Question about Jacuzzi - Bathtub - Alcove - Navona - R105917
We've had a whirlpool tub with jets for 2 years. About a year ago, the jets stopped working--i.e. you push the button and nothing. Whe have it hooked up to one of those cool water circulator things that continually heats the water as long as the jets are working but now that's useless too. The powerstrip running to the heater part underneath the tub is on so we know that it's good to go as soon as the jets are fixed. Any tips on how to diagnose/fix this?
  • 23 Answers
Check behind the access door for a air tube that goes from motor switch to button if either side has come off you have to re attach it just cut off 1/4 inch of the tube before you do. that will make it fit tighter
Posted on Jul 20, 2009
Hytec Kohler Model LM34520 air jet swtich not working. 4 years old and last use, the push button stopped working. Cannot see connection detail at switch/button end but disconnected at motor and and can...
The problem you are experiencing tells me that the air switch in the motor most likely the problem.
This is a latching air switch that operates when the button on the side of the tub is pushed.
The replacement TBS-339 air switch is around $21
Rod
US Parts Center
Jan 06, 2013 | Jacuzzi Home
I have a Royal Whirlpool bathtub. After I fill the tub with water, I push the button for the jets to start and the jets only work while i am pushing the button. The button is a air button. Feels like I am...
You have a bad neumatic switch. Or a small hole in the air line. Try pushing the button fast and hard to see if it will stay on. if so , it is a hole in the tube. if not it is your neumatic switch
Mar 23, 2011 | Home
I have a whirlpool bath in my master bath in my mobile home, years ago my grandson pushed the button to activate the jets without water in the tub, it hasn't worked since, yesterday I had a friend who is...
the air switch should be connected to a switch by the motor the air switch is ur on off and should run from the button to another switch by motor the air switches were put in so there was not live wiring by the tub surface ,the the tub button/switch is like a bellows and pushes air into tube to turn switch on/off
Mar 04, 2010 | Kohler Home
Aqua glass jetted tub quit working
Hello. There are two reset buttons in the mechanical space or your tub. You should be able to access that area from the front by removing a few screws. it is not uncommon to have to push those reset buttons after a power outage. If you do need a repair I recommend that you call a store that sells hot tubs as they will have a technician on staff or be able to guide you to one. Regards, Joe
PS kindly rate my answer as helpful.
Feb 13, 2010 | Whirlpool Safety Bath Walk In Bathtub -...
Can not get the jets to work
Most of the control buttons on a tub are not electrical. These buttons are connected to an air line that runs to the motor. Sometimes an aggressive button push can literally blow the air line right off of the bottom of the button.
This problem is as easy to fix as it sounds. Find the loose air line and push it back onto the button. You will need to open up your access panel. Bring a flashlight.
Be sure to check the connection at the motor too. Good luck
Dec 02, 2009 | Home
My bathtub jacuzzi wont work. I reset the circuit breakers but nothing. I filled the tub but nothing comes out of the jets
make sure you have power to outlet that motor is plugged into,if so try pushing jet button in tub about ten times in a row quickly then on tenth push use as much force as possible and hold.if this does not work,air hose from back of button to pump motor may be disconnected.
Sep 30, 2009 | Maax URBAN 6032 HYDROFEEL AEROFEEL BATHTUB...
Two jets stopped working
Most of these jets turn to close. Check if you turn the nozzle. Hope it helps
Jun 04, 2009 | American Standard 2770.018w.020 Cadet...
Jacuzzi tub works.....sort of.
motor for tub does not run checked electric its ok.. is there a reset button and does there have to be water in the tub?
Apr 05, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
How do I use my Whirlpool bath?
youneed to make sure that the switch is on first .their should be a switch for the tub on the wall somewhere.find the switch than push the button on the tub,also make sure that their is water in the tub that is past the jets before pushing the button on the tub.
Feb 07, 2009 | Whirlpool Home
Jacuzzi - Bathtub - Alcove - Navona - R105917 Logo
465 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
