Question about Grohe Water Heaters
Adjusting the temperature on a Grohe three way mixing valve 29 712
4 Suggested Answers
gary1121
  • 332 Answers
SOURCE: hOW TO ADJUST A MODEL 34122 gROHE VALVE
there should be a flat head screw on the mixing valve turn the water on and turn it to the desired temp,, it is letting to much cold water in , if this does not work replace the mising valve
Posted on Jun 06, 2009
snap101
  • 117 Answers
SOURCE: grohe shower
if you pull the handle off all the way back to the valve body there is a little black stopper around the cartridge body that you can adjust by pulling it out and sliding around the cartridge body this enables people to just turn the handle to one setting and jumpping in to their favorite temperature. in your case it doesn't allow you to have any cold water. so turn it one way see if you get what you want or try the other or some of them you can even just take the darn thing out and not even have to worry about it
Posted on Jul 29, 2009
mrhotandcold
  • 248 Answers
SOURCE: How do I remove grohe shower trim?
norm cover levers off go round cover at four points
Posted on Oct 16, 2009
Could my grohe thermostatic shower be letting cold water into my system? Some other taps run cool but the shower is running OK temperature
If you have single handle facute one bad cartridge in the system may be acting like a mixing valve and allowing cold water to mix with hot not allowing water to get hot enough .
Mar 10, 2015 | Grohe Water Heaters
Trouble adjusting the water temperature for the Grohmix. I cannot get much coldwater.
hi
does the water flow decrease when you lower the temperture?
is there a pump on it?
remove the thermostat housing,their should be a grub screw on the side.
pull the housing off the spindel.
turn the spindel anti clock wise.the more you turn the lower the temperature.
refit housing
turn shower on and test
more info is required if this does not solve the issue
Dec 18, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
Install trim and adjust the thermostat on a Grohe shower faucet
Before you install the temperature control knob, adjust the valve body (47111) with a wrench to set the temperature to "100 degree or close to it". Now, place the limit ring to tdc (top dead center) and control knob with the red 100-degree align to it. Your problem may have been the valve's temperature setting is out range when you installing the temperature control knob.
Jun 28, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
I need to clean the filter on my grohe shower how do I do this
Use a flat head screw driver and unsrew the brass fitting remove the temperature spindel and wash out. Re install the same way and test.
Feb 19, 2010 | Grohe Grohtherm Thermostatic Rough-In...
Grohe valve Grohtherm Thermostatic Rough 34-126 I turn the mixer to full hot but the temperature remains tepid. All the other faucets in the
The thermostatic stop is set too low. Havent set a grohe before but most other thermostatic shower valves work similar. pull off the handle(however a grohe handle comes off . . ) there should be a notched ring or stop which keeps the handle from going all the way hot. pull out the ring and turn it a few teeth hotter put back and reinstall handle try water temp and adjust again if necessary.
Jan 23, 2010 | Grohe Grohtherm Thermostatic Rough-In...
Oct 14, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Grohe shower. I want to adjust the temp mixing valve. I can not get cold water. It is always a mix-never pure cold. I want cold water. How do I adjust it?
Jul 29, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Adjusting water flow
if you are using a mixing valve it is pre set so as to not burn your self but if you wish to set it on the dial depending on which one you have, some are flat tip screw driver some have plastic cap on it turn on the water and set to your desired temp by turning clock wise or counter clock wise
Apr 21, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
HOW TO ADJUST A MODEL 34122 gROHE VALVE
Apr 11, 2009 | Grohe Grohtherm Thermostatic Rough-In...
Installation problem: Grohmix shower valve 1 1/2'' extension
This is what you should have... Grohe Grohmix Thermostat Valve & Trim - 34436
  • Paraffin cartridge
  • Lever volume control
  • Grip ring temperature control
  • 1/2" NPT female connections
  • Service stops
  • Includes rough-in valve and trim
  • Integrated temperature and volume control
  • Requires Twin Ell (03 671) for shower/tub combinations with diverter spout Note:
  • Grohe Grohmix Thermostat Valve & Trim - 34436
    Mar 26, 2009 | Grohe Grohmix Thermostat Valve & Trim -...
    Water Heaters Logo
    44 people viewed this question
    Top Grohe Water Heaters Experts
    Donni Steen
    Gil Shultz
    Are you a Grohe Water Heater Expert? Answer questions, earn points and help others
