Date of manufacture of TV - HV 3207052500A5 - Televison & Video
I want to register my tv
Warranty registration information should be provided with the paperwork that came with your TV. If you have lost that, go to the manufacturer's website and look for a link to warranty information or warranty registration. Some manufacturers do not require registration, however, you must have proof of purchase to retain the warranty from the purchase date rather than the date of manufacture.
Sep 03, 2017 | Televison & Video
What year was the RCA TV Model F19426 manufactured?
Since the manual has a copyright date of 2001, I would guess that the RCA F19426 was manufactured in 2001 or 2002. ManualsLib has the manual for this TV: https://www.manualslib.com/products/Rca-F19426-328410.html . The last page, https://www.manualslib.com/manual/138735/Rca-F19426.html?page=64#manual , has the copyright date.
I hope this helps.
Dec 22, 2016 | RCA Televison & Video
Manufacture date
there is a label on the unit that has the model & serial numbers & date of manufacture. If you cannot locate it, you might try removing the cover & look inside for any indication of dates.
Mar 04, 2015 | Televison & Video
Turned on tv no picture only sound then i heard a pop and smelled burning tv turned itself off. 5 min tried turning on tv again nothing happened tv does not turn on at this time
Your RCA TV needs serious troubleshooting. Burning smell is from HV transformer or resistors smoking.
Most likely power supply and/or high voltage circuit or convergence circuit. Many times RCA have multiple or secondary faults that occur with HV or convergence failure.
Repair of RCA HV or convergence usually requires exact manufacturer parts and upgrades or repair in power supply. I would not advise trying this repair without manufacturer support for correct part numbers and service bulletins.
easyab
Feb 28, 2010 | RCA Televison & Video
Magic Chef M/W MCD990ARB - heat quit
Mine did the same thing: Replaced the HV Cap and diode - works fine now.
Jul 05, 2009 | Magic Chef MCD990W Microwave Oven
Hitachi Projcection TV
If the High Voltage section is working Ok, the relay Could be the culprit.. The cost is negligible, about 40 bucks. The standby voltage needs to be verified as correct before the H.V can switch on. If the HV section is bad, you could be looking at about 150 to 200 bucks to get it back up again.
What model Accorgan do you have? Iorio imported many units from other MFGRS over the past number of years. The last model out was a "J" series, and was manufactured by SEM in Italy, with sub assemblies being built in France, Russia, and Austria. Early models were the "G", "H", and "I" series being built back in the 60's, 70's, and 80's, respectively. Those models were manufactured by Elkavox..accordianman
Sep 15, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Arcing noise in big screen tv 1996 rca
Probable bad HV block Part # 205064
Possible bad CRT = disconnect HV leads one at a time from
HV block until arcing goes away
Please rate this solution..........
Nov 14, 2007 | Televison & Video
Tv sounds like it wants to turn on but doesn't???????
Probable bad HV block ....Provide service number off back of set for verify part # 205064............................................T.
Apr 01, 2007 | RCA P46921 46" Rear Projection Television
MY Samsung HCN4226W have perfect sound but no picture
I had the same experience with my set. I noticed there were 2 new cables attached to the new board and looking carefully noticed the connectors were different from the old. The new connector fit perfectly into the new board but wasnt the same as the old. I replaced the old cable with the new and the TV remained bad. I then flipped the connector to the main circuit board (bottom left) and the new board worked fine. I know nothing about Tv repair, but this new cable seems to be a universal connector in which the contacts are open on 2 sides...allowing them to be flipped if necessary. Now if I could get that solid line out of the display I'd be set!
Nov 05, 2006 | Samsung HCN4226W 42" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
