My unit is only printing some letters not all
I have a new photosmart C4680 printer and I can only print one copy at a time from my computer. I want to print two or more copies at a time. What do I do to make this happen ?
Usually the number of copies of a certain print job is handled by the software.
Example: You have written a one page letter using WordPad. You would like the C4680 to print 2 copies of this letter:
1) On the menu, click "File"
2) Choose "Print..."
3) On the page that follows, change the number of copies to 2. There are other options you may choose at this time, if desired.
4) Click Print
The unit should start printing 2 copies of your letter.
Jan 05, 2010 | Office Equipment & Supplies
Gx-6750 typewriter problems
Check to see if the unit is not on the demonstration mode. Also, does this unit have language change feature? if so, maybe it is set for another language and you cannot of course recognize what is is printing. Or , has any liquied or hi level of moisture gotten to the unit o r the keyboard? The moisture will effect everyhting and make it iratic until thoroughly dry. Goodluck, Macgivor
Jan 02, 2010 | Brother GX-6750 Typewriter
Tops and bottoms of letters are cut off. I have changed the ink cartridge
Replace the old ink cartridge.
Verify that the unit is on. The On button is lit when the unit is on. If the device is not on, press the button to turn on the unit. Open the print cartridge door. The print carriage moves to the far right side of the unit. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. When replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. When replacing the black or photo print cartridge, remove the print cartridge from the slot on the right. Pull the print cartridge toward you and out of its slot. If the print cartridge is being removed because it is low or out of ink, recycle the print cartridge. Remove the new print cartridge from its packaging. Remove the plastic tape by using the pink pull tab. Removing the Tape from the catridge.
  1. Will have Copper-colored contacts.
  2. Plastic tape with pink pull tab ( must be removed before installing ).
  3. Ink nozzles under tape
  4. The HP All-in-One prompts for an alignment of the cartridges every time a print cartridge is installed or replaced. Follow these steps to align the print cartridges from the control panel.
  5. Top & Bottom not printing properly.
  6. Load unused, plain, white letter, A4, or legal paper into the input tray
  7. If coloured paper is loaded in the Input tray when the print catridges are aligned, the alignment will fail. Load unused, plain white paper into the input tray when the Printer catridges are aligned, the alignment will fail. Load and unused plain white paper into the Input Tray and then try the alignment again.
    1. Press 6 to select Tools .
    2. Press 2 to select Align Print Cartridge The unit prints a print cartridge alignment sheet.
    3. Load the alignment sheet print-side down and top first in the center of the document feeder tray, and then press OK. Now the printer will print properly.
Jul 29, 2009 | HP Officejet 4315 All-in-One Printer
The printing on some letters smudges
Hello sir; Try to print out one page, use you finger to rease it ,is the image come off ? if answer yes, replace fusing unit.
Jan 08, 2009 | HP LaserJet 1020 Printer
Printing blue on top of pink
There is a common colour problem with this model printer it is caused by the scanner assembly (there's a fan that blows megenta into the scanner unit).
Solution is to clean the scanner mirrors.
Aug 04, 2008 | HP Color LaserJet 2600n Printer
HP 2180 deskjet all in one problems printing
Try this :-
Resetting the All-in-One
  • Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Jul 15, 2008 | HP DeskJet F380 All-In-One Printer
4250 printing problem
Make sure you have the paper tray guides pushed up far enough.
Print a configuration page by the printer panel and verify the tray settings are correct. If they differ, check the fences are pushed up and ensure the tray lever is set to STANDARD not to CUSTOM.
If the printed paper tray settings differ to what is actually set, you may have a faulty paper tray width sensor. If you still have trouble try the Restore Factory Settings Option. Remember to note any IP info if the unit is attached to a network.
Nov 09, 2007 | HP LaserJet 4250dtn Printer
Tops of letters are cut off when printing.
This is usually caused by clogged or burned out printhead nozzels. You can try putting the unit through a couple cleaning cycles. If that does not help, then replace the cartridge with a new HP BRAND cartridge. Do not trust refilled or compatible cartridges in this case. The heating elements in the individual nozzels can burn out causing your type of problem. Let me know one way or the other Ed
May 30, 2007 | HP PSC 1610 All-In-One InkJet Printer
jasbo
jasbo
