Protemp 40000 btu heater is not burning blue its orange now. Any ideas?
    Top Expert:
  • Heating & Co... Master
  • 78,289 Answers
Clean the burners with a wire brush.
Posted on Dec 05, 2016
  • 12 Answers
SOURCE: REDDY HEATERS
U must get a low pressure guage at auto zone and adpt it to fit into the left hand test port. Fire the heater and adj. guage to 3-4 psi the needel should be at a fast sweep low sweep of 3 and the higest
4. see what happen and let me know ps. that is 8 th inch pipe thread in the test port
Posted on Jan 30, 2009
tbugger
  • 232 Answers
SOURCE: Reddy heater 40000 btu heater hums when you plug it in then stop
Check the air pump. If you are lucky the rotor is busted. If not, see if the fan spins freely with no binding. If so, the starter relay is bad, if equipped. Some heaters have external relays, others have internal relays and are not serviceable. Could also be a bad bearing. Could also be - someone sat on the heater or dropped something on it, or it fell out of the truck and the sheet metal is squashed and is against the fan blade.
Posted on Feb 15, 2009
daddyo742001
  • 70 Answers
SOURCE: I live in Argentina. I have a Reddy Heater of
You need about 15000 watts or 15kva at 120 vac to run this heater. You get about 3.4 btu's per watt on resistant heat.
Posted on Jun 30, 2009
mxc2
  • 146 Answers
SOURCE: reddy heater 40000 btu ker/forcedair plug it in
First thing is to download the service manual.
http://www.desaparts.com/service_manuals.html
You need to make sure the filters are clean and that you are getting the proper air pump pressure.
If the units starts up and runs good and slowly goes out it will normally be due to a lack of fuel getting to the nozzle. When there is not enough fuel being delivered to the nozzle from either a clogged fuel filter of dirty air pump output filter the unit will slowly shut down from lack of fuel.
If the unit shuts down while it is running properly and the nose come is orange then you probably have a problem with a photocell or the flame out control.
Thanks
M Cramer
www.allpartsinc.com
Posted on Jan 05, 2011
  • 123 Answers
SOURCE: I have a protemp 38,00 btu heater.It runs but the
This type of heater is meant to be used in a ventilated area. The fumes will build up if you are in a closed area and it will soon become overpowering. This can also be dangerous from poisonous gases. Take heed to the warning label on the unit. It probably states use in a well ventilated area.
Hope that helps you.
Posted on Jan 28, 2011
Just installed a 30,000 btu Mr Heater blue flame heater last night, worked perfectly. This morning the flames and pilot light are burning mostly orange. What could be causing this.
That is a bad air/fuel mix... could be anything like clogged orifice or just needs to be adjusted.
Check out your warranty support first... and keep in mind poorly burning gas appliance can be EXTREMELY DANGEROUS.
Consider putting in carbon gas detectors in addition to a liberal sprinkling of smoke detectors!!
Be safe
Dec 10, 2016 | Blue Flame Heating & Cooling
Protemp heater is not running right and blowing black smoke before it kicks on
Sounds like you need a new nozzle and filter. Clean the pump strainer too.
Dec 09, 2013 | Milwaukee Tool Master Heater 70,000 BTU...
The heat exchanger is burning due to high limit saftey stat. What should I do
The high limits are designed to shut the heater off if the water temp exiting the heat exchanger gets too high. One is set at 135f the other at 150f. The thermostat should shut the heater off once the pool water gets to temperature.
I'm not sure what you mean by "burning". The operating temp in a 400K btu heater is around 2000 degrees. If you are getting a lot of "sooting" that is typically caused by low gas supply. That's where you get orange flame instead of blue flame. Can you give me more detail?
Nov 23, 2013 | Pool & Spa
Protemp Sun-Stream 60,000 btu heater won't light
my protemp sun-stream 60,000 btu wont ignite fan runs but igniter just makes niose
Oct 27, 2011 | Goldstar KG6000R Window Air Conditioner
My natural gas everdure commander 21 mj heater panels are burning blue. four burn orange but two are blue.
When the panels burn blue it is a sign of complete combustion. When they burn orange this is a sign of incomplete combustion. They need cleaned. Hope this helps. wally
Jun 14, 2011 | Heating & Cooling
I have a protemp 38,00 btu heater.It runs but the fuel fumes are to strong to use.How do I fix this...
Jan 27, 2011 | Heating & Cooling
Reddy heater 40000 btu ker/forcedair plug it in it takes off for a little while then shutsoff
Thanks
M Cramer
www.allpartsinc.com
Jan 04, 2011 | Reddy Heater-70,000 BTU Kerosene w/T'stat
What colour should your gas heater flame be
It should be blue. If it's got orange tips, it's burning dust, If it's got yellow flames or tips, it may need the air shutter adjusted, regulator pressure adjusted, the vent unblocked or just a real good cleaning. Douglas
Jun 05, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heating & Cooling Logo
59 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
