Question about Vivitar Cameras
Why does my vivitar 808HD freeze after first set up
Put batteries in my vivitar 808hd for the first time. switched it on all fine did initial setup still all fine took a picture and it froze non of the buttons worked couldn't turn it off ended up taking a battery out to turn it off. Put the battery back in switched it back on pressed the picture button and froze
silly girl
  • 513 Answers
SOURCE: No picture is taken when shutter release button is pressed
Are those NiMH batteries? Have you tried resetting the camera? If no standard way, just take out batteries for a few minutes, the more the merrier, let the tension build, and replace them. Try tapping on the lens area, it might loose something up. Best I can do, know it aint much ;] Good luck!
Posted on Jun 04, 2006
SOURCE: Camera froze whilst taking pictures, lens stuck.
I had the same thing with my camera. I think it is due to the lens mechanism. It is stuck in one position and thus disabled all other functions on the camera. Try to get the lens un-stuck...
Posted on May 01, 2007
SOURCE: Camera Frozen
I tried Option No.1 successfully when my Panasonic DMC-FZ7K froze once:
Option No1:
1. Try turning the camera on with the battery inserted.
2. Now remove the battery while the camera is on.
3. Flip the switch on the camera to off, then insert a fully charged battery. (Make sure that the battery's orientation is correct. Also make sure that the battery being used is not damaged).
4. Now flip the camera's switch to ON again.
Option No. 2:
If you can open the Setup menu then the camera can be reset which might help:
Turn on the camera.
1. Press MENU SET.
2. Press the left arrow button.
3. Press the down arrow button.
4. Press the right arrow button.
5. Now, press the up arrow button several times until the menu item named RESET is highlighted. Push the right arrow button and then select and set YES when the camera asks to be reset.
Posted on Jul 18, 2008
iwctoys
  • 126 Answers
SOURCE: Canon PowerShot G2 buttons don't work
You have a bad button board . This is a single board with a series of small button switches that control all these functions. Most repair shop will charge around 75.00 to fix.
Posted on Jul 02, 2009
ilovethem711
  • 5 Answers
SOURCE: my cannon powershot sd 1000
If the menus come on but there is no video or picture from the lens, that is usually the CCD which is a sensor in the camera that picks up the image. If you need to have it fixed, it's only $79 total for the parts, labor, the servicing for the camera included and even the shipping back. Go to: www.CamerasAndParts.com They just service these Canon Powershots exclusively and they are excellent for service on these. Your exact issue is on their site, it's $79 for everything and they do superb work on these models. I hope that helps, good luck with the problem.
Posted on Dec 18, 2011
New battery installed in 05 Solara, passenger door does not unlock when car put in park. How do I fix this?
When the battery is disconnected, the ADL mode returns to the default setting (Mode A). The following procedure must be used to set the ADL function to Mode B whenever the battery has been disconnected.
Initialization Procedure
Perform the following procedure to initialize the ADL function to Mode B.
1. Move the shift lever into the "P" position and close all doors. 2. Turn the ignition switch to the "ON" position. 3. Within 10 seconds after the ignition switch is turned to the "ON" position, push and hold the rear side (unlock position) of the door lock switch for 5 seconds. 4. All doors will automatically lock and unlock when you release the power door lock switch. ^ This indicates that the ADL function is set to Mode B. If all doors do not lock and unlock, the time the switch was held may have been too short or too long. Perform the procedure over again starting from step 1.
Sep 11, 2009 | 2005 Toyota Camry Solara
I just got an insignia camcorder IT FROZE AND WON'T TURN OFF!!!!
This camcorder has a really faulty design and the fact that it runs on AA batteries that it drains in a matter of hours - or less - makes it a recipe for a disaster. After mine froze for the billionth time I played around with it to see what the problem was. Apparently if you move the screen around too much, especially while it is recording, it will cause the thing to freeze. The camera really has a mind of it's own, sometimes the slightest bump will freeze it and other times if you move the screen around dozens of times nothing will happen and it works fine. If you are low on battery, which will be most of the time with this piece of ****, it only makes things worse and not only freezes the camera but shuts it off and erases your recordings. The only way to make it go back to normal is to take the batteries out and put them back in. If they are hot, that means you should let them cool or put new ones in. The best solution though is to trash this thing and buy a quality camera if you have the money.
Dec 25, 2008 | Vivitar DVR-550 DV Camcorder
Vivitar 2000 with canon xs
Trigger voltage doesn't have anything to do with the power source. Even though you're only giving it 6V (4 1.5V batteries), it ramps it up internally for the photo tube.
Old cameras used a mechanical switch to fire the flash, so the voltage didn't matter.
New cameras, like your XT, have an electronic switch and eventually will burn out, like Anonymous said. They want 6V at the hotshoe. You're giving it 56V... I know it works now, but it'll fry it eventually. You can get a hotshoe adapter that will isolate the voltage from the camera.
Dec 25, 2008 | Vivitar 2000 Flash
Samsung G600
You must replace this handset form your co.
Feb 25, 2008 | Cell Phones
Camara not turning on
yea I find that happens with me also. I think it boils down to the battery. One thing I noticed with this camera is that the battery life is not long, it uses alot of power. But also, if the camera is inactive for a certain time, it will switch off - and I think that is one of them "power-saves".
Anyways hope this helps!
Jan 10, 2008 | Vivitar ViviCam 3720 Digital Camera
Motorola V360 Text Freeze
no, try the master clear first..its in initial set-up i think
Jan 03, 2008 | Motorola Mobility V360 Cellular Phone
Camera will not turn off
Try to make the camera to work with no card, no cable connected.
If it does the same, the camera needs repair or can be sold for parts.
You can try to reset all in the menu or set up.
Oct 27, 2007 | Vivitar ViviCam 5100 Digital Camera
My Vivitar 5386
have u checked battery? and otherwise i duno
Apr 01, 2007 | Vivitar ViviCam 5385 Digital Camera
Will not power-up
this may sound stupid but did you try alkaline batteries the same happen to my friends camera until we put in the alkaline batteries !it worked. from what i read the batteries you use a very important
Sep 23, 2006 | Vivitar ViviCam 4100 Digital Camera
Cameras Logo
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
