Question about Garden
Part for 4 gallon backpack sprayer bought June 28, 2012. Spray spindle #40 for One Stop Gardens Model 65040
    Top Expert:
  • Garden Master
  • 14,457 Answers
Fixya doesnt sell products notify one stop gardens they may sell parts or advise of a parts distributor in your area or do an online search using make and model
Posted on Dec 05, 2016
I need a new rubber seal for the plunger piston on my stanley backpack sprayer. Where can I get one of these? Is there a web site for ordering these parts?
Drive out to the country side and look for a ACE or TrueValue hardware store. Bring your sprayer with you. They will likely have the right part for you in stock.
Sep 09, 2011 | Stanley Professional Backpack Poly...
I have a Stanly backpack sprayer pro 61804n and need a repair manual. Were could I find one. Thank You, Chuck
The picture looks a lot like a Solo sprayer I have. I wouldn't be surprised if Solo made them for Stanley. Do a search for Solo sprayers. They have a site. My sprayer is a Solo 425
Jun 21, 2010 | Stanley Professional Backpack Poly...
How much 2 cycle oil do i add to 4 gallons of gasoline
Add 3.2 oz of 2 cycle oil to one gallon of gas (40:1 ratio)
Dec 26, 2009 | Husqvarna Backpack Blower, Model No. 356bt
The spray unit bent and broke...
Lowes or Home depot sells replacement sprayers. Hose to tip all included.
Aug 18, 2009 | Stanley Professional Backpack Poly...
Pressure no spray on 1 gal tank
try removing the tip and cleaning it. there maybe something stuck in it even if its new. if that dont work i would take it back to where i bought it. hope that helps
May 16, 2009 | Garden
Sprayer Gun Problem
Before choosing a garden sprayer you must identify the problem. Some areas can be spot-treated with small amounts of pesticide, other areas (such as lawns or large gardens) need a larger capacity sprayer. Sprayer sizes vary greatly, from 1 quart to 4 gallons, so finding a model to fit various gardening needs will not be hard.
Aug 27, 2008 | Chapin Industrial 2 Gallon Viton...
Sprayer Question
Hose end sprayers are the simplest and least expensive of the category. A sprayer jar is attached to a regular garden sprayer. Concentrated material is added to the sprayer jar. An adjustment on the jar determines the amount delivered. The force of the water through the hose pulls the material up from the jar and mixes and dilutes it with the water. A built-in anti-siphon device prevents unused material from being pulled back into your water supply. Compression or tank sprayers are the most common type of spray equipment. Concentrated material is added to the tank. Water is then added to a marked fill line. The remaining air is pressurized by pumping the handle a designated number of times. A control lever on the wand controls the spray pattern and amount. Compression sprayers provide a precise, on target, non-drift spray good for soil and lawn pests. Adjust the sprayer for a coarse, drenching spray, a concentrated stream or a fine mist. Tank capacities range from 1 quart to over 3 gallon for handheld models. Homeowner type backpack sprayers hold up 4 gallons. The tanks may be made from polyethylene plastic, galvanized steel or stainless steel. In addition to treatments for pests and diseases, compression sprayers are designed for applying cleaning solutions for decks and siding. Backpack sprayers are operated in the same manner as the handheld compression sprayer. The over-the-shoulder configuration makes it easier to carry the heavier load of material. Some backpack models also use a lever-style pump to maintain pressure without removing the unit form your back. Powered sprayers rely on a gasoline engine for spray power. Great for larger yards or gardens due to portability and capacity (12 gallons). Dusters are a slightly different breed. Dry powders (mostly for blooming plants such as roses) are added to a canister and applied by manually pumping. NOTE: Compression sprayers deliver liquid under pressure. Compression sprayers are powerful and efficient tools. This fact also makes them potentially dangerous. Always read the manufacturer's instructions and safety precautions carefully.
Aug 27, 2008 | Sp Systems 02sv320065 Farm & Home 2 -...
Garden Logo
85 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
