Question about Garden
WHAT ARE THE AIR FUEL SCREWS SET AT ON PRO MAC 700
McCulloch Chain Brake Housing
Not sure if they're compatible. You may need to check with your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Feb 15, 2014 | McCulloch 214669 Chain Brake Housing 700...
You should contact your nearest service pro to get this answered.
Contact us
User manuals
McCulloch Service
Mcculloch pro mac 700 manual
Contact us
User manuals
McCulloch Service
Jun 10, 2012 | McCulloch Garden
Hello I'm fixing my poulan pro ppb200 gas
My service center told me that they are allowed only 2 of these adjuster per year. It has to do with the air quality issue. They don't want back-yard fixer-uppers to pollute the place up. True store - I could not believe it.
The BLUE wire-splice connector, the one that you crimp after you put a wire in each end, is supposed to fit snug around those screws and allow you to adjust them. However I could not get it to work.
If you take a hack saw and cut the lip from around the adjuster screws and then cut a slot in the adjuster screws themselves, you will be able to set those screws with a flat-head screwdriver.
The whole operation takes about 9 pushes of the hacksaw. The lip is aluminum and the set screws are a very soft steel.
Good luck
John
Apr 17, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
I have a pro mac 700. I need to put the brake
An example of a McCulloch Pro Mac 700 (12-600061E) follows:
http://www.ordertree.com/modelinfo/MCC/12-600061E-PRO-MAC-700-04%2F77-to-01%2F88-IPL-93714-R7/139.12-600061E-PRO-MAC-700-04%2F77-to-01%2F88-IPL-93714-R7.1.59.1.html
There is also an 11- prefix and A,B, & D suffixes. The "Chain Brake" detail appears to be the same and may help.
All 600061 McCulloch chainsaws can be found here:
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
I would inquire here:
McCulloch Contact Us
http://www.poulanpro.com/node4033.aspx
The phone has never provided an answer to a chainsaw question. Please try the e-mail and be specific. Pretend no one except you can actually see the problem.
ArboristSite Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
ArboristSite McCulloch thread
http://www.arboristsite.com/showthread.php?t=71126&highlight=McCulloch
This gent (leeha - active) has 5 of your saw, I will wager if requested in a PM, he will take a few close-up photos of a chain brake.
http://www.arboristsite.com/member.php?u=20628
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 06, 2010 | McCulloch Garden
Do you have a part # for the mcculloch pro mac 700 front handle? the product in a pro mac 700
I found your Pro Mac 700s here:
12-600061A, B, D, or E
McCulloch IPLs
On the underside of your saw you can probably find a yellow and black tag with the serial and model numbers (600061?)
Part numbers are listed. HTH
Lou
Oct 23, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Mcculloch Pro Mac 700 Chain slips
Make sure the saw is pumping oil to the bar and chain and that the chain turns by hand freely. If ok, is there a sheared or missing key between the clutch center hub and the crankshaft?
Aug 10, 2009 | Garden
Gas oil mixture for my Pro Mac 700
40:1. Use high grade 2-stroke oil and mix thoroughly with the fuel.
Jun 30, 2009 | Garden
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
