Question about Building Materials
I have an issue programming my wall wireless keypad. I have followed the instructions but no go. I have installed a new battery. Our wireless keypad from the car does work ok. What should I try next?
  • 188 Answers
SOURCE: Liftmaster 1/3 HP. Remote and wireless keypad stopped working.
Sounds like the reciever for you wireless devices is not working?
Posted on Aug 02, 2009
  • 10 Answers
SOURCE: Programming of Ademco 5839
Program the house id to 8 And enable all keypads
Posted on Jan 21, 2010
  • 3197 Answers
SOURCE: My wireless keypad stopped working. I replaced the
I would make sure the battery contacts are clean and not corroded. Otherwise a new keypad is most likely the answer. Just FYI the keypad will still work when the wall control is locked.
Posted on Sep 28, 2010
  • 3197 Answers
SOURCE: All of my wireless entries just stopped working -
Your receiver is going bad. It is part of the logic board.
Posted on Dec 10, 2010
  • 1116 Answers
SOURCE: The wall mounted control works
What is your exact model number?
Posted on Aug 15, 2011
Trying to reprogram my 387lm to my 8550 liftmaster
Its not compatible with an 8550 of it has a yellow learn button....you will need to locate an 877max lm keypad
Apr 11, 2013 | Chamberlain Liftmaster 387lm Wireless...
Changing PIN on Key Pad
can you please provide the exact model number of your Security device...
Thanks
Jul 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
Door opens by itself
Will likely need a little more info. I am presuming this is the wireless version since it's a Digi Code. However, my first thought is that the problem is not necessarily with the keypad. Most likely could be a programming issue. Have you tried to clear the memory on the Logic board on the Garage door opener and then re-program all of the openers, including the keypad?
Some Logic boards have a dedicated slot for one wireless Keypad that is made specifically for that brand of opener.
A helpful hint: When programming the keypad, have another person help you. Have them push the program button according to the programming instructions for your GDO Make.(Garage Door Opener)
Then you key in the required sequence for programming your keypad immediately after the programming button has been pressed. This reduces the amount of time the logic board wireless memory is in the learn state.
Sometimes stray radio transmissions operating at or near your openers frequency can inadvertantly be programmed into your openers logic board. Especially if there are other same manufacturers GDO units wireless remote transmitters in use within close proximity operating on the same frequency.
Another possible cause is in your hard-wired wall control button or wiring to it. There could be a short in the contacts causing the opener to operate, or a short in the wire to the wall control button. I've run into smashed wires that have had the outer insulation pierced and the metal staple shorts across both wires. (this is not good for the logic board, as it can damage sensitive circuitry on it. Causing more Costly repairs)
One way to isolate the issue is note when this occurs. Is it always the same time every day? Or is it completely random?
I hope these possible solutions help MASTER_TECH1
May 27, 2011 | Digi-Code Digi Code 5202 Garage Door...
I am trying to reprogram my clk1 wireless keypad for a new Chamberlain opener. My clicker manual refers to either green or orange smart buttons, bot not purple, which my opener has. The programming...
Go to the website shown below and click on programming instructions. Follow the instructions in Chart A,
http://www.chamberlain-diy.com/doityourself/pages/productmodeldetail.aspx?modelId=1477
Jan 29, 2011 | Sears Craftsman LiftMaster Chamberlain...
My wireless keypad stopped working. I replaced the battery. It worked 1x and hasn't worked since. I'm able to program remotes. The keypad is backlit and flashes when I enter the code or try to program it....
Sep 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Nov 21, 2009 | Honeywell 5804 Ademco Wireless Security...
Aug 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
I can't get my keypad to program. we follow
If you have replaced the battery and it still doesn't work after programming then it must be bad.
Jul 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad lights flash, wont open with code. Wall button and remote work.
You need to do a remote and opener re synch, because your rolling synch codes were lost when you replaced the batteries. Go to manufacturers web site for re program instructions.
Apr 18, 2009 | Computers & Internet
Building Materials Logo
67 people viewed this question
Top Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
