Question about KitchenAid Food Processors
My food processor Kitchenaid KFPW760OB1 stopped working. The light turns on when the button is pressed, but the motor doesn't turn on. What is wrong?
    Top Expert:
  • KitchenAid Master
  • 41,875 Answers
Possibly motor failure
Posted on Dec 05, 2016
KitchenAid KFPM770 motor runs 3 seconds and stops
Determine first if it really is the motor. Does it only cut out if loaded or will it happen without any load? Remove all bowls and blades, plug it in and turn the power on and press the on button. With something plastic press the small white button that is in the middle above the switch panel and normally hidden by the bowl. This is the safety cutout switch avtivated by the bowl, lid and pusher being in position. Does the motor run while the button is depressed or does it again cut out after a short time but with button still depressed. If it doesn't cut out it's likely that wear in the complicated mechanisms in the lid and bowl handle are releasing the cutout switch with small vibrations of motor running. I figure out which one to replace by swapping out one of the 2 parts for a new one as I try to carry both parts in stock for that purpose.
Jul 11, 2016 | KitchenAid Food Processors
Food Processor's light turns on but blades do not turn. Worked for about 5 minutes than stopped. It started to work again for about 10 seconds running sluggishly and sputtering, then stopped.
There will be a switch activated by correct engagement of the bowl, lid and pusher. Locate and activate that switch without the bowl on and see how it runs then. If it does then you need to figure out which of the bowl parts is not operating the switch properly. If activating that switch changes nothing then then you will need to be looking inside the motor housing, so far it's a place I haven't been on that model.
Jan 15, 2016 | KitchenAid KFP1333ACS Food Processor,...
Closing the lid completely the processor does not work
Take everything off and see if you can activate the motor with the safety switch. It is located at the front above the button panel normally covered by the working bowl. Mixer plugged in and turned on press that button switch in with something non metallic. If the motor goes then fault will be with the mechanisms that activate that switch in either the bowl or the lid. The lids are slightly more likely to be the problem than the bowl. Only a new part will properly solve it.
Sep 01, 2014 | KitchenAid KFP750 Food Processor
Food processor not working
check cover safety tab possible broken or faulty switch
Aug 29, 2017 | KitchenAid KFP740 Food Processor
I have a small Cuisinart food processor and I cannot figure out how to turn it on. It has two levers low and high. I have it plugged in and the lid on? Please help. Fiona Slattery 858-752-8591
Your PowerBlend Duet™ comes with a food processor button. This button is the perfect speed for all your food processing tasks. Always use this speed when using the food processor. You may also use the Pulse button with this function for pulse-chopping.
To use your food processor, make sure that the bowl is assembled properly and the blade or slicing/shredding disc and the cover are locked into place.
When you use the control panel, the LED will light next to each button you press.
Press the On button. For continuous operation, press the Food Processor button. Motor will start if you have followed assembly instructions.
To turn motor off, press the Food Processor button again or the Off button.
For on/off operation, called pulse-chopping or pulsing, press the On button, press the Pulse button, and then press and release the
Food Processor button the desired number of times. Motor runs as long as you hold the Food Processor button down. The motor stops when you release control switch. Try it a few times.
You control the duration and frequency of pulses by the length of time you hold the Food Processor button down and the rate at which you press it. Pulses should be short bursts. Allow enough time between pulses to let food in work bowl fall to bottom.
Always use the Food Processor button for pulse/chopping. Never turn cover back and forth to start and stop processor.
You can download manual from the below link
http://www.cuisinart.com/share/pdf/manuals/bfp-10ch.pdf
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 12, 2009 | Cuisinart Food Processors
My kitchenaid processor is not working
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. I am thinking this is an issue of assembly because the light is on, so the unit is definitely getting power.
Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
Jul 29, 2009 | KitchenAid KFP715 7 Cups Food Processor
Unit assembled, lights are on (pulse, on) nothing happens
Jul 19, 2009 | KitchenAid KFP740 Food Processor
Food Processors Logo
269 people viewed this question
Top KitchenAid Food Processors Experts
xalint1
xalint1
Don Eagan
Are you a KitchenAid Food Processor Expert? Answer questions, earn points and help others
