Question about Sharp Office Equipment & Supplies
I have my message on the Sharp UX CC 500, but when someone calls in, it says mail box not set yet??
  • 279 Answers
SOURCE: sharp plain paper ink jet fax ux-b750
Many fax machines have an auto select mode that will answer the phone and listen for a fax machine, but if there is no fax machine it will cause the phone to keep ringing so you can answer the voice call. Your fax does not have that feature. The closest you can come is to set it to manually answer, and then set the fax to kick in automatically if it hears anything. The problem with this is, if you don't answer the phone when it's a fax, the fax machine never kicks in. I don't think that's what you want. The other option is to turn that feature on, but leave it as auto answer after 5 rings (the maximum for your phone). Then answer the phone before 5 rings if you're there. The problem with that is, anyone who calls when you're not there (or if you don't answer within 5 rings) will get your fax machine beeping at them. Do you need help with either of those settings? Let me know if you do, and I'll give you directions on setting them up.
Posted on Oct 02, 2007
JoshOHoward
  • 63 Answers
SOURCE: Please help
No unless there is a switch to adjust the volume turn that right down if nopt no you can't do that
Hope this helps - Josh Howard
Posted on Feb 02, 2008
SOURCE: to record a new message on my Sharp UX 265
press OGMn key
select O x general outgoing message
pick up handset and record your message (max 60 seconds) (best 30 seconds
recommend pause 2 seconds before starting recording.
press stop when finished.
press OGM to listen to recorded announcement. redo as above if not happy w it.
Cheers
ojgv@comcast.net
Posted on Feb 18, 2008
  • 148 Answers
SOURCE: I have Sharp fax machine.
if you go here http://www.sharp.ca/manuals/default2.asp you should find the op manual for that Facsimile Machine.
Posted on May 28, 2008
cnavarro
  • 2460 Answers
SOURCE: set up voice mail
Feature 14 comes to mind. It's the VM Transfer button for a Partner Voice Mail.
You set it up by dialing FEAT 00 press the button and dial FEAT 14. End programming by dialing FEAT 00.
To use it, when a call comes in press the VMXFR button and dial or press the person's DSS button.
Carl
Posted on Sep 09, 2008
Tip
SMTP server to use with Sharp fax machines (UX-B800SE and UX-D1200SE)Posted by...
<a href="http://www.smtp2go.com/blog/smtp-server-to-use-with-sharp-fax-machines-ux-b800se-and-ux-d1200se/">SMTP server to use with Sharp fax machines (UX-B800SE and UX-D1200SE)</a> <span>Posted by <a href="http://www.smtp2go.com/blog/author/admin/">mi6</a> on </span>August 19, 2009 - 4:06 am <span>Filed under <a href="http://www.smtp2go.com/blog/category/uncategorized/">Uncategorized</a></span> Some Sharp fax machines require a certain type of SMTP server in order to be able to send emails. SMTP2Go provides an SMTP server that authenticates senders based on their 'from' email address, meaning that it works with fax machines that are unable to send an SMTP username or password.<br /> Two examples of SMTP setup procedures for popular Sharp fax machines are below:<br /> Sharp UX-B800SE and UX-D1200SE Broadband Fax SMTP setup In the 'Network Settings' area, enter smtp2go.com as the SMTP server, and <b>UNCHECK</b> the box 'POP before SMTP'. Try entering either port 2525, 25, or 587 as the outgoing SMTP port. Then, make sure you are sending 'from' an email address that is registered with SMTP2Go.<br /> See a sample screenshot from the UX-B800SE fax below (click on it to enlarge):<br /> <br /> <p><a href="http://www.smtp2go.com/blog/wp-content/uploads/2009/08/sharp_fax_ux-b800se_smtp_setup.gif"><img src="sharp_fax_ux-b800se_smtp_setup_small.jpg" /></a><br /> Please note that Gmail's SMTP server doesn't work, as it not only requires a username/password, but it also requires that SSL/TLS is used.<br /> Please note: some fax machines may still have a problem sending - if this is the case, use the IP address of 207.58.142.213 instead of smtp2go.com as the SMTP server.<br /> SHARETHIS.addEntry({ title: "SMTP server to use with Sharp fax machines (UX-B800SE and UX-D1200SE)", url: "http://www.smtp2go.com/blog/smtp-server-to-use-with-sharp-fax-machines-ux-b800se-and-ux-d1200se/" }); <span><a><span>ShareThis</span></a></span><br />
on Feb 15, 2011 | Office Equipment & Supplies
All the calls we recieve in the office go through me. I greet the caller and then transfer them to the person they want to speak with. When I transfer a call, let's say to my boss, my boss will pick up...
