Question about Kitchen Ranges
What is the watts (power consumption) of the Defy DFC Range - Model K55261 Thanks
4 Suggested Answers
  • 20 Answers
SOURCE: power consumption/in watts
Most likely 350 or there abouts.
I tried to look up the specs but VGN -NR17G is not a known model number.
Posted on Jan 28, 2008
  • 10 Answers
SOURCE: Does anyone know the power consumption in watts
yeah find the data plate on the ac muliply the RLA or amps by the voltage of the unit example 15 amps times 120volts= 1800 watts. hope this helps
Posted on Jun 07, 2009
  • 5 Answers
SOURCE: What is the average power
Sir / madam
Horsepower (HP) is the name of several units of measurement of power. The most common definitions equal between 735.5 and 750 watts. Horsepower was originally defined to compare the output of steam engines with the power of a draft horses... In refrigerator the unit use is horsepower(HP) 1 HP = 750 watts
Posted on Jun 21, 2011
How much power does it consume?
It is only possible to get a total figure of the power a computer uses by external measurement, i. e. use of a device that measures such. There are expensive power supply units that do measure consumption in the $500 range, as well. A ballpark figure for consumption is between 65 and 300 watts. No software can provide the total figure although there is software than can measure power consumption of a CPU. Here is a link to a relatively inexpensive device which can measure devive power consumption:
Kill Watt Electricity Monitor P4400 The Home Depot
Oct 21, 2017 | Power Computers & Internet
I just purchased a lasko model 5805 ceramic heater. What's the cost to operate.
look for the power rating of your heater (usually it is in Watts (W) and convert it to kilo Watts (kW) unit by diving it by 1000).
kW = W / 1000.
now divide the kW by hour many hours your planning to operate your unit.
power consumption = kW/operating hours
when you get your power consumption value then multiply it with the power cost (you can find it usually in your bill).
cost to operate = power consumption x power cost.
Happy New YEAR!!!!
don't forget to rate me...
Dec 31, 2010 | Lasko Ceramic Heater
What is the power supply for the hp 845c printer ? Thanks,
Electrical specifications NOTE: The HP Deskjet automatically accommodates the worldwide range of AC line voltages and frequencies. There is no on/off switch on the power adapter. Category Specification Input voltage 100 to 240 volt ac (VAC) (+/- 10%) Input frequency 50 to 60 Hertz (Hz) (+/- 3 Hz) Power consumption (maximum) 4 watts maximum when off
4 watts minimum when idle
45 watts maximum average printing (Printer carries the ENERGY STAR emblem)
Jul 16, 2010 | HP DeskJet 845c Printer
I have a microwave and I am not sure of the wattage . The model # is JES738WJ02 And seriall # is DS991786u could you please help me find the answer to how many watts this product is. Thank you
Your microwave oven is 700 watts. Its printed on front of the owner's manual. If you no longer have an owner's manual, you can go to and download or print a copy for FREE. Just type in the model number you provided under the "Manuals" link. Your manual is listed in .pdf (Adobe) format. I hope this help you.
Feb 28, 2010 | Microwave Ovens
What is the power consumption for HP laserjet 2430dtn
hello welcome to fixya
The details of power consumption for HP lase rjet 2430dtn are:-
If 'll be Active then : 625 watts
If it 'll be on Standby then : 11 watts
Power save: 8.5 watts
I hope it 'll helpful for u,
Kindly Do Rate if it is Helpful
Thanks & keep using fixya
Feb 19, 2010 | HP LaserJet 2430dtn Printer
Checking power consumption
you need a clamp on amp probe, a multimeter wont hack it. if you can get a amp probe, you first seperate the wires on your cord and then place the probe over one of the wires only this will give you your consumption. by the way, your approx usage of watts on a 26 inch lcd tv would be 160 watts. models do vary.
Mar 29, 2008 | Televison & Video
Power consumption/in watts
Jan 28, 2008 | Toshiba Satellite M35X-S111 Notebook
12C Power Supply
Power inverters are plentiful on eBay in the range of $25-$100 US and any within that range would satisfactorily supply 110-120 VAC for your set. These items are also available at auto & RV parts outlets.
Check the rated power consumption on the set itself or in the user guide but I doubt that it will need more than 150 watts at 120 VAC.  If the consumption is not given in watts but instead amperes, multiply that number by 120 (for the liine voltage) and the result will be in watts. Any higher wattage that you buy will give you the possibility of using it for things other than your TV.
All later consumer items such as your set are able to deal with the quasi-sine wave output of this kind of primitive inverter.
Power inverters
Not all items can use this kind of AC; any power tool or kitchen appliance with brushes for the motor will accept this kind of voltage, as well as resistance type of appliances like hair dryers, curlers, etc. If you are in doubt about something you might like to attach to an inverter, listen closely to the device and if it doesn't sound like it did at home, don't use it.  Also if it starts to emit an odor or heats excessively, stop using it.
Sep 16, 2007 | Sansui LCDVD200 20 in. TV/DVD Combo
Power Consumption
Power Consumption 240 Watts and the Standby Power 2.0 Watts
Jun 28, 2007 | Hyundai ImageQuest PD421 42 in. HD-Ready...
Kitchen Ranges Logo
44 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
