this should cure the problem, but may take some time as there are quite a lot of plugs.
Apr 13, 2011 | Volvo V40 Cars & Trucks
I have 2 bissell pro x2's that are now both not spraying water
Thanks to many others who have posted on similar problems -- water and/or solution sprays through the handheld tools, but not through the main machine.
As others have suggested, I removed the water reservoir, which exposes the 2 main water sprays mounted above the rollers. Using, pliers, I carefully slid the clips back. Gently but firmly removed the two red nozzles.
Elsewhere I have read suggestions to just do one nozzle at a time. However, I found out that if you remove both red nozzles, you can then blow through one side and it will come out the other. In my case, that dislodged a nice collection of crystal-like chunks (guessing it may be crystallized residue from the cleaning solution).
There was also a bit of blockage in one of the red nozzles, which I cleaned out. Make sure you can blow through both of them with little resistance.
Reassemble: Push red nozzles back into hoses. Using pliers, reposition sprung clip back over the red nozzle. Snap nozzles back into place. Refill tanks and power it up.
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!! d
Jul 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a Kitchen Aid Superba KUDS24SEBS1. The inlet water pressure is good and the dishwasher fills and starts the wash cycle, however, after the initial spray of water, it seems that all of the water...
when "full" of water, the normal height of level is about 1/2 below the heater assy(large blackish grey coil below he spray arm).. if theres enough water in the unit nad its still not "spraying",its quite possible that your filter/chopper assy is clogged and cant let water through. try removing hte spray arm and under that you will see 5 torx15 screrw holding down top filter plate under there to the left youll see another t15 screw covering hte chopper assy area. claen out sump of debris this may be your issue
Nov 26, 2008 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
