Question about Hoover F7452-900 SteamVac Upright Vacuum
Hoover f7452900 brushes wont turn? - Hoover F7452-900 SteamVac Upright Vacuum
  • 97 Answers
Make sure that you have it on the carpet setting and not the hardwood/tile setting. also if you used the hose, make sure that the little door is closed. if all checked... remove the recovery tank, there should be a rubber grament on the stand pipe under the tank, if it is there, then it would have to be the turbine assembly that drives the brushes
Posted on Jul 20, 2009
3 Suggested Answers
SOURCE: Brushes on My Hoover Steam cleaner will not spin
We had same problem,Had to have bearings replaced at hoover store/service center. If you bought it within the last year it is under warranty and you wont be charged.
Posted on Nov 25, 2008
ThinkVacuums
  • 144 Answers
SOURCE: Need to remove bottom brushes of Hoover Steam
Here is the manual that came with the vacuum if you didn't have it already, in it on page 13 of the pdf shows you how to remove the bottom brushes.
www.thinkvacuums.com/pdf/uprights/Hoover_F7452900.pdf
Posted on Aug 25, 2009
Hoover F7425-900 SteamVac V2
http://www.hoover.com/pdfs/manuals/F7452900.pdf Heres a link to the manual if you dont have one, Ive emailed them and they gave me the same solutions that are on page 17. ? Make sure tank is securely locked in position ? Clean water tank or detergent container empty ? Refill container according to instructions for surface being cleaned ? Recovery tank lid not on correctly ? Make sure lid is firmly in place ? Valve cap clogged ? Remove and clean valve cap (see following instructions) 1. Remove clean water tank. 2. Turn valve cap (A) counterclockwise and remove. Soak valve cap in warm water for at least 15 minutes. Wipe cap dry. 3. Align slots (B) on cap with tabs (C) in opening. Turn cap clockwise to tighten.
Sep 17, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
I have a Hoover Steam Vac F7452900. I've read the tutorial about how to replace the brush turbine but the pictures are of a different model. I've removed the screws from the underside but my...
I have an F7427-900 but try taking a flat headed screw driver to the black plastic on the front. I gently tried it on mine and it popped up no problem.
Sep 05, 2011 | Hoover V1 SteamVac SpinScrub Vacuum
F7452900 brushes not turning
The usual reason for this is that the air driven turbine which turns the brush has seized up. Remove the brush assembly and insert a screwdriver into the square hole that the pin on the brush normally fits into. ( Make sure the pin has not broken off). If you can't turn it, the turbine has frozen up and must be replaced. If you can turn it, the problem lies elsewhere. Pull out the lint screen on the bottom of the machine and be sure it is clean. Be sure the brush control is set properly, and be sure the dirty water tank is firmly in place. The turbine will not turn without the lower tank in place.
Feb 20, 2011 | Hoover SteamVac F5914-900 SpinScrub...
How do you replace the brushes on a hoover f7452-900
You have two model numbers showing. I could not find anything on the F7425-900, but I did find an exploded view of the F7452-900 If you go to this URL:
http://www.ereplacementparts.com/hoover-f7452900-steamvac-all-terrain-parts-c-37315_37419_37439.html
you can see the exploded view. This itself does not provide directions on changing the brush, but it does indicate that by removing a few screws on the brush and squeezing some plastic tabs (looks like any way) that you can pull the brush off. If you have the new brush already, it may indicate some of the connection points.
Hope this helps a bit. Paul
Oct 05, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
I have a Hoover F7458-900 steamVac all terain. I
You can reach under the brush (on top) and pull down. The manual for an all terrain is here to download
F7452900
Apr 10, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
Need to remove bottom brushes of Hoover Steam cleaner F7452900 to clean
Aug 25, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Agitator brushes wont turn even after cleaning
the brushes will not turn even wen the switch is turned on
Aug 10, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Nov 24, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover F7452-900 SteamVac Upright Vacuum Logo
345 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