Haven't you solved this yet? When we install a system, we reserve THREE buttons for voice mail functions. One is VM Transfer, one is 2 Way Transfer, and one is VM Record. In order you pick 3 buttons press PROGRAM one of the buttons and dial in order 94 500 STORE 01 500 STORE and 90 500 STORE, assuming your voice mail is on the default extension of 500. To send a call to someone's voice mail you press VMT and his DSS button or dial his extension and hang up. The outside party will get all of his greeting. If you want to prompt the user, like you would if you were taking a pink slip, you press 2W Transfer and his extension and carry on a conversation with the outside party. The message records in their mailbox as a new message. If you want to silently record into your OWN box, you press the VM Record button and your conversation is recorded into your own box as a new or old message, depending on how the system is set up.
There are other variations, including a single button transfer into someone's mailbox and some other features that are covered in you telephone sytsem OM or User's manual under Customizing your phone.
Carl
Mar 16, 2011 | Panasonic KX-T7630 Corded Phone
Fax problem
Set the reception mode to A.M.
Set your answering machine to auto answer.
♦ Your answering machine must be set to answer on a maximum of two rings.
If not, you may not be able to receive faxes sent by automatic dialling.
♦ If your answering machine has a toll saver function, make sure that it will
answer by the fourth ring.
Below I've provided a link to your Owner's Manual. Best of luck!
Greg
Sharp UX-B700
Nov 06, 2009 | Office Equipment & Supplies
Sharp UX-B750 won't automatically answer calls.
Your reception mode is set to TEL/FAX or TEL mode, to set it to automatically receive faxes it should be set to FAX. Look at the LCD display ( right section ).
To change the reception mode you can print the HELP LIST by pressing COPY/HELP button.
May 26, 2009 | Sharp UX-B750 Inkjet Fax
Need Sharp UX P100 Operating instructions
Go to the following link and scroll down to your model:
http://www.sharpusa.com/products/TypeManuals/0,1083,24,00.html
The line shouldn't be any trouble for local faxing.
*Please rate me :)
Mar 15, 2009 | Sharp UX P100 Plain Paper Thermal transfer...
Fax problem
Hi Fatimo25,
The screen on your fax machine displays how the machine is set to receive calls. TEL MODE means the machine will not auto-answer incomming calls and will operate as a normal telephone device, it will still however be able to send a fax in this setting.
Place your message on the original tray and pick up the handset, dial the number and when the distant machine answers press the start key or ask for their fax machine and when you hear the high pitched fax tone press start.
There is a button on the panel that will allow you to change the reception mode of your machine to the other settings.
Your machine is of a model that doesn't come into this country so I have no manuals to forward you. You can try however to access the SHARP web site www.sharp.ae
Hope this helps you
regards
Gavin
Oct 08, 2008 | Sharp UX CC500 Plain Paper Thermal...
Manual for a Sharp UX-105 Fax Machine
I've got my old manual from a Sharp UX-105 machine. Does someone want me to mail it to them?
TD (in VA)
Mar 20, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Sharp fax machine
Please help. Can Sharp UX-BD90 tel/fax machine be set to mute incoming calls?
Thankyou.
Jan 07, 2008 | Office Equipment & Supplies
Sharp UX B20 Plain Paper Fax
http://www.sharpusa.com/files/fax_man_UXB20.pdf hope this helps Cops
Oct 07, 2007 | Sharp UX B20 Plain Paper Inkjet Fax
70 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
