Question about Kitchen Ranges
Renters got gas shut off, now back on but can't get the furnace to come on
    Top Expert:
  • 12,744 Answers
Need to relight pilot and check power supply
Posted on Dec 05, 2016
Colman gas furnace wont light
Is it natural gas or propane? If propane, make sure you are not out of gas. Does it have electronic ignition or a manual pilot? if pilot, make sure the pilot flame is still lit and the control knob is turned to the "On" position. If it has electronic ignition, shut off the power to the furnace and then turn it back on and see if resets and lights.
Feb 16, 2015 | Coleman 7990-319p Evcon Gas Furnace...
Intertherm furnace model # MMHB-070ABHR-06 red light blinks two times
Number of flashes mean different things for diff models. The meanings of those flashes should be posted somewhere on the unit; usually inside front of the bottom service panel. Though you can't truly diagnose a problem by number of flashes they can give you an idea of where to look for a problem. There are a ton of videos and how-to's about furnaces on youtube by real service techs. Most modern furnaces have basically the same set-up and features so don't worry about your paticular brand; but of course that would be the best place to start looking. You could start here to familiarize yourself with your brand of furnace:
And then here:
Hope this helps.
Dec 21, 2012 | Heating & Cooling
Goodman furnace model # GMNT100-4B On vacation, neighbor checked house, house filled with gas. He shut off main and furnace. came home turned on gas to everything except furnace. All good. Furnace will...
Solid red typically means bad controller. Try unplugging the furnace, wait about 30 secs, then plug it back in. The possibility that the controller was sending voltage to the valve even when there was no flame is a bad sign. If the controller starts the furnace, watch it very closely and see what it does. If the solid light comes back on, it's time for a new board.
Mar 24, 2010 | Goodman GMS90703BXA Heater
Gas Furnace - residential -found furnace off - pilot light off -
check ur venting first make sure its not plugged
Jan 01, 2010 | Heating & Cooling
Furnace flame goes low fan stays on
if the gas pressure is good on inlet and outlet of valve u might wanna chk the burner trays and manifold for flakes, dirt, spider webs ect... once u kno the passages are clear from obstruction you can focus on the mechanical. (sounds like gas valve may be getting weak and not able to open fully)
Mar 21, 2009 | Dayton Gas Furnace Heater
Suburban RV Furnace
make sure fan is set auto its just seeing fan motor now
Jul 06, 2017 | Dometic Rooftop RV Air Conditioner
Old Gas furnace(heat only)
Yes, it only needs 2 wires to run.
Please rate Fixya solutions
Jan 20, 2009 | Hunter Fan Company 5/1/1 Programmable...
Lennox Gas Furnace that turns on and shuts off in minutes
After troubleshooting like mad, I found that the flame sensor (rod that sits within the flame) was fouled with carbon on the surface. I believe this shields the rod from proper heat detection and the sensor reports that there is no flame and to shut off the gas valve to avoid explosion. Once I pulled out the rod and cleaned it with a wire brush, I have no problem whatsoever--fixed.
Nov 10, 2008 | Heating & Cooling
Furnace will not light, but there is gas to the house
This problem will need to broken down in several steps. First, reset all the breakers that operate the furnace and ac. Turn the thermostat to on and the ac to off and see if the furnace blower starts. Get back with me.
Aug 12, 2007 | Haier HWF05XC5 Air Conditioner
Kitchen Ranges Logo
35 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
