Question about Smeg Ovens
I have am error code 5 on my smeg LB127 X-1, what do I need to do?
After a pyrolitic cleaning cycle, an error code F04 has appeared and the menu does not want to start any more.
Miele fault code f04 Ovens Questions & Answers - Fixya > Forum > Tags > fault code f04 > Ovens
Miele ovens fault code f04 related questions and answers. ... Can't use my Meilepyrolitic oven fault 90 I turned it off at the main power source and then ... fault 23 is displayed on the control panel after using teh self clean function on our miele ...
Smegelements or interior surfaces or racks of the oven during or immediately after use. During the oven ..... locked automatically due to self-clean mode. "USER LOCK" is ...These codes are displayed when the electronic control detects a ...... The ovens feature a pyrolytic self-cleaning function ..... F03 or F04 Error appears.
[PDF]user manual e:line built in ovens - Appliances Online
Jan 10, 2016 | Ovens
Will these doors interchange, on these models
doubt it but measure both and see if they are close
Apr 21, 2015 | Smeg Ovens
Has anyone got a successful recipe for a sponge made in a new Smeg oven. Had no trouble with my old Smeg but new one doesn't seem to produce the same standard of product with the same recipe
Dunno, if I had a sponge in MY smeg oven i'd try to cook it at 400 degrees for at least 5 hours then bury it in the backyard!
Then I'd be sure it was dead.
Mar 16, 2015 | Smeg Ovens
What does error 8 mean?
Same problems, error 4 followed by error 8 on smeg oven SFP496X-1
The cooling fan had stopped working.
I fixed the problem by replacing the 20W ceramic resistor connected to the fan.
The spare parts number maybe 806890480
an image of resistor
Sep 24, 2014 | Smeg SE399X/5 Stainless Steel Electric...
Smeg oven is "locked", needs unlocking or resetting
Use a flashlight and look into the hole from where you normally feel hot airflow. Locate the hook holding the door on the left side. Using a thin screwdriver or a knife gently push the hook to the left. Voila! The door is open and functions are back working normally. Also known as Error 4 interlock problem. This will depends on the model of the oven
Jan 30, 2010 | Smeg SE399X/5 Stainless Steel Electric...
try this site for service and user manuals. download pdf files.
Jun 07, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Ovens Logo
29 people viewed this question
Top Smeg Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
