Question about Samsung Televison & Video
Hello, I have a samsung un55d6400 led tv, where the standby light blinks 5 times, ive replaced the powerboard and main board. The fuse keeps blowing what is my next step
    Champion:
  • 209 Answers
The fuse keeps opening because the problem is more serious. If it did not blow, then more damage could be incurred in the TV. Sounds like you should consult a professional rather than not really knowing what you should be doing next.
Posted on Dec 05, 2016
Testimonial: "Gary thank you for you assistance. I understand it could be serious. Im and electrical engineer, however i dont understand what im missing. The tcon board was disconnected as well as the backlights, only the ps, main board, and the function cable for the controls on the side/power on. When i plug in 110VAC the led light is on. But once i hit the power on the smps clicks and blows the fuse. I dont know if there is a boot sequence since the main board was replaced, is the firmware thats needed. Can i power up with just these 3 connected or is the main board looking for feedback."
I have a Samsung LED TV with no sound & screen is blank. Backlights are illuminated but nothing happens. Red power light blinks 5 times then nothing. Replaced Tcom, Power & Main board. No luck.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://electronicshelponline.blogspot.com/
If blinks continue without any pause, or the LED light stationery; the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts./
Jun 06, 2018 | Samsung Televison & Video
My Samsung LED tv doesn't turn on. No standby light. What do i need to check, to see what board is damage? What components is important to check? What to replace?
The main circuits are check before the TV is turned on. When high voltage was checked, was it 391 volts or more at the large capacitor? A voltage below 390 will shutdown the TV.
Jan 12, 2018 | Samsung Televison & Video
My Samsung LED 46" tv (UN46D6050TFXZA) won't turn on. The standby led blink twice 5 time in each cycle. all the capacitors on power board look normal.
In most of the case the problem is defective LED strips inside of the panel, please try this:
1. Unplug the cable between the main board & the power supply, apply the AC power to the power supply, if the back lights came on, the problem is defective main board.
2. if the back light do not come on, the problem in most of the case is the defective LED strips, you may get a new power supply module to test it again to make sure that the problem is not the power supply.
Aug 24, 2017 | Samsung Televison & Video
Samsung led TV model UN40H6203AF no picture no sound no backlights. Flashlight test shows letters on screen after pressing menu button. Standby light blinks 5 times after turning on.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 29, 2017 | Samsung 40" Black LED 1080P Smart HDTV -...
How do I fix my Samsung LCD TV?
It rather seems to depend on the model. I have seen Two videos on YouTube, one says it could be the LED back lighter, with a burned or shorted out LED(s). In the other it says it is the power supply board. But both were different Samsung TV's. The LED one if that looks tricky to do. If it is the power board, which I think it could be, you should be able to get the full board fairly cheap. Just be careful with the voltages when removing it, if you intend to do it yourself.
To see the Videos just type "Samsung TV blinking lights" into YouTube.
May 19, 2016 | Samsung Televison & Video
LED TV pulsing
How many have 'blinking' issue with Samsung led tv - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJan 26, 2011 - I am trying to get the number of people affected by this nagging blinkingissue with the latest Samsung led tv's. If possible it would be useful to ... Samsung LCD TV Screen flickering (LN55C630K1F)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung LED with flashing standby light on front
Apr 17, 2014
More results from www.cnet.com
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical ...
Jan 18, 2016 | LG Televison & Video
Why my samsung tv model un40es6100f power light is blinking for about 5 times?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Jan 18, 2016 | Samsung 40" 1080p 120Hz Slim LED Smart TV...
Samsung red light flashing 5 times
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Jan 17, 2016 | Samsung Televison & Video
I got a 55 inch Samsung flat panel tv model # UN55D6000Sf Version H302 with standby light blinking 1 time in repeat. I have changed the power supply board, main board & tcon board but still no luc
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jan 27, 2015 | Samsung UN Televison & Video
Televison & Video Logo
119 people viewed this question
Jerry Greenberg
Jerry Greenberg
