Question about Brother Sewing Machines
Bobbin case won't lock in place making the needle brake , brother ce4000
    Top Expert:
  • Brother Master
  • 8,204 Answers
How to fix bobbin timing?
Check to see the bobbin case is in fully, and the shuttle race cover is secure. Also make sure the needle is not larger than specified for the machine (many machines can't cope with size 18 or 19 needles!) Also check to see if the needle is of the right needle system (not a serger needle!), and fully up in the needle clamp. The needle package should show one of these needle systems: HAx1, 130R, 130/705H, 15x1, SY 2020.
May 25, 2014 | Brother CE4000 Computerized Sewing Machine
check the thread take up lever to see if the thread has come off
that can cause the machine to jam
change the needle
Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
rethread the machine top & bobbin
check the bobbin to make sure it's not warped
Jun 07, 2012 | Brother CE4000 Computerized Sewing Machine
Singer Confidence Model 7470 bobbin jammed, needles breaking, now won't sew
Sewing machines will get out of time, often as a result of broken needle. Search for sewing machine timing or take it for service, otherwise it will simply continue to break needles and possibly damage the machine.
Nov 11, 2017 | Brother Sewing Machines
E6. Motor locked up because the thread is tangled. I have re-threaded machine and bobbin; thread still tangles after 2 or 3 stitches. HELP!
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
Jan 18, 2011 | Brother CE4000 Computerized Sewing Machine
The bottom bobbin of my machine seems to catch as the needle comes down cause the needle to jam and sometimes bend. is there anyway i am able to adjust the bottom bobbin so that when it is rotating it does...
put a new needle in & see if it still does the same thing & if it does the same thing check the bobbin & bobbin case to make sure there inserted correctly,,make sure there is no lint or loose threads in bobbin area
if that doesn't help then it could be out of time
Oct 21, 2010 | Brother CE4000 Computerized Sewing Machine
My ce4000 started jamming up thread under the foot and then it pulls the bobbin case and gets stuck so that it doesn't sew at all
If the thread is getting jammed under the FABRIC then it means the TOP thread is threaded wrong. Just the opposite of what we think it should be. If the thread is looping on the TOP of your fabric it's the BOBBIN thread that's not threaded right. If it's a front loading bobbin, the thread should go over the top of the bobbin to the right before placing it in the bobbin case. Hope this helps!
Aug 21, 2010 | Brother CE4000 Computerized Sewing Machine
Corect threading needle for sewing on brother lx3125
please follow the instruction
1. raise needle to its hieghest position
2. remove hand hole cover plate
3. remove bobbin case from shuttle, pull open latch of bobbin case
4. pull bobbin case straight out of shuttle
5 insert bobbin into bobbin case making sure thread is coming from bobbin.
6. pull thread through slot
7. pull thread under tension spring
8. holding latch open position case into shuttle, and release latch. case should lock into place when latch is released
happy sewing.
regards please rated me.. thanks
Mar 31, 2009 | Brother Sewing Machines
I have a Singer XL5000 machine, the normal looking bobbin is not spinning with the shaft and wont wind what have I done wrong?
Is your bobbin case holding in place right? See if you can jiggle it back and forth to see if it moves. If it does move, it may have unattached itself in it's inner-casing.
My bobbin case would just go back and forth in the casing. Make sure that your needle plate is inserted right, as it locks the bobbin case in. You may have to unscrew the needle plate, take out the bobbin case, place it back in - pushing it to your left as you glide the needle plate back into place. (go from front to back while inserting). It should catch your bobbin case and lock it into place. Hope this helps. If not I would suggest you take it in for repair. Good luck.
Jan 14, 2009 | Singer Quantum XL-5000 Computerized Sewing...
Sewing Machines Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
